Author Topic: CWOP data link on NWS site.  (Read 1540 times)
Offline rcowboy
« on: June 30, 2016, 06:00:26 PM »
So I was doing some poking around on my local NOAA site ("noaa jax" if ya do a google search), and found an interesting link that I haven't seen discussed here. At least not recently. I've always wondered if they actually use our data that we send in. Anyways, when Florida had that tropical storm come through about a month ago, I saw my weather station data actually being used in their rainfall totals for the area. This was the first evidence that I had ever seen sense I've been sending data that they are using what I am sending in, and are announcing it to the public. Which has been a little over a year and a half now.
This web site below is more evidence that they are actually using the data. However, I'm a little surprised that the data is coming from Mesowest, and that they are not using it directly. Anyways thought that you guys might find this interesting. See link below. By the way, the link I posted Is for my area, you can zoom in and out of the map to view you area and you tabulated data.
http://www.wrh.noaa.gov/map/?&zoom=7&scroll_zoom=true&center=30.0976,-84.2651&basemap=ESRI%20Imagery&boundaries=false,true,false&hazard=true&hazard_type=severe&hazard_opacity=60&obs=true&obs_type=tempcur&obs_popup=false&obs_density=2
rcowboy
« Last Edit: June 30, 2016, 06:03:20 PM by rcowboy »
Offline hankster
    • NFM Weather
Re: CWOP data link on NWS site.
« Reply #1 on: June 30, 2016, 06:25:54 PM »
Interesting. The data from my station is also on the map.
Offline Otis
  • (aka Paul)
    • Lake Huron Weather
« Reply #2 on: June 30, 2016, 09:57:43 PM »
Mine also. Is interesting.
Davis Vantage Pro2, Serial Data Logger
WD 10.37S-(b60), VWS V15.00p03, Weatherlink 6.0.3,  Fling 2.35, Broadwave 2.0, Win 7 Pro 64Bit
KMICHEBO10 - CW3699 - Cheboygan, MI
Offline lrosenman
    • Siena Weather
« Reply #3 on: June 30, 2016, 10:36:11 PM »
As is mine.
http://mesowest.utah.edu/cgi-bin/droman/meso_base.cgi?stn=
and put your station id (the 5 character version) in the stn parameter for some interesting info.
Offline hankster
    • NFM Weather
« Reply #4 on: June 30, 2016, 11:32:05 PM »
As is mine.
Some cool graphs there.
« Reply #5 on: July 01, 2016, 05:35:52 AM »
Somebody on this forum put up a link to that site quite some time ago, so it has been around a while.
Still, it is a great site and I use it a lot.
