Author Topic: Saratoga Template Script issues?? Try this before reporting a problem...  (Read 3126 times)
If you're having an issue with one or more scripts in the Saratoga template set (USA, Canada, World) and something that was working is now not working, try running (on your website):
 check-fetch-times.php?show=versions
It will show the version levels of core scripts v.s. what you have installed, and give you a link (if needed) to the update tool page with query info.  Using the update tool page will generate a .zip just for you that contains all the needed updates and quick instructions on how to install each script.
If running check-fetch-times.php?show=versions on your site just shows a series of fetch tests, then you have an old version of that software.
Download a fresh copy from here, upload to your site, then run check-fetch-times.php?show=versions again.
You'll be glad you did, and you can save a posting on the forum or an email to me for some other issue not fixed by the above.
Best regards,
Ken
