Author Topic: Sdr  (Read 5762 times)
Offline atari
Sdr
« on: July 05, 2016, 11:39:02 AM »
hi
I have auriol weather station, sdr usb device. Im trying to make driver work but for now whitout success.Can anybady help?
I use:
h**ps://github.com/matthewwall/weewx-sdr
for driver
root@ubuntu1404:/home/weewx/bin# weewxd /etc/weewx/weewx.conf
Traceback (most recent call last):
  File "/usr/bin/weewxd", line 64, in <module>
    weewx.engine.main(options, args)
  File "/usr/share/weewx/weewx/engine.py", line 859, in main
    engine.run()
  File "/usr/share/weewx/weewx/engine.py", line 185, in run
    self.dispatchEvent(weewx.Event(weewx.NEW_LOOP_PACKET, packet=packet))
  File "/usr/share/weewx/weewx/engine.py", line 218, in dispatchEvent
    callback(event)
  File "/usr/share/weewx/weewx/engine.py", line 313, in new_loop_packet
    if event.packet['usUnits'] == self.target_unit: return
KeyError: 'usUnits'
root@ubuntu1404:/home/weewx/bin# wee_debug --info
Using verbosity=1, displaying most info
wee_debug output will be sent to stdout(console)
Using configuration file /etc/weewx/weewx.conf
Using database binding 'wx_binding', which is bound to database 'archive_sqlite'
System info
  cpu cores:              8
  bogomips:               4800.16
  core id:                7
  apicid:                 7
  fpu_exception:          yes
  stepping:               1
  cache_alignment:        128
  clflush size:           64
  microcode:              0x1
  cache size:             4096 KB
  cpuid level:            13
  fpu:                    yes
  model name:             Common KVM processor
  siblings:               8
  physical id:            0
  address sizes:          40 bits physical, 48 bits virtual
  cpu family:             15
  vendor_id:              GenuineIntel
  wp:                     yes
  power management:
  flags:                  fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx lm constant_tsc nopl pni cx16 x2apic hypervisor lahf_lm
  cpu MHz:                2400.084
  model:                  6
  processor:              7
  initial apicid:         7
  Operating system:       Ubuntu 14.04 trusty
                          Linux ubuntu1404 3.13.0-91-generic #138-Ubuntu SMP Fri Jun 24 17:00:34 UTC 2016 x86_64
  1 minute load average:  0.02
  5 minute load average:  0.04
  15 minute load average: 0.05
General weewx info
  Weewx version 3.5.0 detected.
Station info
  Station type: SDR
  Driver:       user.sdr
Driver info
[SDR]
    # This section is for the software-defined radio driver.
    # The driver to use
    driver = user.sdr
Currently installed extensions
Extension Name    Version   Description
owfs              0.18      driver for one-wire devices connected via owfs
sdr               0.1       Capture data from rtl_433
Archive info
  Database name:        weewx.sdb
  Table name:           archive
  Unit system:          16 (METRIC)
  First good timestamp: 2016-07-03 23:10:00 CEST (1467580200)
  Last good timestamp:  2016-07-04 11:50:00 CEST (1467625800)
  Number of records:    12
  weewx (weewx.conf) is set to use an archive interval of 300 seconds.
  The station hardware was not interrogated in determining archive interval.
