Author Topic: A Different Sunlight Pie Chart in My Saratoga Template and Dashboard  (Read 3899 times)
Offline gwwilk
  • Southeast Lincoln Weather
The sunlight pie chart I was using relies on deprecated Google API's, so I was looking for an alternative display.  Over in the Cumulus forum Mark Crossley and others have created a nice 24 hr. clock-like display that serves admirably.  The script to create the pie chart is called 'heavens.php', a copy of which you can download and save.  I've modified it to save and cache a PNG graphic rather than displaying the pie chart 'in place'.  This pie chart can then be displayed in the menubar and/or the dashboard.  I've copied a legend from a graphic on the Cumulus board and use a mouseover link to display it in my menubar, but I don't have room for it in my dashboard.  The defaults in 'heavens.php' should work for most purposes.  The cache timeout is set at 2 minutes because small changes in the location of the red 'hour-hand' are perceptible.
The code to display the pie chart itself is fairly straightforward, but displaying the difference in daylight from yesterday to today is a little less so.  This code snippet displays both the pie chart image with the legend and the day difference:
<p class="sideBarTitle"><?php langtrans('Sunlight Hours'); ?></p>
    <div class="sideBarText" style="font-weight:lighter; font-size: 6.5pt; text-align: center; margin-bottom:4px; line-height:135%">
          <?php
include("heavens.php");
$hrsOfSunLight = array(); // [0] = yesterday, [1] = today, [2] = tomorrow
$changeinday2 get_changeinday();
#     echo '$changeinday2 = '.$changeinday2.'<br/>'; // Debug Code
           //Make piechart
$timebits explode(":"$hrsOfSunLight[1]); // Today
$testresult $timebits[0] + $timebits[1]/60;
$test1jus=round(($testresult/24)*100,1);
$testmorker=100-$test1jus;
            <span class="thisPage" style="position: relative; font-weight:lighter">
          <?php
           $time_arr
explode(':'$changeinday2);
   $time_arr[0]>0?$cidsign '+'$cidsign ='-';
   if ($time_arr[1]< 5) {
if ($displayYesterday) {
$time_arr2 explode(':'$hrsOfSunLight[0]); // Yesterday
echo (int)$time_arr2[0] . " hrs " . (int)$time_arr2[1] . " min " . (int)$time_arr2[2]." sec";
echo '<br/>Sunlight Yesterday<br/>';
$time_arr explode(':'$hrsOfSunLight[1]); // Today
echo (int)$time_arr[0] . " hrs " . (int)$time_arr[1] . " min " . (int)$time_arr[2]." sec";
            echo
'<br/>of Sunlight Today';
<?php echo '<br/>Which is ';
$time_arr explode(':'$changeinday2);
echo (((int)$time_arr[1]>0)?('<br/>'.(int)$time_arr[1] . ' min '):' ') . $time_arr[2];
echo (substr($time_arr[0],0,1) != "-")?' sec Longer':' sec Shorter'// '-' when getting shorter
echo ('<br/>Than Yesterday');
if ($displayTomorrow) {
$time_arr3 explode(':'$hrsOfSunLight[2]); // Tomorrow
echo (int)$time_arr3[0] . " hrs " . (int)$time_arr3[1] . " min " . (int)$time_arr3[2]." sec";
echo '<br/>Sunlight Tomorrow<br/>';
            </span>
            <span class="thisPage" style="font-size:7px"><br/>(Noon)</span>
            <a style="width:109px" href="<?php echo $sunLightPieLink?>" target="_blank" title="Astronomy Page in New Tab"><img style="width:109px; margin-left:auto; margin-right:auto" src="<?php echo getUniqueImageURL('./cache/heavenpie.png')?>" alt="graph"/></a>
            <span class="thisPage" style="font-size:7px">(Midnight)<br/>
            </span>
            <span class="thisPage" style=" position:relative; font-weight:lighter">
            <a style="cursor:pointer; text-align:center; width:109px" onmouseover="show_legend('legend')" onmouseout="show_legend()">Legend</a><img id="legend" style="display:none" src="./ajax-images/heavensLegend.png" alt="Legend"/>
          </span>
        <?php } else { echo 'Unavailable<br/>&nbsp;'?></span><?php
      </div>
Note that two dependent functions are used in this snippet, 'get_changeinday()' and 'getUniqueImageURL()'.  I have added both of these functions to my 'common.php'.  Here is the code:
// CHANGE IN DAYLENGTH FUNCTION:  computes length of yesterday, today,  & tomorrow
//   and then the change in day length from yesterday to today
// Written by SE Lincoln Weather                                                           .
