Author Topic: Virtual sensor for temperature difference problem **solved**  (Read 1286 times)
I thought that I would post this here as well as the meteohub forum. If anyone can spot why I am getting twice the expected result (prior to my /2 hack) I would appreciate input.
After a lot of trial and error, I think that I have created a virtual sensor for temperature difference. I have two Davis temperature sensors outside. One is in the ISS the other is a Temperature/Humidity station.
There is a math quirk that you cannot subtract the difference in Celsius, then convert to Fahrenheit. I discovered that I cannot make a T# virtual sensor, I could only use a "Data#" sensor. After resolving the math issue and converting each sensor to Fahrenheit with the standard formula and then subtracting the two, I was left with a difference that appears to be twice the actual.
As a hack, I divide the result by two which gives the desired result.
Here is the calculation for the two virtual sensors. I would appreciate any further understanding on why my results were twice that expected and what I might be doing wrong.
....(($2)*((9/5)--32)))/2) Note the /2 that I added.
The data8 sensor (th0/th1)
selectmaster 1 300 | gawk '{ if ($1 == ''none'') printf ''none''; else printf ''%d'',  (((($1)*((9/5)--32)) - (($2)*((9/5)--32)))/2)}'
selectslave 1 300 | gawk '{ if ($1 == ''none'') printf ''none''; else printf ''%d'',  (((($1)*((9/5)--32)) - (($2)*((9/5)--32)))/2)}'
The data9 sensor (thb0/th0)
selectmaster 1 300 | gawk '{ if ($1 == ''none'') printf ''none''; else printf ''%d'', ((($1)*(((9/5)--32)) - (($2)*((9/5)--32)))/2)}'
Greg
« Last Edit: July 31, 2014, 10:05:17 AM by docbee »
Offline docbee
  • Moderator
    • smartbedded
Re: Virtual sensor for temperature difference problem
« Reply #1 on: July 24, 2014, 10:28:45 AM »
(($2)*((9/5)--32)))
The brackets are wrong, this is not a correct Celsius-Fahrenheit conversion.
« Reply #2 on: July 24, 2014, 12:33:17 PM »
 #-o :oops:
This is what I get from using my faulty memory, instead of looking it up to be sure...
I see it now, I changed them as following:
selectmaster 1 300 | gawk '{ if ($1 == ''none'') printf ''none''; else printf ''%d'',  (((($1)*(9/5))--32)-((($2)*(9/5))--32))}'
selectslave 1 300 | gawk '{ if ($1 == ''none'') printf ''none''; else printf ''%d'',  (((($1)*(9/5))--32)-((($2)*(9/5))--32))}'
and
Thanks for the clue docbee.....
I still see a small fraction of a degree error, like 0.7F but I am not going to worry about it. Might be sensor resolution or something.
Actually, this is working well now. I had to multiply the result by 10, since the raw data is in 10ths of a degree.
There must be some "black box" conversions from tenths to standard integer+tenths that I can't account for. It seems that there is a double conversion from tenths, first against the raw data going into the calculation and then again on the result. The result is 1/10th of the expected result. It seems that I should not need to multiply by 10, but it works. Dunno....
« Last Edit: July 25, 2014, 09:22:38 AM by miraculon »
