Author Topic: Meteotemplate - new free website template  (Read 437162 times)
Offline elspinars
  • Meteo Els Pinars - Vallirana
Re: Meteotemplate - new free website template
« Reply #7625 on: December 18, 2017, 09:40:03 AM »
Hi everybody,
I already posted this on the Meteotemplate forum but I thought I would also put it here as some users may not have acces to the official forum (they should register though. Lots of good stuff there).
I live in a town where traffic can get nasty a certain time in the week. The visitors of my website www.elspinars.es often visit it in the morning as a one shop stop to get their daily dosis of meteo, but also requested to have some kind of info about the traffic.
That how I came with the trafficAlert block, which is available for download here : www.elspinars.es/dev/dev.php
Concept is very basic : you define some routes, the block check the time it takes to drive that route and if the time is above certain thresold, it displays an alert, with the possibility to display the current traffic on a map :
I tried to make the setup as user-friendly as possible (but may have failed in the attempt).
After entering an optional block heading, the first step is to add an alert :
Then you define your route name and use the map to define your route.
On the map, a left-click define the center and a right click define the starting and ending point.
The page will update the route and the normal time it takes to drive it. You can then use these values to define your thresolds in the alerts.
You can alernatively enter the values manually and click on the Refresh Map button to see how it looks like.
Then you define your alerts :
For each alert level (Green, Orange, Red), you define the thresold and the message.
You can use tags like %T in your message to display the actual time it takes to drive the route according to Google Maps Directions.
You can also personalize the icon and animate it.
Finally, you can disable an alert level.
When done, click on save, don't forget to add your block on your homepage and you're done.
This is an early version of the block, I would appreciate if you could let me know if you find it useful, if you tried it and if you have any idea on how to improve it.
Next steps will be to allow the users to create their own routes (after registration) and to add notifications in a mobile app on which I am working (also available on my dev page)
You can either comment on this forum post or leave me a message on my contact page
Cheers,
Pol-Brieuc
« Last Edit: December 26, 2017, 06:48:37 PM by elspinars »
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« Reply #7626 on: December 19, 2017, 08:02:57 AM »
Just setting up using this template. Does anyone know what units Weather Display uses for the data that is sent via the API? Also, is there a Weather Flow option for a station? Thanks!
This is fixed, API uses metric units, but they are converted based on your db units setting
Offline Jáchym
    • Meteotemplate
Meteotemplate 17.0 Nectarine
« Reply #7627 on: December 30, 2017, 02:13:27 PM »
Hi guys,
new version of Meteotemplate includes several tweaks and for example a brand new mobile homepage, which uses Bootstrap and is ideal for any device type
more: http://meteotemplate.com/blog/?p=3549
Offline paulIOG
« Reply #7628 on: March 30, 2018, 04:56:35 PM »
Hi
Having some issues..... templates were a breeze to set up btw now i have this issue the templates will not load from my url of http://www.iogweather.org.uk/ but they ll load perfectly from http://www.iogweather.org.uk/template/indexDesktop.php.
Template folder is in public_html folder of server been scratching my head for hours.
Any ideas on how to fix this anyone?
Offline waiukuweather
« Reply #7629 on: March 30, 2018, 05:13:59 PM »
you would need a index.html or index.htm
in your root folder
to at least  have a link to where you template is (or a redirect)
Offline paulIOG
« Reply #7630 on: March 30, 2018, 05:25:26 PM »
I tried putting all the files in the root folder without the 'template' subfolder so index.php etc are there like old site setup it loads but its a mess
Offline paulIOG
« Reply #7631 on: March 30, 2018, 05:58:15 PM »
Put a redirect in for now till i come up with a solution
Offline Johnny 5
  • Just a hobby
    • Watford Weather
« Reply #7632 on: March 30, 2018, 06:08:09 PM »
Hi Paul, in the Meteotemplate Main Setup, go to the section Paths and make sure the URL you have specified is correct. For instance under path I have a forward slash / and under page URL I have http://www.watfordweather.co.uk
Offline paulIOG
« Reply #7633 on: March 30, 2018, 06:22:55 PM »
Just tried no joy  :sad: i ll put the redirect back in for now
thanks for the idea tho
Offline Asobig
    • Weerstation Cartoon
« Reply #7634 on: March 31, 2018, 06:05:23 AM »
For me, your website loads perfectly. :lol:
Some blocks keep spinning, but it shows 'Online'.
