Author Topic: Chandler Burning Index  (Read 1572 times)
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« on: August 04, 2015, 11:05:36 AM »
I was just experimenting with the Chandler Burning Index, I found the following formula to calculate it:
CBI = (((110 - 1.373*RH) - 0.54 * (10.20 - T)) * (124 * 10^(-0.0142*RH)))/60
RH - humidity in %, T = temp in deg C
in PHP I used:
(((110 - 1.373 * $RH) - 0.54 * (10.20 - $T)) * (124 * pow(10,(-0.0142 * $RH))))/60;
Now the problem is, that when for example I plug in 97% for humidity and 19.4 C for temperature, I get a negative number... and likewise, some numbers lead to CBI way above 100. But the index description says it should lie between 0 and 100. I even checked this by manually calculating it on a calculator and that formula really gives these values.
Is my formula incorrect? Or can the values be negative and above 100?
« Last Edit: August 04, 2015, 11:32:57 AM by Jachym »
Re: Chandler Burning Index
« Reply #1 on: August 05, 2015, 12:58:23 AM »
Yep, we use
$cbi = (((110 - 1.373 * $rh) - 0.54 * (10.20 - $ctemp)) * (124 * pow(10,(-0.0142* $rh ))))/60;
which looks like yours
$cbi = (((110 - 1.373 * $RH) - 0.54 * (10.20 - $T)) * (124 * pow(10,(-0.0142 * $RH))))/60;
And this kind of code summarizes the CBI scale
<?php
         $cbi
= (((110 1.373 $hum) - 0.54 * (10.20 $temp)) * (124 pow(10,(-0.0142 $hum))))/60;
         if (
$cbi "97.5") {
$cbitxt "EXTREME";
         } elseif (
$cbi >="90") {
$cbitxt "VERY HIGH";
         } elseif (
$cbi >= "75") {
$cbitxt "HIGH";
         } elseif (
$cbi >= "50") {
$cbitxt "MODERATE";
         } else
         if (
$cbi "50") {
$cbitxt="LOW";
         echo
"Fire Risk for Today: " $cbitxt
(from here
Offline Jáchym
    • Meteotemplate
« Reply #2 on: August 05, 2015, 04:08:28 AM »
Thanks Ken,
Niko already messaged me about this, the equation is correct. What I didnt know is that the index can really be even negative or above 100, from the scale it seemed as though it should lie between 0 and 100, so I just wasnt sure I got the formula right.
Thanks.
Offline dan43
    • Central Port Coquitlam, BC Weather
« Reply #3 on: January 12, 2017, 12:51:34 AM »
Jachym, sorry for this tardy reply, I just discovered the Chandler Burning Index and wanted to mention mine right now is -1.6, so your formula is probably correct.  I'm not sure if it's relevant to Canada, but I'm experimenting... it's kind of fun to see what numbers are generated each day and to learn what they mean.
Offline Scalphunter
« Reply #4 on: January 12, 2017, 02:08:35 AM »
Yep Jac I go from negative numbers this time of year  to 100 plus  during the summer when we  are at 13 -20% humidity and hitting the high 80's  to mid 90's. yep it gets that warm here with out any night cooling down time.
Offline d_l
  • Slide Mtn - Mt Rose
« Reply #5 on: December 17, 2017, 12:19:36 PM »
If you have a Meteohub, you can do the Chandler Burning Index calculations by a virtual sensor.  Instructions on how to do that are here: http://forum.meteohub.de/viewtopic.php?f=9&t=12243.  What advantage is there to doing this?  Well you can plot a graph of the CBI over time such as I do on this web page (24 hrs in this case): https://www.tceweather.com/firedanger_graph.html  This allows you to get a feel for the trend of the CBI over time and do an eyeball projection estimate of what it might be in the future.  A future estimate of the CBI trend can be useful if a fire in a nearby area is threatening your place.
I modified the regular CBI PHP script to intake a special firedanger text file containing the just the CBI, temp, and hum that the Meteohub can output.  This data is used to generate the regular Smokey the Bear's fire danger graphic display which I've linked to a mouse click on the 24 hr CBI graph. So someone can click back and forth between the graph and the Smokey graphic.
--Dave--
Wireless VP2 w/ solar, 24hr FARS, Heater, (Envoy-WLIP)*3-Meteohub, plus custom VP2 @ 26', WL 6.0.3, WU & W4U=KNVRENO37 NetcamXL
Offline SLOweather
    • http://www.sloweather.com
« Reply #6 on: December 17, 2017, 03:03:09 PM »
I'll have to see if I can find my notes or references, but I believe the CBI is supposed to be clamped or limited to between 0 and 100. Or, I may be wrong. :)
