Author Topic: Some homebrew detector projects  (Read 3739 times)
« on: January 17, 2016, 02:38:30 PM »
Here is a source of some basic homebrew detectors.
http://www.techlib.com/electronics/lightning.html
Re: Some homebrew detector projects
« Reply #1 on: January 17, 2016, 03:01:44 PM »
Not exactly homebrewed, but good:  http://www.hobby-boards.com/store/products.php?product=Lightning-Detector  And decent rpice since Hobby-Boards is going out of business...
Offline waysta
« Reply #2 on: January 17, 2016, 03:03:53 PM »
Wenzel's circuits and projects are very high quality.  Wenzel is a leading designer in field of ultra precise crystal oscillators (retired now, I think).  His hobby instrument designs are mostly analog or mixed signal (with an occasional Microchip 8 pin processor) circa 1980's to 1990's style, but very reliable and relatively easy for a somewhat experienced electronics hobbyist to follow and build.  He still does mostly through-hole designs (parts with leads), so you don't have to struggle with tiny SMT parts and toaster ovens.
« Last Edit: January 17, 2016, 03:06:08 PM by waysta »
« Reply #3 on: January 17, 2016, 03:10:04 PM »
I have been running one of these for many years. It still works great.
A good ground and a Lithium 9V battery is my only advice with this detector. I don't post it online any more due to Blitzortung, etc. but I enjoy watching the "close in" strikes. I use a Linux plotting program and OWW (as a GPC).
Attached is an example of the trend plotter output for a real storm with the H-B detector.
Offline Coolerman
« Reply #4 on: May 11, 2016, 12:26:25 PM »
I ran one of these One Wire Lightning Detectors years ago when they were made as a kit by Point Six in Lexington, KY. Had it connected to an Excel Spreadsheet with OBDC to capture, in real time, the "counts" from the One Wire Counter. I still have that original sensor. Used another of the one wire counters as a rain gauge counter.
Just three weeks ago I bought the updated version of the lightning detector from Hobby Boards (probably the last one since they are now closed!) along with a couple of the DS1820 temp modules so I can do some comparision temp readings...
Davis VP2 Pro Plus w/FARS, CoCoRaHS Station KY-GD-2
