Author Topic: Can't get Internet URL  (Read 1223 times)
« on: September 12, 2014, 04:56:45 PM »
As if there were not enough things... I try to select the "access this device via URL" and the Smartbedded  server says it is too busy or down for maintenance.  Wassup?
Offline docbee
  • Moderator
    • smartbedded
Re: Can't get Internet URL
« Reply #1 on: September 12, 2014, 05:41:34 PM »
Working fine here. Can you please send me the Link you tried? info(at)meteobridge.com
Offline docbee
  • Moderator
    • smartbedded
« Reply #2 on: September 12, 2014, 06:13:14 PM »
Thanks, tried with your link but doesn't work. Message might be a bit misleading, basically it tells that the SSH tunnel has not been setup. So no general problem with the servers out there ;-)
I can't say why tunnel is down from being outside your LAN. Did you had remote access working before?
« Reply #3 on: September 12, 2014, 06:17:30 PM »
Have not tried up til now but I have other SSH tunnels working fine.
Offline docbee
  • Moderator
    • smartbedded
« Reply #4 on: September 12, 2014, 06:23:06 PM »
this one goes through port 80. Do you have a http proxy inhibiting direct web traffic?
« Reply #5 on: September 12, 2014, 06:26:12 PM »
No proxy; nothing blocked.
Offline docbee
  • Moderator
    • smartbedded
« Reply #6 on: September 12, 2014, 06:29:39 PM »
Did you try a reboot? As tcpdump libs to sniff going through TCP/IP traffic from the Acurite bridge consumes lot of RAM, the lib is removed during startup, when this station is not selected. So a reboot might fix the issue of a missing library.
« Last Edit: September 12, 2014, 06:33:22 PM by docbee »
« Reply #7 on: September 12, 2014, 06:30:37 PM »
Yes - rebooted  the MB lots of time.  DO you mean the PC?  Also, would it help to add the admin. site to the trusted sites list?
Offline docbee
  • Moderator
    • smartbedded
« Reply #8 on: September 12, 2014, 06:35:31 PM »
PC does not need reboot. When ssh tunnel does not work, can you give me access via setting up classical port forwarding at your router? ports 22 and 80 would be needed.
« Reply #9 on: September 12, 2014, 06:37:54 PM »
So you want the external IP (206.1.n.n:22 and 206.1.n.n:22 ) both pointing to 192.168.1.86 (which is the internal?)  Sorry for being dense...
Offline docbee
  • Moderator
    • smartbedded
« Reply #10 on: September 12, 2014, 06:42:41 PM »
yes, although I guess the second port 22 was meant to be 80.
Please send IP to "info(at)meteobridge.com" and reset to standard password.
« Reply #11 on: September 12, 2014, 06:59:43 PM »
So now of FW 2.3 there is no live data but I can get the remote URL.  Yow...
Offline docbee
  • Moderator
    • smartbedded
« Reply #12 on: September 12, 2014, 07:24:31 PM »
both seems ok to me now.
« Reply #13 on: September 12, 2014, 07:25:57 PM »
Yeah, they are - EXCEPT that the live data tab shows "Putdoor #5" at 20C  when  it is 6 c.  No idea what sensor that is.
