Author Topic: Designing and building my own weather station, notes and discussion  (Read 4450 times)
Offline SLOweather
    • Weatherelement Moline IL
Well, the copper weather vane has morphed now into as much of a "steam-punk" weather station as I can muster. As you probably have read elsewhere, I have the weather vane and anemometer built, and the anny actually measuring wind speed. I'm still cogitating on the mechanics of how to read the weather vane position. I've chosen a rather obscure industrial automation controller, because I have lots of parts, it makes me a better programmer for our water company, and because I think it will add to the ultimate steam-punkishness of the final project.
The choice of the controller limits my inputs to discrete switches, and 4-20 ma, and 0-5 volt analog signals. I can also have relay and analog outputs as well as a speech board.
For temperature, I've selected LM34s, which produce a voltage output proportional to the temperature in F. It's actually very easy to read, as the voltage in 10s of mv = the temperature in degrees F. (0.75 volts = 75°).
2 of those, a wick and some distilled water, and a small fan make a psychrometer. I can use those temperature values and the barometric pressure to calculate the relative humidity and dew point.
Now I'm on the track of some analog barometric pressure sensors. :)
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
Re: Designing and building my own weather station, notes and discussion
« Reply #1 on: March 07, 2016, 04:55:04 PM »
That is awesome! Care to post some pictures of your fine work?  :-)
Joe Fitzwater
Chief Meteorologist for WVNS-TV 59 in Beckley, WV
Work Page on Facebook -> www.facebook.com/meteojoe
Work Page on Twitter -> https://twitter.com/meteojoe
Waterfalls -> www.wvfalls.com
« Reply #2 on: March 07, 2016, 04:58:55 PM »
There's a ton of aircraft altimeters on sale thru ebay.
Offline SLOweather
« Reply #3 on: March 07, 2016, 06:18:17 PM »
Those all seem to be mechanical. I thought about trying to make one analog. I'm looking for something with a 0-5 volt output at say, 800-1100 hPa/mb.
Climatronics has one that would work, but it's $600.
http://www.climatronics.com/pdf_pn/sensors/102270.pdf
First Sensor has one, for $54 in unit quantities, shipped from Germany:
Offline SLOweather
« Reply #4 on: March 07, 2016, 06:20:54 PM »
There's a thread on the mechanics of the weather vane and "add-a-mometer" here:
http://www.wxforum.net/index.php?topic=27818.0
and more on the anemometer sensing and calibration here:
http://www.wxforum.net/index.php?topic=28573.0
Offline SLOweather
« Reply #5 on: March 22, 2016, 01:48:11 PM »
The work bench was getting too cluttered, so I built a stand to hold the controller, display, fuse block, servo controllers, and the demo servo driven gauges.
Now there's more flat real estate for other work. :)
Offline PaulMy
« Reply #6 on: March 22, 2016, 01:57:12 PM »
Everything except baler twine and duct tape...
Offline Garth Bock
  • Table Rock Lake Weather
« Reply #7 on: March 22, 2016, 02:24:03 PM »
What??? No chewing gum ????
