Author Topic: NSDisplay 2013 and .Net Framework  (Read 1834 times)
Offline virusdunil
    • Station Meteo Hebertville
« on: May 31, 2016, 08:58:55 AM »
Hi all...
im having an issue when running NSBackend.A pop up window related to microsoft.net Framework
at the end of the message box it says...
When the just-in- time debugging is enabled , any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.(google translate)
im on win10 and the problem began this spring
does some of you knows this issue ?
thanks
Cabled Vantage pro2 + Solar / Stevensen screen
Weather Display latest version + Boltek PCI-NexStorm-StormVue NGX / NSDisplay
http://www.meteolacstjean.com/weather28/index.php
Meteotemplate : http://www.meteolacstjean.com/hebert/index.php
Offline virusdunil
Re: NSDisplay 2013 and .Net Framework
« Reply #1 on: May 31, 2016, 12:31:48 PM »
Looks like its fixed...
I originally installed ndsdisplay in /my documents ... later on i did some cleanup and moved the folder to/my documents/original template .
Ive re moved the folder to /my documents and no errors since then  ;)
Offline virusdunil
« Reply #2 on: June 04, 2016, 06:37:12 PM »
well...its not
i had a problem to with .net framework shutting down NGX data server due to Weather Display trying to get data from the IPC commands.I had the graphs enabled to show on the WD"s main screen along with wind direction
But this part is solved and data server is running as it should  :grin:
but the .net framework JIT persists and cant find the file where to apply the fix...
if someone knows,please share ;)
