Author Topic: Stell gauges with WeatherCat  (Read 2155 times)
Offline lobsterman
    • Cape Small Harbor Weather
« on: September 26, 2016, 05:06:55 PM »
I have the Steel gauges working with my meteobridge but am not managing to do it with the WeatherCat program
realtimegaugesWC.txt is updated on the server just fine; the Steel gauges are in their folder in the same level as the realtimegaugesWC.txt file; gauges.js is set as follows:
Line 38:
            imgPathURL         : '../../',            //*** Change this to the relative path for your 'Trend' graph imagesLine 68:
realTimeUrlWC      : '../../realtimegaugesWC.txt',   //*** WeatherCat Users: Change to your location of the JSON script generator ***
and the scroller/tickertape consistently reports "error - Not Found"
http://suiattle.net//CapeSmallHarborWeather/wc/wxssgauges.php
I'm sure I am missing something very obvious and basic but can't seem to spot it.
