Author Topic: Meteotemplate - new free website template  (Read 444382 times)
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
Re: Meteotemplate - new free website template
« Reply #6300 on: March 23, 2017, 10:11:28 AM »
Hey there.  I started getting a strange error on my Bloomsky Timelapse Block.  The video is definitely there and the cron is running.  Any ideas?
This looks like an issue with the BS API again
Offline Jáchym
    • Meteotemplate
« Reply #6301 on: March 23, 2017, 10:35:31 AM »
Love lemons!
Updated and all seems well!
LOL.... Im at work now, but I think I should be at home because Im probably sick... I need to do some groceries after work so I will make sure I buy some lemons as well, will be useful now :D
Offline Jáchym
    • Meteotemplate
Meteotemplate - Block Update – Station Status 4.0
« Reply #6302 on: March 23, 2017, 10:36:14 AM »
Hi guys,
added new feature for API users – displays the SW type used for updates.
DEMO: http://www.meteotemplate.com/template/indexBlockDemoNarrow.php?block=stationStatus
Enjoy
Offline weatherbee
    • Sherman Ct. Weather
« Reply #6303 on: March 23, 2017, 11:04:38 AM »
Updated and everything seems to be running fine.  Quick and painless.
Tom
Offline Juan Maria Vilaro
« Reply #6304 on: March 23, 2017, 01:09:45 PM »
Hello, I installed the template 12 and it works almost everything, except that I had installed many plugins and now only some are seen from where they are activated now in the Menu?
Offline jeffm5690
    • Long Island New York Weather
« Reply #6305 on: March 23, 2017, 01:28:56 PM »
Lol.  Thanks!
Offline Jáchym
    • Meteotemplate
« Reply #6306 on: March 23, 2017, 01:49:22 PM »
Hi Juan,
not sure what exactly you mean, there was no change in v12 with the menu. Check your menu setup if all plugins are there and make sure you are using the latest version of menu.php.
Offline Jáchym
    • Meteotemplate
Meteotemplate - Block Update – Database Info 2.0
« Reply #6307 on: March 23, 2017, 02:29:33 PM »
Hi guys,
- added date/time of last update
- major optimization (reduced loading time by 70%)
- CSS tweaks
DEMO: http://www.meteotemplate.com/template/indexBlockDemoNarrow.php?block=dbInfo
Enjoy
Offline jeffm5690
« Reply #6308 on: March 23, 2017, 05:16:50 PM »
SuperFAST update.  Easiest one yet.  Thank you and already excited for the next update!!!
Offline Jáchym
    • Meteotemplate
Meteotemplate - new feature/tips
« Reply #6309 on: March 23, 2017, 07:01:20 PM »
Hi guys,
just like there is lots of blocks there is also lots of languages now, so again to make it easier and better adapted to the current situation, I added a new link in the Translations section “Download All”, which will download all the language files at once as a ZIP file.
Translations: http://www.meteotemplate.com/web/translations/index.php
Make sure you keep these files up-to-date
I have also just posted some version update tips: http://meteotemplate.com/blog/
Enjoy
Offline Jáchym
    • Meteotemplate
Meteotemplate - Block update/new block
« Reply #6310 on: March 24, 2017, 07:45:19 AM »
Hi guys,
Block Update – Current Australia 1.2
- minor bug fixes
- CSS optimization
New Block – Germany – Current Conditions
This new block shows national and regional maps with current conditions and warnings in Germany.
DEMO: http://www.meteotemplate.com/template/indexBlockDemoNarrow.php?block=currentDE
Enjoy
Offline Jáchym
    • Meteotemplate
Meteotemplate - New Block – Dynamic Graph
« Reply #6311 on: March 24, 2017, 10:03:45 AM »
Hi guys,
this new block is finally a real “interactive/dynamic” graph. First you select parameter of choice and the number of data points to preload from db. This will show initally on your page. Then, using the API, it will dynamically be adding points in realtime, so the graph will be sort of “moving forward” as new data is sent by the API script.
In the DEMO I set the interval to 30 seconds and used wind speed, which probably best illustrates how this works because it changes very quickly. Works with both dark and light themes.
DEMO: http://www.meteotemplate.com/template/indexBlockDemoWide.php?block=dynamicGraph
Enjoy
Offline Jáchym
    • Meteotemplate
« Reply #6312 on: March 24, 2017, 02:32:07 PM »
Hi guys
Block Update – Bloomsky Timelapse 1.1
- minor CSS tweaks to ensure proper scaling
Meteotemplate Recommended Software
At the Meteotemplate homepage I added a new section on the left “Recommended Software”. In this section you will find a list of SW, which support the API and thus guarantee you will be able to use Meteotemplate to its full potential, ensuring highly accurate and reliable data and very easy to set up.
