Author Topic: 64bit computer, VSPE and Virtual VP  (Read 4734 times)
Offline shirsch
« on: April 08, 2015, 06:50:43 PM »
I am trying to get a Davis Pro 2 to connect to a 64 bit computer using VSPE emulator and Virtual VP. I have been able to do this with a 32 bit computer using VVP and N8VBvCom Driver without a problem
The 64 bit computer does have 2 serial ports and I set VSPE to create a virtual com3 and set VVP to com3 and keep getting "no repsonse after several tries in waking up console"
any ideas???
Steve
Offline Josiah
  • Add-InWx Software Author
    • Add-InWx
Re: 64bit computer, VSPE and Virtual VP
« Reply #1 on: April 08, 2015, 08:06:53 PM »
What type of data logger do you have?
oh and,
why are you trying to use both VSPE and Virtual VP?
Offline Garth Bock
  • Table Rock Lake Weather
« Reply #2 on: April 09, 2015, 09:17:14 AM »
Use Com0com....it works great with a 64 bit system.
Offline SteveFitz1
    • Tyler Texas Weather
« Reply #3 on: April 09, 2015, 10:11:52 AM »
any ideas???
Steve,
I use VSPE and VVP on a 64-bit system and they work flawlessly. On my system, VSPE creates virtual ports com16-com19 and VVP communicates with the 'real' com3 port. Can you post screenshots of your VSPE and VVP configs?
Steve
Offline Breezy
  • Indian Trail Weather
« Reply #4 on: November 26, 2016, 10:54:57 AM »
I just upgraded from a W7-32 bit to a W7-64 bit computer. Just as SteveFitz1 has noted, VSPE and VVP are a good solution. They worked for me without a hitch using my single physical com1. Running Davis WeatherLink and Weather Display simultaneously. A big "Thank You" to Steve for his time and effort in assisting me with this project.  =D>
Jeff
« Last Edit: November 26, 2016, 10:59:01 AM by Breezy »
Jeff
W7-64, Intel Z170A 16 GB RAM