Databases configured in weewx.conf
  Database driver:      weedb.sqlite
  Database driver:      weedb.mysql
  Database host:        localhost
Parsed and obfuscated weewx.conf
# WEEWX CONFIGURATION FILE
# Copyright (c) 2009-2015 Tom Keffer <tkeffer@gmail.com>
# See the file LICENSE.txt for your rights.
# This section is for general configuration information.
# Set to 1 for extra debug info, otherwise comment it out or set to zero
debug = 1
# Root directory of the weewx data file hierarchy for this station
WEEWX_ROOT = /home/weewx
# How long to wait before timing out a socket (FTP, HTTP) connection
socket_timeout = 20
# Do not modify this. It is used when installing and updating weewx.
version = 3.5.0
#   This section is for information about the station.
[Station]
    # Description of the station location
    location = "Neutrino-Digital, Paracin, Srbija"
    # Latitude and longitude in decimal degrees
    latitude = 43.515
    longitude = 21.245
    # Altitude of the station, with unit it is in. This is downloaded from
    # from the station if the hardware supports it.
    altitude = 130, meter    # Choose 'foot' or 'meter' for unit
    # Set to type of station hardware. There must be a corresponding stanza
    # in this file with a 'driver' parameter indicating the driver to be used.
    station_type = XXX obfuscated by wee_debug XXX
    # If you have a website, you may specify an URL
    #station_url = http://www.example.com
    # The start of the rain year (1=January; 10=October, etc.). This is
    # downloaded from the station if the hardware supports it.
    rain_year_start = 1
    # Start of week (0=Monday, 6=Sunday)
    week_start = 6
[Simulator]
    # This section is for the weewx weather station simulator
    # The time (in seconds) between LOOP packets.
    loop_interval = 2.5
    # The simulator mode can be either 'simulator' or 'generator'.
    # Real-time simulator. Sleep between each LOOP packet.
    mode = simulator
    # Generator.  Emit LOOP packets as fast as possible (useful for testing).
    #mode = generator
    # The start time. If not specified, the default is to use the present time.
    #start = 2011-01-01 00:00
    # The driver to use:
    driver = weewx.drivers.simulator
#   This section is for uploading data to Internet sites
[StdRESTful]
    [[StationRegistry]]
        # To register this weather station with weewx, set this to true
        register_this_station = false
    [[AWEKAS]]
        # This section is for configuring posts to AWEKAS.
        # If you wish to do this, set the option 'enable' to true,
        # and specify a username and password.
        enable = false
        username = XXX obfuscated by wee_debug XXX
        password = XXX obfuscated by wee_debug XXX
    [[CWOP]]
        # This section is for configuring posts to CWOP.
        # and specify the station ID (e.g., CW1234).
        enable = false
        station = XXX obfuscated by wee_debug XXX
    # If this is an APRS (radio amateur) station, uncomment
    # the following and replace with a passcode (e.g., 12345).
    #passcode = replace_me (APRS stations only)
    [[PWSweather]]
        # This section is for configuring posts to PWSweather.com.
        # and specify a station and password.
        enable = false
    [[WOW]]
        # This section is for configuring posts to WOW.
        enable = false
    [[Wunderground]]
        # This section is for configuring posts to the Weather Underground.
        # and specify a station (e.g., 'KORHOODR3') and password.
        enable = false
        # Set the following to True to have weewx use the WU "Rapidfire"
        # protocol. Not all hardware can support it. See the User's Guide.
        rapidfire = False
#   This section specifies what reports, using which skins, to generate.
[StdReport]
    # Where the skins reside, relative to WEEWX_ROOT
    SKIN_ROOT = skins
    # Where the generated reports should go, relative to WEEWX_ROOT
    HTML_ROOT = public_html
    # The database binding indicates which data should be used in reports.
    data_binding = wx_binding
    # Each of the following subsections defines a report that will be run.
    [[StandardReport]]
        # See the customizing guide to change the units, plot types and line
        # colors, modify the fonts, display additional sensor data, and other
        # customizations. Many of those changes can be made here by overriding
        # parameters, or by modifying templates within the skin itself.
        # The StandardReport uses the 'Standard' skin, which contains the
        # images, templates and plots for the report.
        skin = Standard
        [[[Units]]]
            [[[[Groups]]]]
                group_altitude = meter
                group_speed2 = meter_per_second2
                group_pressure = mbar
                group_rain = mm
                group_rainrate = mm_per_hour
                group_temperature = degree_C
                group_degree_day = degree_C_day
                group_speed = meter_per_second
    [[FTP]]
