Author Topic: Saratoga template question  (Read 2510 times)
Offline xcom
    • Texas Weather
« on: August 13, 2015, 02:17:00 PM »
Is it possible to have this page in stand alone?
http://saratoga-weather.org/NA-lightning.php
I am part of the Blitzortung network :)
TIA!
Davis Vantage Vue|Meteohub 5.0l (Build 7293) Running on Debian 7.9 x86 (oVirt)|WU KTXSPRIN75/PWS JRARGWX75/CWOP EW2972/WBB TXWDVUE75/Blitzortung ID: 1142|AWEKAS: 12095
Re: Saratoga template question
« Reply #1 on: August 13, 2015, 05:27:02 PM »
Sure, the script (gen-BO-maps.php) simply generates animated GIFs which can be used anywhere.
If you want to have the rest of the text from my page, here it is
<div id="main">
  <h1 id="pageName">Blitzortung Lightning</h1>
  <div class="story">
  <?php
if(file_exists('./BOmap/cache/BONorthAmerica-ani.gif')) {
 $fn './BOmap/cache/BONorthAmerica-ani.gif';
 } else {
 $fn './BOmap/cache/BONorthAmerica.png';
 if(file_exists('./BOmap/cache/BONorthAmerica-map.html')) {
 include('./BOmap/cache/BONorthAmerica-map.html');
  <p><img src="<?php echo $fn;?>?<?php echo time(); ?>" alt="Lightning by Blitzortung network stations" title="Lightning by Blitzortung network stations" usemap="#BONorthAmerica"
  width="623" height="454" /></p>
  <p>Lightning Map Courtesy of <a href="http://www.blitzortung.org/Webpages/index.php?lang=en&amp;page_0=30">Blitzortung.org</a> hobbyist lightning detection network.<br/>
Data supplied by Blitzortung network members using their home-built Blitzortung hardware.</p>
<p>The Blitzortung networks members build (from kit parts) the detector which monitors H-field   (and now can do E-field) emissions from lightning strikes, and has a set   of servers in Europe to correlate the Time-Of-Arrival at detectors v.s.   GPS-time and uses that to locate strikes.  There is a great (and somewhat hypnotic) <a href="http://www.blitzortung.org/Webpages/index.php?lang=en&amp;page_0=30">realtime map</a> for North America where you can see real-time strike info, and which stations participated in the location of that strike.  There is a companion site that offers the same data and uses a<a href="http://www.lightningmaps.org/blitzortung/america/index.php?lang=en"> zoomable Google Map</a> for display.</p>
<p>  For those interested in more information about Blitzortung, there is a Blitzortung forum in the US at <a href="http://www.wxforum.net/index.php?board=115.0">WXForum.net</a> and a <a href="http://www.blitzortung.org/Webpages/index.php?lang=en&amp;page=6">public forum</a> .. to access the internal forum, there, you'll need to have a Blitzortung member id. </p>
  </div>
</div><!-- end main -->
Offline xcom
    • Texas Weather
« Reply #2 on: August 13, 2015, 05:49:43 PM »
<div id="main">
  <div class="story">
  <?php
 } else {
  </div>
Ken,
Thank you so much!
Where can I download the script from?
Thanks in advance!
Regards,
« Reply #3 on: August 13, 2015, 06:49:00 PM »
Sent you a PM with the link...
Offline xcom
    • Texas Weather
« Reply #4 on: August 13, 2015, 11:45:30 PM »
Ken,
All up and running but cant figure out why it wont animate, Also Cant seem to get any data when I click on a stations.
Any ideas?
TIA!
Offline xcom
    • Texas Weather
« Reply #5 on: August 14, 2015, 09:30:10 AM »
Ken,
I found the issue but I am not sure how to fix it.
Fatal error: Class 'GIFEncoder' not found in /home/user/path/path/wxbomap/BOmapgen-inc.php on line 962
Any ideas?
Offline xcom
    • Texas Weather
« Reply #6 on: August 14, 2015, 09:44:47 AM »
I got it fixed!
YAY! :D
Offline fpalafox
    • Hermosillo Weather
« Reply #7 on: May 16, 2018, 05:45:39 PM »
Thank you Ken,
Could you share with me where I can get this Saratoga script, please? This is showed at:
Thank you in advance.
Wunderground: ISONORAH5
CWOP: CW2548
AWEKAS: 7184
Blitzortung: 1023 Hermosillo,Mex
www.climason.com
« Reply #8 on: May 16, 2018, 05:52:01 PM »
The script is available, but is only usable if you have a Blitzortung lightning detector operating and sending data to blitzortung.org -- the data the script uses is accessible only using the Blitzortung userid:password .. it's not otherwise available.
Do you have a Blitzortung detector operational?  If so, I'd be pleased to send the script package.
Offline fpalafox
« Reply #9 on: May 16, 2018, 06:24:42 PM »
Thank you Ken,
Yes, I have deployed my Blitzortung station 1023, located in Hermosillo, Mexico.
Thank you.
CWOP: CW2548
AWEKAS: 7184
www.climason.com
« Reply #10 on: May 16, 2018, 06:36:04 PM »
PM sent with instructions.. enjoy!
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #11 on: October 31, 2018, 09:35:55 AM »
Ken, have sent you an email, but just found this thread. is there any possibility I could get the script too? I'm running Saratoga Templates and a Red System too.
« Reply #12 on: October 31, 2018, 10:01:56 AM »
Sure.. PM sent with instructions.. enjoy!
