Author Topic: USB splitter for Meteobridge  (Read 1249 times)
Offline Jackietools
  • https://www.weatherlink.com/bulletin/a1320598-ae1c-4267-9009-3c86e9215e32
    • Jackietools
« on: July 29, 2014, 09:12:09 PM »
Is it possible to attach a splitter to the USB of my data logger on Davis Vue so I can still run Meteobridge but also plug one into my PC to download the data from the station?
Re: USB splitter for Meteobridge
« Reply #1 on: July 29, 2014, 11:00:43 PM »
No.  Have MB push the data to your local PC (ftp. SQL push etc.) Or periodically disconnet and DL the logger data.
Offline Jackietools
    • Jackietools
« Reply #2 on: July 29, 2014, 11:05:54 PM »
I didn't think the USB splitter would work. Thanks. I assume I can disconnect then reconnect MB without problems. How long would the logger need to download the info to the PC? Thanks
« Reply #3 on: July 29, 2014, 11:44:44 PM »
Depends on the data archive interval which determines the number of records.  They go pretty fast.  A couple days at 1 hr interval is like 20-30 seconds
Offline Jackietools
    • Jackietools
« Reply #4 on: July 30, 2014, 08:45:40 AM »
Sorry to be a pest but I plugged USB from station back into PC and opened WeatherLink and it is saying it cannot find the station. Is there a certain procedure I have to do to reconnect it to the WeatherLink software. Thanks
Offline Jackietools
    • Jackietools
« Reply #5 on: July 30, 2014, 12:10:31 PM »
Disregard. Got it reconnected and downloaded data tp PC. Plugged back into Meteobridge and all is up and running. Thanks
« Reply #6 on: July 30, 2014, 12:33:06 PM »
You could probably use something like this if you want to avoid physically plugging an unplugging cables.  http://www.amazon.co.uk/USB-Manual-Share-Switch-Printer/dp/B002YOVDSS
Offline docbee
  • Moderator
    • smartbedded
« Reply #8 on: July 31, 2014, 02:30:36 AM »
You might also try using a Meteostick (http://www.smartbedded.com/wiki/index.php/Meteostick) with the Meteobridge that reads RF data from your Davis. Doing so the console can be connected to your PC constantly.
Offline Jackietools
    • Jackietools
« Reply #9 on: July 31, 2014, 07:32:08 AM »
Thanks. I saw that but a bit too expensive. Already spent about 450 dollars on everything,