Offline paulIOG
« Reply #7635 on: March 31, 2018, 07:17:06 AM »
Thanks should be 2 blocks spinning working on that today. The redirect in place on the server has got this site working for now
Offline Jáchym
    • Meteotemplate
« Reply #7636 on: March 31, 2018, 09:28:43 AM »
Some blocks fail because this function is missing:
gregoriantojd
It is a standard PHP function so it looks like your PHP installation is not complete.
Your page looks nice except for the footer. I would really consider removing all the page counters, they look awful and very amateur
Offline paulIOG
« Reply #7637 on: March 31, 2018, 04:28:20 PM »
gregoriantojd
Took your advice looks much tidier now but still lots to do im not entirely happy yet  also fixed my  gregoriantojd issue by switching to php 7.0 on server
Offline tpweather
  • Firefighter
  • Be patient...I'm a firefighter not a computer whiz
    • Tom Price Weather Centre
« Reply #7638 on: April 13, 2018, 09:51:23 PM »
Hi All
I am trying to import my data using the Import Data function in the template but I get an error saying:
Forbidden
You don't have permission to access /site/admin/testImportFile.php on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
I have made the import files permissions to 777 but still the same issue. Can anyone advise what I need to do please?
Cheers
Chris
Offline kweaver66
  • Kevin Weaver
    • Weaver Estates Wx-Watch
« Reply #7639 on: April 14, 2018, 02:45:27 PM »
Mine only works if I have it at 755
Offline Jáchym
    • Meteotemplate
« Reply #7640 on: April 14, 2018, 05:42:21 PM »
I personally use 650 for folders and 640 for files, but it does not work on all servers, you need to use try/error method
Offline tpweather
  • Firefighter
« Reply #7641 on: April 14, 2018, 07:50:01 PM »
Many thanks guys.
Offline tpweather
  • Firefighter
« Reply #7642 on: April 14, 2018, 09:59:15 PM »
Failing I get the permissions to work, can I do it through myphpadmin?
Offline tpweather
  • Firefighter
« Reply #7643 on: April 15, 2018, 11:38:30 AM »
Turned out to be a modsec rule. All sorted now
Offline Andy Thompson
  • Southern Minnesota Live Weather
  • Madelia and Thompson Farms
« Reply #7644 on: April 29, 2018, 11:42:44 AM »
Good morning,
I have been experiencing high amounts of junk mail coming through my website Contact form. A robot has outsmarted the form by filling it out and sending the messages. About 5 months ago is when I started seeing them. They contain anything from random letters and characters, to advertising. It is quite annoying. I was wondering if the Contact form could be changed? I was thinking of a script that randomly generates a string of numbers and letters instead of simply checking box that says "I am not a robot".
« Last Edit: April 29, 2018, 11:44:43 AM by Andy Thompson »
Regards,
Andy Thompson
www.somnwx.com
Offline Jáchym
    • Meteotemplate
« Reply #7645 on: April 30, 2018, 03:05:43 PM »
I tried that before, math calculations, captcha, Google recaptcha.... sooner or later it stops being effective. I have the same problem in the forum, which uses Google Recaptcha and the PHPBB built-in captcha and even those two together dont work, I have on average 2 fake registrations daily. I usually discover it by googling the email address and finding it in the Spam mail database.
Offline elspinars
« Reply #7646 on: February 13, 2019, 06:16:29 AM »
Hello,
I am trying to build an app (for Android) to access Meteotemplate sites and provide additional features to visitors like notifications :
A beta version is available here : https://play.google.com/apps/testing/com.meteotemplate.meteotemplate
It would help a lot if those brave users who install the app can send me their feedback or bug reports.
Cheers,
Pol-Brieuc
