Author Topic: improving the the WS1001 (clones) screen layout  (Read 30607 times)
Offline weather34
  • its just my hobby
    • Weather34 meteobridge template
Re: improving the the WS1001 (clones) screen layout
« Reply #175 on: October 05, 2017, 09:56:46 AM »
yarın Cuma olmaz mı? Havya getiririm getiririm ben.
hayir yarin ben çalışma Cuma aksamlar traffik cok problem .. lehim bir demir gerek ..bir hafta problem yok.. iyi aksamlar ben şimdi gitmeliyim .
brian
"It is better to fail in originality than to succeed in imitation."--Herman Melville
https://github.com/lightmaster/Meteobridge-Weather34-Template
Offline sinan0310
« Reply #176 on: October 05, 2017, 09:58:38 AM »
o zaman haftaya Cuma gelirim, anlaştık? Çünkü benim okul var izin alıcam.
WU ID: IISTANBU111
Offline sinan0310
« Reply #177 on: October 07, 2017, 09:56:19 AM »
Cuma okulda sınav var, izin alamadım. Salı ya da Çarşamba olur mu?
WU ID: IISTANBU111
Offline weather34
  • its just my hobby
« Reply #178 on: October 08, 2017, 05:33:08 PM »
merhaba Sinan.. sali aksam problem yok .. 19:30---21:30  tamam..brian
Offline sinan0310
« Reply #179 on: October 09, 2017, 06:36:57 AM »
teşekkürler abi, nasıl haberleşebiliriz yarın? ben metrobüs tüyap sonra mimarsinan gidip yürüyecem sinanoba'ya
WU ID: IISTANBU111
Offline weather34
  • its just my hobby
« Reply #180 on: October 09, 2017, 07:06:23 AM »
cep tel sms yarin sabah taman... tuyap/beylikduzu --> mavi otobus ya da dolmus  --> sinanoba carsi !! sinanoba meydan hacid sayid sol / migros sağ !
5 dakika içinde hacid sayid evinde görüşmek :-)...
brian
Offline sinan0310
« Reply #181 on: October 09, 2017, 07:29:21 AM »
tamam biz yarın çatalca kaymakam ile görüşücez, sonra size geliriz. telefon numaram +905552525354
iyi günler
WU ID: IISTANBU111
Offline weather34
  • its just my hobby
« Reply #182 on: October 09, 2017, 07:30:02 AM »
iyi günler
tamam kolay gelsin..
Offline sinan0310
« Reply #183 on: October 24, 2017, 10:53:17 AM »
Merhaba, when we will meet again on november? Hava istasyonu kontrol bizim ruzgar yönu
WU ID: IISTANBU111
Offline weather34
  • its just my hobby
« Reply #184 on: October 28, 2017, 05:46:12 AM »
gunaydin sinan
kasim sali 10th ya da carsamba 11th problem yok aksam hacid sayid cay :-)  ..tamam
brian
Offline sinan0310
« Reply #185 on: October 31, 2017, 10:15:55 AM »
hocam Kasım 10 Cuma gününe denk geliyor
WU ID: IISTANBU111
Offline weather34
  • its just my hobby
« Reply #186 on: October 31, 2017, 01:01:14 PM »
Pardon ben akılsız  :grin: sali 7th Çarşamba 8th akşam... tamam cuma hayır...
Offline sinan0310
« Reply #187 on: November 02, 2017, 03:11:28 PM »
estağfurullah, twitter yeni resim gönderdim wmr300 :)
WU ID: IISTANBU111
Offline weather34
  • its just my hobby
« Reply #188 on: November 02, 2017, 03:46:10 PM »
Çok iyi Sinan cu bir hafta sonra
Offline sinan0310
« Reply #189 on: November 05, 2017, 04:53:08 AM »
Salı akşam olur mu? Bir de saat kaçta
WU ID: IISTANBU111
Offline mike817
« Reply #190 on: August 19, 2018, 12:13:57 AM »
Sorry to bump an old thread, but can someone reup the theme.zip file?  The current link is dead.
Offline weather34
  • its just my hobby
« Reply #191 on: August 21, 2018, 03:54:50 AM »
hello
its been a very long time since i did anything with this . i can not confirm or even guess if it is useable on latest firmware versions for this model and clones.I no longer own one so it is gone by the layside as I am not able to verify or test with later firmware versions.
you can try at your own risk make note 100% your own risk .whilst the download only contains the necessary image files it does not contain firmware or neither do any of the files in the download write to the firmware .all they are for is replacing the existing images on the console .
do not ask me if you brick your console or have any problems it literally is what it was from over a year ago or more..
download link http://www.mediafire.com/file/6r1voz5qow7s4uf/themes.zip/file
Offline mike817
« Reply #192 on: August 23, 2018, 11:19:07 PM »
Thanks! They worked perfectly.
Offline weather34
  • its just my hobby
« Reply #193 on: August 24, 2018, 04:53:19 AM »
good glad you like it , i was more concerned about you bricking the console so thats a relief ..brian
Offline mike817
« Reply #194 on: August 24, 2018, 11:42:39 AM »
I updated to the latest firmware first, then i copied the theme files over and increments the dot version and the update date and it worked fine.  I don't think they're very complicated devices. It looks like that theme folder is pulling the data directly from storage so there probably isn't that big of a risk of bricking it.
The damn deleteData=false flag was ignored each time though.
Offline weather34
  • its just my hobby
« Reply #195 on: August 24, 2018, 12:07:46 PM »
ok well,good to know not much has changed. i should imagine some of the other branded later models have a similar structure.  if your confident in CS6 photoshop you can use the psd layered version to customize better to your liking .. anyway have fun and i recall when i first did it because my wife complained the original console unit display looked industrial not because i was disliking it but sometimes you have to listen ..have a nice weekend..brian
Offline galou50
« Reply #196 on: October 02, 2018, 02:27:33 AM »
Bonjour
Je voudrais tester ce thème mais le lien ne fonctionne pas,quelqu'un pourrai t'il me l'envoyer?
Merci
Offline weather34
  • its just my hobby
« Reply #197 on: October 02, 2018, 02:59:24 AM »
Offline galou50
« Reply #198 on: October 04, 2018, 04:38:31 AM »
Merci beaucoup
le lien fonctionne,je vais essayer le thème
Bonne journée
Offline zsolt67
« Reply #199 on: February 08, 2019, 02:38:31 AM »
think your asking for this http://www.mediafire.com/file/2dh58bewlhv8kbs/themes.zip/file
Hi is it possible to include graphs in the new theme?
What is the exact method to upload this theme?