        # FTP'ing the results to a webserver is treated as just another report,
        # albeit one with an unusual report generator!
        skin = Ftp
        # If you wish to use FTP, uncomment and fill out the next four lines.
        #user = replace with the ftp username
        #password = replace with the ftp password
        #server = replace with the ftp server name, e.g, www.threefools.org
        #path = replace with the ftp destination directory (e.g., /weather)
        # Set to True for a secure FTP (SFTP) connection. Not all servers
        # support this.
        secure_ftp = False
        # To upload files from something other than what HTML_ROOT is set
        # to above, specify a different HTML_ROOT here.
        #HTML_ROOT = public_html
        # Most FTP servers use port 21
        port = 21
        # Set to 1 to use passive mode, zero for active mode
        passive = 1
    [[RSYNC]]
        # rsync'ing to a webserver is treated as just another report
        skin = Rsync
        # If you wish to use rsync, you must configure passwordless ssh using
        # public/private key authentication from the user account that weewx
        # runs as to the user account on the remote machine where the files
        # will be copied.
        # The following three lines determine where files will be sent.
        #server = replace with the rsync server name, e.g, www.threefools.org
        #path = replace with the rsync destination directory (e.g., /weather)
        #user = replace with the rsync username
        # Rsync can be configured to remove files from the remote server if
        # they don't exist under HTML_ROOT locally. USE WITH CAUTION: if you
        # make a mistake in the remote path, you could could unintentionally
        # cause unrelated files to be deleted. Set to 1 to enable remote file
        # deletion, zero to allow files to accumulate remotely.
        delete = 0
#   This service acts as a filter, converting the unit system coming from
#   the hardware to a unit system in the database.
[StdConvert]
    # The target_unit affects only the unit system in the database. Once
    # chosen it cannot be changed without converting the entire database.
    # Modification of target_unit after starting weewx will result in
    # corrupt data - the database will contain a mix of US and METRIC data.
    # The value of target_unit does not affect the unit system for
    # reporting - reports can display US, Metric, or any combination of units.
    # In most cases, target_unit should be left as the default: US
    # In particular, those migrating from a standard wview installation
    # should use US since that is what the wview database contains.
    # DO NOT MODIFY THIS VALUE UNLESS YOU KNOW WHAT YOU ARE DOING!
    target_unit = METRIC    # Options are 'US', 'METRICWX', or 'METRIC'
#   This section can adjust data using calibration expressions.
[StdCalibrate]
    [[Corrections]]
        # For each type, an arbitrary calibration expression can be given.
        # It should be in the units defined in the StdConvert section.
        # Example:
        foo = foo + 0.2
#   This section is for quality control checks. If units are not specified,
#   values must be in the units defined in the StdConvert section.
[StdQC]
    [[MinMax]]
        barometer = 26, 32.5, inHg
        outTemp = -40, 120, degree_F
        inTemp = 10, 120, degree_F
        outHumidity = 0, 100
        inHumidity = 0, 100
        windSpeed = 0, 120, mile_per_hour
        pressure = 24, 34.5, inHg
#   This section controls the origin of derived values.
[StdWXCalculate]
    # Derived quantities are calculated by this service. Possible values are:
    #  hardware        - use the value provided by hardware
    #  software        - use the value calculated by weewx
    #  prefer_hardware - use value provide by hardware if available,
    #                      otherwise use value calculated by weewx
    pressure = prefer_hardware
    barometer = prefer_hardware
    altimeter = prefer_hardware
    windchill = prefer_hardware
    heatindex = prefer_hardware
    dewpoint = prefer_hardware
    inDewpoint = prefer_hardware
    rainRate = prefer_hardware
#   For hardware that supports it, this section controls how often the
#   onboard clock gets updated.
[StdTimeSynch]
