Author Topic: Show Off Your VWS Real Estate  (Read 21051 times)
Offline Axelvold
Re: Show Off Your VWS Real Estate
« Reply #25 on: January 01, 2009, 11:23:51 AM »
Here is mine:
Lars Magnusson
Axelvold / Sweden
55 57' 41" N / 13 6' 1" E
Offline Axelvold
« Reply #26 on: January 01, 2009, 01:09:48 PM »
I have a question to MadALwx and sam2004gp, how have you done to get the graph to be colored?
If there is any one else how could answer this question, please do.
Lars Magnusson
Axelvold / Sweden
Offline WeatherBeacon
  • Chief
    • http://www.wxbeacon.com
« Reply #27 on: January 01, 2009, 01:39:03 PM »
Right click on the graph of interest. Then under Plot Style, they probably used Vertical Bar or Base Zero Vertical Bar.
Regards,
Kevin...
Mae govannen!
blackjack52
  • Guest
« Reply #28 on: January 01, 2009, 02:35:33 PM »
WeatherBeacon nailed it....10.0.
For multi-colored graphs like this create the graph using vert bars. Just have to create the graph using the parameter you always want in front.
In the case of this one just right click the graph and change plot color or fill color.
Offline Axelvold
« Reply #29 on: January 01, 2009, 03:35:15 PM »
Thanks for the tip, but i cant get it to work.
But no matter how i change so will it not be like your last image
Lars Magnusson
Axelvold / Sweden
  • Chief
« Reply #30 on: January 01, 2009, 03:46:00 PM »
Right click on the graph of interest. Then under Plot Style, scroll until you reach Vertical Bar or Base Zero Vertical Bar. Then click Close (not the X in the corner).
Regards,
Kevin...
Mae govannen!
Offline Axelvold
« Reply #31 on: January 02, 2009, 12:43:23 PM »
i did do that but i cant get be like those pictures, any ideas why?
Lars Magnusson
Axelvold / Sweden
blackjack52
  • Guest
« Reply #32 on: January 02, 2009, 01:37:50 PM »
What version of VWS are you using?
Offline Axelvold
« Reply #33 on: January 02, 2009, 02:17:33 PM »
I'm using 14.00 p45
Lars Magnusson
Axelvold / Sweden
blackjack52
  • Guest
« Reply #34 on: January 02, 2009, 02:46:02 PM »
Unless your weather system doesn't allow changing the graphs, you should be able to right click on any graph, Meter, tank, etc in VWS to change the various properties of the item.
Offline Axelvold
« Reply #35 on: January 02, 2009, 02:50:29 PM »
i'm ale to change colors and other things but i can't get them like your picture.
Could you take a screenshot on the configuration of that picture?
Lars Magnusson
Axelvold / Sweden
  • Chief
« Reply #36 on: January 02, 2009, 02:53:42 PM »
When you right click on a graph, what options do you see under Plot Style?
Mae govannen!
Offline Axelvold
« Reply #37 on: January 02, 2009, 02:59:11 PM »
This is what i see
Lars Magnusson
Axelvold / Sweden
Offline sam2004gp
  • Mount Crawford, Virginia
  • Weeeeeeeee!!!!
    • Mount Crawford Weather, VA
« Reply #38 on: January 02, 2009, 03:05:42 PM »
Here are my settings to do it in Version 13.  The important things is to get the colors right, and Use "Vertical Bars", also make sure the Grid Color is Transparent or the large "T" that you see as the color.
To get this:
Your settings must be this:
« Last Edit: January 02, 2009, 03:08:30 PM by sam2004gp »
  • Chief
« Reply #39 on: January 02, 2009, 03:10:14 PM »
Lars:
What happens when you click Vertical Bar?
Mae govannen!
Offline Axelvold
« Reply #40 on: January 02, 2009, 03:26:30 PM »
if i use the same settings as Sam, this is the result
Lars Magnusson
Axelvold / Sweden
Offline Axelvold
« Reply #41 on: January 02, 2009, 03:37:42 PM »
No i think i know what the problem is.
I only have weather data from 11:00am yesterday in history (because of a small mistake)
So i think when i get more data the bars will get closer and the picture will be like yours.
Dont you agree?
Lars Magnusson
Axelvold / Sweden
  • Chief
« Reply #42 on: January 02, 2009, 03:37:47 PM »
Hmm. I wonder if there was a change between v.13 and v.14. Your graph looks more like a true bar graph should.
Mae govannen!
Offline Axelvold
« Reply #43 on: January 02, 2009, 03:42:54 PM »
I will get back with the result in a day or so.
And the will we know if this is the case.
Lars Magnusson
Axelvold / Sweden
  • Chief
« Reply #44 on: January 02, 2009, 03:43:41 PM »
Sounds like a plan.
Mae govannen!
Offline wello
  • Welloweather
  • Welloweather
    • Welloweather
« Reply #45 on: January 02, 2009, 04:05:12 PM »
Might also have something to do with the database timer. If you go into Settings, then Database Settings and change the Database Timer to something very small...say 1 or 2 minutes, the bars should close up more.....shouldn't they?  Axelvold, what is your database timer set to?
Peter
www.welloweather.info
OS WMR-200 with V14.01 P22 on Windows Vista
  • Chief
« Reply #46 on: January 02, 2009, 04:14:16 PM »
Ah. Good question. That might explain why some of his graphs (on his website) look somewhat stair-step like.
Mae govannen!
Offline Axelvold
« Reply #47 on: January 02, 2009, 04:19:09 PM »
It's set to 1 h, but i have changed it to 1 min
and as you could see in the picture no change
Lars Magnusson
Axelvold / Sweden
Offline wello
  • Welloweather
  • Welloweather
    • Welloweather
« Reply #48 on: January 02, 2009, 05:05:03 PM »
Maybe you need to let it run for a while at that setting. I'm using V14 P45 and even with my database timer set on 10minutes, I can get the "filled in" graph when I reset it to Vertical Bar (I normally use Thin Line).
Peter
Offline Axelvold
« Reply #49 on: January 02, 2009, 05:18:20 PM »
in the picture setting what have you set the plot previus set to?
Lars Magnusson
Axelvold / Sweden