// Alternate $changeinday routine that finds $changeinday2
function get_changeinday() {
global $hrsOfSunLight;
global $SITE;
global $displayTomorrow;
$t = time()-86400; // Yesterday
for ($i=0; $i<(2+($displayTomorrow?1:0)); $i++) { // Only loop twice if no $displayTomorrow
$sun = date_sun_info($t, $SITE['latitude' ], $SITE["longitude"]);
$srise  = $sun["sunrise"];
$sset  = $sun["sunset"];
$sunhrs[$i] = $sset - $srise;   // $sunhrs is time between sunrise and sunset
$sh[$i] = floor($sunhrs[$i]/3600); // Sun Hours
$sm[$i] = floor((($sunhrs[$i]/3600)-$sh[$i])*60); // Sun Minutes
$ss[$i] = round(((((($sunhrs[$i]/3600)-$sh[$i])*60)-$sm[$i])*60),0); // Sun Seconds
$hrsOfSunLight[$i] = $sh[$i].':'.$sm[$i].':'.$ss[$i]; // Assemble strings in array
$t+=86400; // Next Day
$cindsign = (($sunhrs[1]-$sunhrs[0])>0)?'+':'-'; // Change IN Day sign
$shdiff = ($cindsign=='-'?($sh[0] - $sh[1]):($sh[1] - $sh[0])); // Difference in hours
$smdiff = ($cindsign=='-'?($sm[0] - $sm[1]):($sm[1] - $sm[0])); // Difference in minutes
$ssdiff = ($cindsign=='-'?($ss[0] - $ss[1]):($ss[1] - $ss[0])); // Difference in seconds
if ($ssdiff<0) { // negative number of seconds?
$smdiff -= 1; // borrow
$ssdiff += 60; // and carry
if ($smdiff<0) { // negative number of minutes?
$shdiff -=1; // borrow
$smdiff += 60; // and carry
$changeinday2 = $cindsign.$shdiff.':'.$smdiff.':'.$ssdiff; // Assemble cind string
return $changeinday2;
// end of changeinday()
and
if (!function_exists('getUniqueImageURL')) {
function getUniqueImageURL($image_url){
$timestamp = time();
if(strpos($image_url, '?')){
$image_url = str_replace('?', "?$timestamp&", $image_url);
else{
$image_url .= "?$timestamp";
return $image_url;
This latter function prevents browser image caching of the 'heavenpie.png' image.  I use it liberally on my website so I need to check to see if it has already been declared whenever I want to use it.  Declaring it twice WILL produce a fatal error.
The Legend is available here (right click and 'Save as...').
I have anchored a link to my astronomy page, '$sunLightPieLink', on the sunlight pie chart.  The variable is in my 'Settings.php' as:
$sunLightPieLink = 'wxastronomy_new.php'; // Link to Astronomy Page
Be sure to check this link and point it at your astronomy page.  You can hardcode this link by replacing '$sunLightPieLink' with the relative URL of your astronomy page, but I would recommend using a 'Settings.php' entry for ease of maintenance.
Regards, Jerry Wilkins
gwwilk@inebraska.com
Offline mcrossley
    • Wilmslow Astro
Re: A Different Sunlight Pie Chart in My Saratoga Template and Dashboard
« Reply #1 on: September 30, 2015, 08:53:59 AM »
Did you see the variant I use that also shows sunshine for the day so far? It is on my home page.
Offline gwwilk
« Reply #2 on: September 30, 2015, 09:18:57 AM »
I did see that variant in the thread on Cumulus, but I wasn't aware it lived on your home page, Mark.  The shading had me confused until just now when you elucidated it. :-) There were also other variants of interest such as those with actual numbers on the clock face, but when I tried to implement those using my rudimentary coding skills I wandered down a garden path leading only to frustration.  In the end I settled for the external (Noon) and (Midnight) markers.  There's a lot of code in 'heavens.php' that doesn't get used, but I left it there in case someone wants to repurpose it.
I particularly like the twilight shadings.  Creating a Legend 'on-the-fly' is interesting, but including the time doesn't seem essential.  That's why I copied the Legend graphic from the Cumulus forum, whited out the time, and saved it as a fixed graphic that displays transiently on mousing over the link.  The font quality of my resulting Legend leaves a lot to be desired, but it's not apparent at normal screen resolutions.
