Author Topic: weatherlink browse records - no data?  (Read 1355 times)
Offline m77
« on: July 17, 2016, 11:08:48 AM »
when i click 'browse data' in the WL software it just shows a long list of dates and times, with no weather data.
However when i run a NOAA report, this seems to function as normal.
Has my data disappeared?!
Have I just hidden it?
thanks
Weatherlink ip, Vantage Vue,
Offline m77
Re: weatherlink browse records - no data?
« Reply #1 on: July 17, 2016, 01:32:24 PM »
solved.
- if it shows only date and time, check an entry for data (double-click or go to edit)
- if data there, close WL and delete the two DAT files - "DataSets.dat"  & "DataLists.dat"
taken from http://www.wxforum.net/index.php?topic=3168.0
Offline plr78
« Reply #2 on: May 11, 2019, 07:42:02 AM »
Excellent solution!
I faced same issue w/ WL 6.0.5.
Erased the 2 DAT files ("DataSets.dat"  & "DataLists.dat").
Then it worked perfectly.