    # How often to check the weather station clock for drift (in seconds)
    clock_check = 14400
    # How much it can drift before we will correct it (in seconds)
    max_drift = 5
#   This section is for configuring the archive service.
[StdArchive]
    # If the station hardware supports data logging then the archive interval
    # will be downloaded from the station. Otherwise, specify it (in seconds).
    archive_interval = 300
    # How long to wait (in seconds) before processing new archive data. Must
    # be greater than zero.
    archive_delay = 15
    # If possible, new archive records are downloaded from the station
    # hardware. If the hardware does not support this, then new archive
    # records will be generated in software.
    # Set the following to "software" to force software record generation.
    record_generation = hardware
    # Whether to include LOOP data in hi/low statistics
    loop_hilo = True
    # The data binding used to save archive records
#   This section binds a data store to a database.
[DataBindings]
    [[wx_binding]]
        # The database must match one of the sections in [Databases].
        # This is likely to be the only option you would want to change.
        database = archive_sqlite
        # The name of the table within the database
        table_name = archive
        # The manager handles aggregation of data for historical summaries
        manager = weewx.wxmanager.WXDaySummaryManager
        # The schema defines the structure of the database.
        # It is *only* used when the database is created.
        schema = schemas.wview.schema
#   This section defines various databases.
[Databases]
    # A SQLite database is simply a single file
    [[archive_sqlite]]
        database_type = SQLite
        database_name = weewx.sdb
    # MySQL
    [[archive_mysql]]
        database_type = MySQL
#   This section defines defaults for the different types of databases.
[DatabaseTypes]
    # Defaults for SQLite databases
    [[SQLite]]
        driver = weedb.sqlite
        # Directory in which the database files are located
        SQLITE_ROOT = /home/weewx/archive
    # Defaults for MySQL databases
    [[MySQL]]
        driver = weedb.mysql
        # The host where the database is located
        host = localhost
        # The user name for logging in to the host
        user = XXX obfuscated by wee_debug XXX
        # The password for the user name
#   This section configures the internal weewx engine.
[Engine]
    [[Services]]
        # This section specifies the services that should be run. They are
        # grouped by type, and the order of services within each group
        # determines the order in which the services will be run.
        prep_services = weewx.engine.StdTimeSynch
        data_services = ,
        process_services = weewx.engine.StdConvert, weewx.engine.StdCalibrate, weewx.engine.StdQC, weewx.wxservices.StdWXCalculate
        archive_services = weewx.engine.StdArchive
        restful_services = weewx.restx.StdStationRegistry, weewx.restx.StdWunderground, weewx.restx.StdPWSweather, weewx.restx.StdCWOP, weewx.restx.StdWOW, weewx.restx.StdAWEKAS
        report_services = weewx.engine.StdPrint, weewx.engine.StdReport
[SDR]
    # The driver to use
    driver = user.sdr
# Options for extension 'owfs'
[OWFS]
    interface = u
    driver = user.owfs
    [[sensor_type]]
    [[sensor_map]]
wee_debug report successfully generated
Offline atari
Re: Sdr
« Reply #1 on: July 05, 2016, 01:32:30 PM »
i get replay from autor, driver is not finished...