This is not a definite list of programs which Meteotemplate supports, but for some features the API is required. If you are using a different means of updating and would like to see the API built-in whatever software you use, then just ask the developer and send them link to the API page in the WIKI and let me know if they are interested so that I can add them to the “Recommended SW” as well.
http://www.meteotemplate.com/web/index.php
Enjoy
Offline kocher
    • San Sebastian (Spain)
« Reply #6313 on: March 24, 2017, 04:34:37 PM »
Greetings Jachym
You maintain your intense activity as always.  =D>
Thanks for your template updates.
I installed Meteotemplate 12.0 Orange.
The block of Dynamic Graph does not work on my page; I have curiously observed that in the php files of that block, the php closing sign "?>" is missing  #-o
   http://kocher.es/meteotemplate/
Saludos desde San Sebastian  :grin:
Javier
« Last Edit: March 24, 2017, 04:38:04 PM by kocher »
Windows 7 Pr
Davis Vantage Pro Plus f.a.
WeatherLink 6.0.2
Meteotemplate 15.0 Black Currant
CumulusMX
GraphWeather Version 3.0.15
Offline Jáchym
    • Meteotemplate
« Reply #6314 on: March 24, 2017, 05:04:42 PM »
Hi Javier,
when a file has no HTML, just PHP, it can be, or in fact it is even preferable to omit the ending ?> tag
See for example: http://stackoverflow.com/questions/3344506/php-closing-tag-unnecessary
And this should not cause any problems at all
Offline waiukuweather
« Reply #6315 on: March 24, 2017, 05:06:25 PM »
the dynamic graphs work OK for me
( I am using Version 13, Lemon)
« Last Edit: March 24, 2017, 05:59:02 PM by waiukuweather »
Offline kocher
« Reply #6316 on: March 24, 2017, 05:08:59 PM »
Hi Javier,
Ok, I did not know  :idea:
« Last Edit: March 24, 2017, 05:14:03 PM by kocher »
Windows 7 Pr
WeatherLink 6.0.2
CumulusMX
Offline Jáchym
    • Meteotemplate
Meteotemplate - Block Update – Forecast 4.2
« Reply #6317 on: March 24, 2017, 05:44:57 PM »
Hi guys,
the MeteoBlue forecast is now localized. Language will be chosen automatically, if you are using “gb” or “us”, or your chosen language is not on the list below, English will be used.
Supported languages in no particular order (except the first one of course 😉
- Czech
- Slovak
- German
- French
- Spanish
- Italian
- Portuguese
- Greek
- Bulgarian
- Serbian
- Polish
- Romanian
- Dutch
- Hungarian
Enjoy
Offline i_fiorentino
  • Davis Vantage Vue, Boltek Stormtr., Mobotix M22-IT
    • Meteopistoia.it
Re: Meteotemplate - New Block – Dynamic Graph
« Reply #6318 on: March 24, 2017, 05:48:08 PM »
Hi guys,
Enjoy
Hi Jachym,
i've just installed dynamic graph block but i've blank page in its space.
Please could you give an eye here: http://www.meteopistoia.it
I've also seen that there isn't rain value as choice on settings menu.....is it possible to add it in the next release?
Regards,
Alessandro
Offline EastFrisianGuy
    • Private Weather Station Bremerhaven
Re: Meteotemplate - Block update/new block
« Reply #6319 on: March 24, 2017, 05:48:32 PM »
Hi guys,
Enjoy
Thanks a lot for the current conditions plugin Jáchym, very useful. :-)
However you made a little typo in the tab for "Niedersachsen/Bremen", Bremen is spelled with just "m".  ;)
Best Regards
Georg
Best Regards
Georg
Offline Jáchym
    • Meteotemplate
« Reply #6320 on: March 24, 2017, 05:56:43 PM »
:D
Block Update - Germany - Current Conditions 1.1
- minor bug fixes...
Enjoy
Offline kocher
« Reply #6321 on: March 24, 2017, 06:34:39 PM »
I could not upgrade to version 13.0 Limón.
The download link to update the template, takes me to:
http://www.meteotemplate.com/web/downloadedTemplate.php
I can not find any files to update  ](*,)
Windows 7 Pr
WeatherLink 6.0.2
CumulusMX
Offline nineback
    • Albertville, AL Weather
« Reply #6322 on: March 24, 2017, 06:37:57 PM »
Davis VP+
Weather Display
http://www.kq5s.com/template/
Offline Jáchym
    • Meteotemplate
« Reply #6323 on: March 24, 2017, 07:00:06 PM »
Javier please try again, just use the downloads page. I just checked the log file and there was too many of you recently so the server was having a hard time serving everyone. Also double check your popup blocker.
Offline kocher
« Reply #6324 on: March 24, 2017, 07:04:03 PM »
Ok Jachym
 Now it worked
Also works the block "Dynamic Graphics"
 thank you very much  :grin:
« Last Edit: March 24, 2017, 07:11:20 PM by kocher »
Windows 7 Pr
WeatherLink 6.0.2
CumulusMX
