Author Topic: HELP!!Determine current archive position  (Read 2560 times)
    • Robbinsdale Middle School Weather
« on: February 03, 2016, 10:02:33 PM »
This just popped up. in a window while VVP is connecting.
VVP will not connect to the data logger. I am trying to get either WD or WL to connect to the data logger.
any suggestions?
« Last Edit: February 03, 2016, 10:26:17 PM by chief-david »
Vantage Pro Plus 6163
Re: HELP!!Determine current archive position
« Reply #1 on: February 03, 2016, 10:28:59 PM »
cant get WL to connect to my data logger.
this is not good
Offline CurtisZM
    • CurtisZMWeather
« Reply #2 on: February 06, 2016, 11:23:01 PM »
David,
If you are using USB:
- just checking --Did you shutdown all weather programs and VVP. Just open WL and change in settings the port to the CP210X USB/Serial port number (Device Manager) and see if it will connect?
- Some have had issues with Windows 10 updates affecting the CP201X driver if you are operating Win10
- read this post: http://www.wxforum.net/index.php?topic=27910.25
-Might have to power down the console. Before that... maybe you might want to see what anyone else might have for ideas.