i find other driver for sdr for pi
h**ps://github.com/jcarduino/weewx_rtl_433
i changed code
Process: 2016-07-06 10:41:22,AlectoV1 Temperature Sensor,171,1,OK,32.900,39,,,,
Detected AlectoV1 Temperature Sensor
Updated: outTemp: 32.900
Updated: outHumid: 39
Process: 2016-07-06 10:41:37,AlectoV1 Rain Sensor,13,0,OK,,,4.250,,,
Detected Rain sensor
Updated: Rainvalue: 4.250
Process: 2016-07-06 10:41:53,AlectoV1 Wind Sensor,171,1,OK,,,,0.000,0.200,90
Process: 2016-07-06 10:42:15,AlectoV1 Rain Sensor,13,0,OK,,,4.250,,,
Process: 2016-07-06 10:42:24,AlectoV1 Wind Sensor,171,1,OK,,,,0.000,0.000,90
Process: 2016-07-06 10:42:51,AlectoV1 Rain Sensor,13,0,OK,,,4.250,,,
Process: 2016-07-06 10:42:55,AlectoV1 Wind Sensor,171,1,OK,,,,0.000,0.000,90
Updated: rain 4.250 - 4.250 = 0.0
Missed sensors: barometer outHumidity pressure altimeter
Open exportfile: /var/tmp/wxdata
Date=1467794583
usUnits=17
windDir=90
outTemp=32.900
windSpeed=0.000
outHumid=39
windGust=0.000
rain=0.0
Close file: /var/tmp/wxdata
root@ubuntu1404:/home/weewx# PYTHONPATH=bin python bin/user/fileparse.py
2016-07-06 12:21:26 CEST (1467800486) {'outHumid': 31.0, 'rain': 0.0, 'dateTime': 1467800486, 'windDir': 45.0, 'outTemp': 34.9, 'windSpeed': 0.2, 'windGust': 0.2, 'Date': 1467800274.0, 'usUnits': 17.0}
2016-07-06 12:21:28 CEST (1467800488) {'outHumid': 31.0, 'rain': 0.0, 'dateTime': 1467800488, 'windDir': 45.0, 'outTemp': 34.9, 'windSpeed': 0.2, 'windGust': 0.2, 'Date': 1467800274.0, 'usUnits': 17.0}
2016-07-06 12:21:31 CEST (1467800491) {'outHumid': 31.0, 'rain': 0.0, 'dateTime': 1467800491, 'windDir': 45.0, 'outTemp': 34.9, 'windSpeed': 0.2, 'windGust': 0.2, 'Date': 1467800274.0, 'usUnits': 17.0}
2016-07-06 12:21:33 CEST (1467800493) {'outHumid': 31.0, 'rain': 0.0, 'dateTime': 1467800493, 'windDir': 45.0, 'outTemp': 34.9, 'windSpeed': 0.2, 'windGust': 0.2, 'Date': 1467800274.0, 'usUnits': 17.0}
but when i run weewx:
:/home/weewx# ./bin/weewxd weewx.conf
LOOP:   2016-07-07 01:28:18 CEST (1467847698) altimeter: None, appTemp: None, barometer: None, cloudbase: None, dateTime: 1467847698, dewpoint: None, heatindex: None, humidex: None, inDewpoint: None, maxSolarRad: None, rainRate: 0, usUnits: 1, windchill: None
LOOP:   2016-07-07 01:28:28 CEST (1467847708) altimeter: None, appTemp: None, barometer: None, cloudbase: None, dateTime: 1467847708, dewpoint: None, heatindex: None, humidex: None, inDewpoint: None, maxSolarRad: None, rainRate: 0, usUnits: 1, windchill: None
LOOP:   2016-07-07 01:28:38 CEST (1467847718) altimeter: None, appTemp: None, barometer: None, cloudbase: None, dateTime: 1467847718, dewpoint: None, heatindex: None, humidex: None, inDewpoint: None, maxSolarRad: None, rainRate: 0, usUnits: 1, windchill: None
LOOP:   2016-07-07 01:28:48 CEST (1467847728) altimeter: None, appTemp: None, barometer: None, cloudbase: None, dateTime: 1467847728, dewpoint: None, heatindex: None, humidex: None, inDewpoint: None, maxSolarRad: None, rainRate: 0, usUnits: 1, windchill: None
LOOP:   2016-07-07 01:28:58 CEST (1467847738) altimeter: None, appTemp: None, barometer: None, cloudbase: None, dateTime: 1467847738, dewpoint: None, heatindex: None, humidex: None, inDewpoint: None, maxSolarRad: None, rainRate: 0, usUnits: 1, windchill: None
i dont get any data
any help?
« Last Edit: July 06, 2016, 07:30:07 PM by atari »
Offline tibasoft
Re: Sdr
« Reply #2 on: September 15, 2016, 05:50:57 PM »
now the driver is finished and work fine.
please put attention to the installation and configuration of packages .
Check the examples on the MATT Github web page.
for info go to google group weewx page:
https://groups.google.com/forum/#!topic/weewx-user/
and search SDR tread.