Offline jay_hoehn
    • Jay's Woodcrafts
« Reply #3 on: October 01, 2015, 11:51:13 AM »
Jerry,
I have your sunlight pie graphic installed, but can't get the legend to show.  Not sure where I have gone wrong.  Graphic is where it belongs.
http://jayswoodfurniture.com/wx/
Jay
Davis Vantage Pro2 Plus
VVP
Weather Display
Offline gwwilk
« Reply #4 on: October 01, 2015, 12:16:00 PM »
Not your fault, Jay. It's a stupid name-space conflict I created by using "id='legend"'! :oops: In menubar.php try replacing 'legend' with 'spLegend' (this is the simpler method, but verify each change) or use this updated code segment:
          <?php
           //Make piechart
          <?php
           $time_arr
            echo
            </span>
            </span>
            <a style="cursor:pointer; text-align:center; width:109px" onmouseover="showspLegend('spLegend')" onmouseout="showspLegend()">Legend</a><img id="spLegend" style="display:none" src="./images/heavensLegend.png" alt="Legend"/>
          </span>
        <?php
      </div>
with this modified javascript function:
<script language="Javascript" type="text/javascript">
function showspLegend(nam)
   document.getElementById("spLegend").style.display= "none";
   document.getElementById(nam).style.display = "block";
</script>
Sorry about that...
Edit 2015 Oct 1:  I just realized that there's some useless leftover dangling code that the W3C Validator didn't pick up on.  Instead of
          </span>
      </div>
it should read
          </span>
        <?php
      </div>
The code above has been corrected.
« Last Edit: October 01, 2015, 12:36:32 PM by gwwilk »
Offline jay_hoehn
    • Jay's Woodcrafts
« Reply #5 on: October 01, 2015, 12:34:30 PM »
Jerry,
Still no joy.  I copied your code and uploaded.  I had to change the src="./ajax-images/heavensLegend.png" to match where the image is but still not working.
Jay
Hold on.  I did't read farther down in the post.
« Last Edit: October 01, 2015, 12:38:58 PM by jay_hoehn »
VVP
Weather Display
Offline gwwilk
« Reply #6 on: October 01, 2015, 12:39:24 PM »
I think your javascript is still unchanged, Jay.  That's the second snippet I included above.
You've got it now! =D&gt; \:D/ =D&gt;
« Last Edit: October 01, 2015, 12:48:30 PM by gwwilk »
Offline jay_hoehn
    • Jay's Woodcrafts
« Reply #7 on: October 01, 2015, 12:48:14 PM »
Was I supposed to remove some javascript  I couldn't find the old version.
Jay
VVP
Weather Display
Offline gwwilk
« Reply #8 on: October 01, 2015, 12:49:58 PM »
Jay
Well, that's one reason the Legend wouldn't display... :shock:
Looking good now that you've added the necessary javascript.
Offline jay_hoehn
    • Jay's Woodcrafts
« Reply #9 on: October 01, 2015, 12:51:10 PM »
Thanks for the help.  Looks great.
Jay
VVP
Weather Display
Offline 92merc
  • BismarckWeather.net
« Reply #10 on: October 02, 2015, 10:12:01 AM »
I'm not using the menu like everyone else, but I'd like to add the chart to my pages.  Is there a standalone PHP file I can add to my site and include at the appropriate point?
Davis VP2, Cumulus, Blitzortung, Bloomsky, Saratoga Scripts
Offline gwwilk
« Reply #11 on: October 02, 2015, 11:56:43 AM »
Since 'heavens.php' is set up to save the pie chart in the cache directory and with the name of your choice (currently '$pc_cacheFile = './cache/heavenpie.png';'), you can easily create the pie chart.  It must be saved as a PNG graphic, however.  Then all you need to do is add the code to display it somewhere on your page(s).  I would consider adding at least a '(Noon)' at the top of the pie chart and a '(Midnight)' at the bottom as well as adding a Legend.  There is also a size option available in 'heavens.php'.  You could create it fairly large and then display it smaller with '<img src="xxx" width="xx" height="xx">'.
Offline 92merc
« Reply #12 on: October 02, 2015, 12:05:28 PM »
But then how do I get all the text added around the chart like you have?  Plus, what is going to trigger the heavens.php file to update the pie chart?
