Author Topic: Bios Weather Station/rain guage problem  (Read 3866 times)
Offline kdfarms
« on: January 12, 2009, 03:32:38 AM »
I have a Bios Weather Station, (cheap, I know but actually pretty acurate)
The rain guage has on a couple of occasions recorded extreme rain amounts
even in dry conditions. As much as 16 inches even when no actual rain.
Any thoughts would be appreciated.
Offline offroadjosh
  • Davis Vp2 Wireless- VWS 14 P90 Serial Data logger
  • Montana Firefighter
    • My Website=)
Re: Bios Weather Station/rain guage problem
« Reply #1 on: January 25, 2009, 06:55:14 PM »
start off by checking connections;) and also checking your rain gauge out for any corrosion and nicks in wires
Josh
Josh Patten
Davis VP2 Wireless -May 2008
VWS 14.00P90\WL 5.9.9/Plus others!
Skywarn trained
CoCoRaHS member
Smith Valley Fire Dept Firefighter:)
http://josh.northwestwx.com/station/usa.htm
CWOP-DW0711
Kestrel 2000 hand held anemometer
Cocorahs 4in rain gauge
Custom co
Offline DanS
  • Chiang Mai weather
    • ThaiWx
« Reply #2 on: January 25, 2009, 07:07:16 PM »
Yes, as Josh said, check connections. I've found with the LaCrosse station (also cheap one) that sometimes just unplugging and reconnecting a plug several times clears a problem. Oxidation on the contacts from weathering plays havoc on connections. :-)
Not sure about the Bios rain guage but inside mine there's a reed switch that opens/closes for each tip of the see-saw bucket. If your cables and connections check out o.k. and yours has a reed switch you may want to check that out. If it's not opening and closing completely it will give erratic readings.
Dan
« Last Edit: January 25, 2009, 07:11:57 PM by DanS »
    • Watts Bar Weather
« Reply #3 on: January 25, 2009, 07:11:25 PM »
Consider dielectric grease.
