Garth Bock
« on: November 07, 2008, 02:44:45 PM » |
The university's ISS stopped transmitting. I got maintenance to get it down off the pole for me. I was thinking this was just the dead battery syndrome which it did have. I have it setting here in the office with me for cleaning and testing. Thing is I know the supercap ran down. I was hoping that ambient light from the window would atleast give me a few minutes of transmission during diagnostics. I pull the lithium and transmission stops immediately. I called Davis and they said the ISS won't run with the lithium pulled. Is there a way to test the supercap to find out if it is charging ?
 Davis VPro2,VWS,WF,VVP,WD,WDL,Cumulus,WV32
talbert1952
« Reply #1 on: November 07, 2008, 04:31:33 PM » |
Take the plastic cover off the ISS board and look at the capacitor. If the capacitor has crud growing around the leads you definitely need to replace the capacitor.
Tom W4SNA IRLP 4069 - Echolink W4SNA-R http://tobaccovilleweather.com/Hardware: Davis 6153 wireless VP2 with 24 hr fan aspirated radiation shield, WMR968, Boltek Stormtracker PCI, Hamtronics R139, stacked Woodhouse 6X6 beams on Yaesu G-5500 az/el rotator Software: Weatherlink, VWS, Image Salsa, Lightning/2000, GRLevel3 with Allison House data feed, WxtoImg
Garth Bock
« Reply #2 on: November 07, 2008, 05:05:07 PM » |
Thanks so much ! I want to eliminate it as the real failure of the battery. Davis said the battery would last 8 months so if it failed again it would be in the summer. Not my idea of full diagnostics. Before the snow flies I want to make sure the ISS is fault free. I don't want to send one of our union guys up on the lift in the middle of winter. That wouldn't go over well......
talbert1952
« Reply #3 on: November 08, 2008, 05:33:51 PM » |
If the super capacitor is bad a new CR123 battery will last a few days at best. The bad capacitor kills the battery. You can get a replacement super capacitor from Digikey. http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=589-1002-ND
92merc
BismarckWeather.net
Contributor
Offline
BismarckWeather.net
« Reply #4 on: November 09, 2008, 12:52:39 PM » |
Is that a VP2? Reason I ask is my VP1 has a disc shaped cap instead of the can one. Anyone know where you can get those?
BismarckWeather.net
talbert1952
« Reply #5 on: November 09, 2008, 03:54:11 PM » |
Yes it is a VP2. Does your capacitor have any markings? The value, voltage rating and manufacturer would be very helpful for finding an exact replacement.
Garth Bock
« Reply #6 on: November 10, 2008, 03:01:02 PM » |
Super cap had leaked. Ordered a new one and a new lithium. Thanks for everyone's help !
92merc
BismarckWeather.net
Contributor
Offline
BismarckWeather.net
« Reply #7 on: November 11, 2008, 09:26:02 AM » |
Mine shows 5.5v and 1.0F.
BismarckWeather.net
talbert1952
« Reply #8 on: November 11, 2008, 07:57:00 PM » |
92merc
BismarckWeather.net
Contributor
Offline
BismarckWeather.net
« Reply #9 on: November 12, 2008, 09:15:02 AM » |
Looks like the one for the VP1 is on page 1545, top left. Panasonic SG Series Gold Capacitors. Electric Double Layer Capacitors. Vertical Mount. 5.5V 1F
DigiKey PN P6975-ND Panasonic PN EEC-S5R5V105
$4.82 for one $3.84 in a lot of 10
BismarckWeather.net