Offline gwwilk
« Reply #13 on: October 02, 2015, 02:06:37 PM »
This script illustrates how to create and display the pie chart in a table.  Here is the script.  Right-click on the source, click 'Save as...', and save without the '.txt'.
You will need to set up the defaults in 'heavens.php', and you may get a few 'headers-already-sent' errors if you're using a 'Settings.php' file.  The pie chart is updated whenever the calling script is loaded unless the image in cache hasn't expired.  The 'heavens.php' currently on my site doesn't look for a 'Settings.php' but requires your long. and lat. to be entered.
« Last Edit: October 02, 2015, 02:13:14 PM by gwwilk »
Offline 92merc
« Reply #14 on: October 02, 2015, 02:15:41 PM »
I'm close now.  http://www.bismarckweather.net/light.php
How do I add the legend to that page?
Offline 92merc
« Reply #15 on: October 02, 2015, 02:16:38 PM »
And the other text like you have.
"Sunlight:
11 hrs 41 min
45 sec
of Sunlight Today (Noon)"
Offline gwwilk
« Reply #16 on: October 02, 2015, 04:14:33 PM »
"Sunlight:
11 hrs 41 min
45 sec
That's more complicated.  Download my 'menubar.php' and look at the code under 'Sunlight Hours'.
Here is the relevant code from my menubar:
<p class="sideBarTitle"><?php langtrans('Local Sunlight Hours'); ?></p>
          <?php
# include("heavens.php");
$theChanges get_changeinday();
$changeinday2 $theChanges[0];
$hrsOfSunLight $theChanges[1];
# $changeinday2 = get_changeinday();
           //Make piechart
          <?php
           $time_arr
            echo
            </span>
            <div id="PieChart">
            <?php
include ("heavens.php");
            <table style="width:105px">
              <tr style="text-align:center; font-size:7px">
                <td style="vertical-align:bottom">
                  <span class="thisPage">(Noon)</span>
                </td>
              </tr>
              <tr>
                <td style="text-align:left; vertical-align:middle">
                  <a href="<?php echo $sunLightPieLink?>" target="_blank" title="Astronomy Page in New Tab"><img src="<?php echo getUniqueImageURL('./cache/heavenpie.png')?>" height="100" width="100" id="sunPie" alt="Day-Night Graphic"/></a>
                </td>
              </tr>
                <td style="vertical-align:top">
                  <span class="thisPage">(Midnight)</span>
                </td>
              </tr>
            </table>
            </div>
            <span class="ajax" id="pieChartreLoader">
            <script type="text/javascript"><!--
            //<![CDATA[
var jq = jQuery.noConflict();
              function reloadPieChart() {
// if (ajaxUpdates < update.maxupdates) { // Stop and start updating with ajaxUpdates
                jq("#PieChart").load("menubar.php" + " #PieChart");
//} // Omitted 4/25/16 to allow continuous processing
                setTimeout('reloadPieChart()',120000);
            </script>
            </span>
            <a style="cursor:pointer; text-align:center; width:109px" onmouseover="showspLegend('block')" onmouseout="showspLegend('none')">Legend</a><img id="spLegend" style="display:none" src="./images/heavensLegend.png" alt="Legend"/>
          </span>
        <?php
      </div>
  You can find any functions you need near the end of my 'common.php'.
Here is the get_changeinday() function I placed at the bottom of my Saratoga Template's 'common.php':
// The following functions were added by SE Lincoln Weather as part of ajax-dashboard69x
if (!function_exists('get_changeinday')) { // Avoid fatally re-declaring this!!!
global $SITE;
$result = array($changeinday2,$hrsOfSunLight);
return $result;
« Last Edit: March 19, 2019, 04:30:33 PM by gwwilk »
Offline gwwilk
« Reply #17 on: October 02, 2015, 04:23:17 PM »
Heavenpie-test now includes a jQuery function to refresh the pie chart at the desired intervals.  It's currently set up to use 15 second intervals for demo purposes.  The two occurrences of '15000' should be changed to however many milliseconds you want between refreshes, e.g. '120000' for two minutes, etc.  To use this place the pie chart in its own <div id="PieChart">...</div> and it should reload as desired.  This version supplants the previous one.
Be aware that because the image is cached, setting a refresh interval less than the cache interval will just reload a stale image until the cached image expires.
