Author Topic: WU GRAPHS very long load time ** SOLVED **  (Read 1488 times)
Offline wvdkuil
  • Wim van der kuil
« on: November 27, 2015, 11:51:38 AM »
The website of Radomir Luza, the programmer of WU GRAPHS  is unreachable.
When using his scripts, the version is checked against his website, which now leads to long delays / time-outs.
Check inside the folder  wxwugraphs (or weather??/wxwugraphs/) the script  WUG-settings.php
Search for (aprrox. line 220) the line which reads:
$updateCheck = true; // if there is a new version, v. info on bottom of th and change tru to false so that it now reads
$updateCheck = false; // if there is a new version, v. info on bottom of th
Wim
« Last Edit: December 05, 2015, 08:09:47 AM by wvdkuil »
Support for Leuven-Template & Scripts  at this forum
Script sponsors support.leuven-template.eu/userlistScripts.php
Template sponsors support.leuven-template.eu/userlist.php
Support for the PWS_Dashboard  pwsdashboard.com
Offline TyArGlaz
    • Météo Daoulas
Re: WU GRAPHS very long load time
« Reply #1 on: December 05, 2015, 07:19:40 AM »
The website of Radomir Luza is online!
Patrice
Météo Daoulas
CWOP : EW7503
WeatherUnderground : IBRETAGN101
French Weather Network
Offline wvdkuil
  • Wim van der kuil
Re: WU GRAPHS very long load time ** SOLVED **
« Reply #2 on: December 05, 2015, 08:09:31 AM »
Very good,  problem solved.
Wim
