Author Topic: VVP 1.2.5 - Cumulus keeps trying to wake up the console  (Read 1360 times)
Offline CurtisZM
    • CurtisZMWeather
« on: August 16, 2015, 02:53:56 PM »
To all,
 I just installed VVP 1.2.5 and all is working except for Cumulus 1.9.4(Which I had to shutdown). In the VVP activity log Cumulus's keeps trying to wake up the console. This causes Weather Display eventually to stop receiving data. Any ideas?
-My Davis VP2 is connected via USB with the Davis CP210X USB Driver.
-Com Driver for VVP I used: com0com-3.0.0.0-i386-and-x64-unsigned.
-I'm using the Virtual Console TCP/IP Settings to connect WD, VP LIve and Weatherlink.
Offline Beaudog
Re: VVP 1.2.5 - Cumulus keeps trying to wake up the console
« Reply #1 on: August 16, 2015, 07:19:15 PM »
Your setup is not clear to me. Could you post a screen shot of the setup page including cumulus.
Do you have protect console checked?    You do understand that VVP does not support loop 2.
Offline CurtisZM
    • CurtisZMWeather
« Reply #2 on: August 16, 2015, 08:14:35 PM »
Beaudog,
 I'm sorry but you will need to explain loop 2. This is new to me.
 Before I disabled Cumulus, I had protect console checked. Here are my attachments. Thank you for replying.
Offline CurtisZM
    • CurtisZMWeather
« Reply #3 on: August 16, 2015, 08:34:05 PM »
Beaudog,
 Understand Loop 2 now. Sorry. #-o ](*,)
 Funny thing is WD, WL and VP Live are working.
I'm seeing in the Activity log: Weather Display: Socket error: Socket descriptor is[1]not a socket, or [2] is of wrong type (10038).
 Should I be using the 1.2.4 VVP from tinplate?
Offline CurtisZM
    • CurtisZMWeather
« Reply #4 on: August 18, 2015, 10:02:08 PM »
 To All,
 My thanks to SteveFitz1 for his assistance. Everything is up and running.
 Cumulus is using COM6 VVP with Virtual Serial Port Emulator
 WD, WL and VP Live is using TCP/IP VVP. All is a little overboard but what the heck!! I'm a geek... :shock:
 I would also like to thank Beaudog for responding also.