I've now included an example of how to use the auto-refreshing version in my 'menubar.php'.
« Last Edit: October 02, 2015, 07:06:44 PM by gwwilk »
Offline btrip
    • South West Weather
« Reply #18 on: October 13, 2015, 06:41:01 PM »
Hi I have added the Heaven Pie chart to my dashboard http://southwestweather.com/wx/wxindex.php
Thanks for the script
BTrip
B.Trip
DavisVP2/ Envoy Wireless, 2011 Mac Mini Server
High Sierra 10.12.6 2.3ghz Quad-Core Intel Core i7 16GB Ram
Arizona
Offline gwwilk
« Reply #19 on: October 13, 2015, 07:23:31 PM »
BTrip
Good work!  Looks good.  Fortunately you have room for the Legend without which the 'heavenpie.png' could be hard to interpret.
Offline gwwilk
« Reply #20 on: October 14, 2015, 01:11:37 PM »
I've found a way to include the 'heavenpie.png' Legend, 'heavensLegend.png', in my dashboard while still maintaining the table width.  It's a bit of a stretch, but it uses CSS to magnify the Legend with 'mouseover':
  • Make sure jQuery is loaded somewhere in your <head> before </head>.  Mine occurs in my 'menubar.php':
<script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/jquery/1.11.3/jquery.min.js"></script>
  • Next I added the necessary <style> to my 'index.php' just before '</head>':
<style type="text/css">
.img-zoom {
position:relative;
z-index: 1;
cursor:auto;
.transition {
position:relative;
z-index: 999;
  transform: scale(2);
cursor:crosshair;
</style>
  • Then I added this at the end of my 'ajax-dashboard6.php':
var j = jQuery.noConflict();
  j(document).ready(function(){
    j('.img-zoom').hover(function() {
        j(this).addClass('transition');
    }, function() {
        j(this).removeClass('transition');
</script>
  • Then I added this switch to 'AltAjaxDashboardConfig6.php' just below '$useSunlightPie':
$showSLPLegend = true; // Show the Sunlight Pie Legend
  • Finally I also added this code to my 'ajax-dashboard6.php' (in context):
            <span class="thisPage" style="font-size:7px; line-height:130%">(Noon)</span>
            <a href="<?php echo $sunLightPieLink?>" target="_blank" title="Astronomy Page in New Tab"><img style="width:80px; margin-left:auto; margin-right:auto" src="<?php echo getUniqueImageURL('./cache/heavenpie.png')?>" alt="graph" width="80px" height="80px" id="HeavenPie"/></a>
            <span class="thisPage" style="font-size:7px; line-height:130%">(Midnight)<br/></span>
            <?php if ($showSLPLegend) { ?>
<img class="img-zoom" src="./images/heavensLegend.png" alt="Legend" width="80px" height="52px"/><br/>
              <?php ?>
    You can see the result on my home page by mousing over the small Sunlight Pie Legend.
    Offline Breezy
    • Indian Trail Weather
    « Reply #21 on: September 23, 2017, 08:51:06 AM »
    Hello Jerry,
    Great script!  =D&gt; I would like to setup your "sunlight pie chart" in my dashboard (Alt. 6.92) but I'm having a bit of difficulty following all of the instructions in this topic. At your convenience, would you please "list" the required scripting steps necessary to install? Most appreciated  :!:
    Best regards,
    Jeff
    Jeff
    W7-64, Intel Z170A 16 GB RAM
    Offline gwwilk
    « Reply #22 on: September 23, 2017, 09:01:55 AM »
    Hello Jerry,
    Best regards,
    Jeff
    See PM, Jeff.
    Offline spweather
      • Sand Point Weather
    « Reply #23 on: September 23, 2017, 11:36:35 AM »
    I would be interested in this also.
    Jerry, could you please provide me the steps also.
    Dennis
    Regards,
    Dennis
    Davis Wireless Vantage Pro2 Plus w/24hr FARS, Boltek/NexStorm/StormVue NGX/MicroLDN TOA, Porcupine Labs LR4/Fluke 414D Laser Rangefinder for measuring snow depth, WL, WD
    Offline Breezy
    « Reply #24 on: September 23, 2017, 12:22:08 PM »
    Dennis,
    I'm trying to install the script following the notes in Jerry's thread as included here. I'll post to this thread as I make progress. Testing will be conducted at
    http://indiantrailweather.com/indextest.php
    Jeff
    Jeff
