Author Topic: Station Signals - Tool - Region 3  (Read 43222 times)
Offline Cutty Sark Sailor
« on: July 11, 2014, 05:42:24 PM »
February 1 2015    UPDATE
For several reasons the signals data has been moved to non-public access.
Please see post http://www.wxforum.net/index.php?topic=25107.0
« Last Edit: February 02, 2015, 12:24:19 AM by Cutty Sark Sailor »
Re: Station Signals - Tool - Region 3
« Reply #1 on: July 11, 2014, 07:39:24 PM »
That's pretty cool, Mike. Sure beats typing over "signal" or "FFT" and the station number all the time in the image URL like I have been doing...
Offline JonathanW
  • Engineer
« Reply #2 on: July 11, 2014, 08:03:54 PM »
Nice work, Mike!
Online Maumelle Weather
    • Maumelle Weather
« Reply #3 on: July 11, 2014, 10:09:28 PM »
Thanks Mike for doing this. I realized today that I have not grounded my controller. ](*,) ](*,) ](*,) Plan on doing that tomorrow, if possible, before it gets screaming hot.
GR2AE, GR3, Cumulus
Offline Knickohr
    • Der Sternhimmel ueber Ulm
« Reply #4 on: July 12, 2014, 05:42:15 AM »
Thanks Mike for inspiration  =D>
I adapt this to my station, works pretty fine  8-)
http://www.sternhimmel-ueber-ulm.de/blitz/blitz.htm
Great job !
Thomas
Offline Jumpin Joe
    • Joe’s Weather
« Reply #5 on: July 12, 2014, 09:01:21 AM »
Sorry for the late response....
Thanks for all of your hard work and support of Blitzortung and WXForum.  =D>  =D>
Joe
https://joesweather.info
WeatherLink Live
Offline dfroula
« Reply #6 on: July 12, 2014, 11:14:53 AM »
What does it signify when one's station is highlighted in yellow?
Offline DaleReid
    • Weather at Eau Claire, WI
« Reply #7 on: July 13, 2014, 09:16:44 AM »
Great Effort!
This is a treasure trove for those who are curious, to say the least.
THANKS.
Hey, maybe it isn't enough caffeine here, but what did you mean by this statement?
" proper 'cycle' images for your station... upper left corner of each image..."
I'm not getting it.  What's a cycle to you?  The version? The stepping through the images?  I'm confuzed.
ECWx.info
ECWx.info/t/index.php
Offline DaleReid
« Reply #8 on: July 13, 2014, 11:06:23 AM »
I gotcha.  It would be 'watching updates happen' in my vernacular!
No static images unless the aforementioned things are causing the station to not be updating in the server.
Just verbage, but I was thinking of having to manually click on something to see it change.
All is well with my page.
Two questions more:
How much of a load does this place on the BO server?  Does it efficiently dispatch to your display scripts, or is it a bandwidth hog when you are getting a request for a display (which, question 1a, is do you generate those displays constantly, or ONLY when someone loads a particular station and then your software gets busy?)
Final question:  Do you drink from a fountain or a bubbler?
Dale
S
ECWx.info
Offline DaleReid
« Reply #9 on: July 13, 2014, 01:27:54 PM »
Thanks for how you do it.
And, is it pop or soda?
ECWx.info
Offline W3DRM
    • Emmett Weather
« Reply #10 on: July 23, 2014, 11:10:34 PM »
REDS: When you upgrade to firmware V7.2 you will see some interesting changes in your signals display...  ;)
(Find 7.2 after BO login, miscellaneous, firmware directory)
I noticed there was a new firmware version available on the controller webpage under either the Status or Settings tab (can't remember which one showed it). I just clicked on download and it grabbed the latest version.
--- RIPE Atlas Probe - 32849
Offline W3DRM
    • Emmett Weather
« Reply #11 on: July 27, 2014, 10:37:16 PM »
Forgot to mention... duh
One feature of the 'signals'  is not working - Egon turned it off at the server a few weeks ago as they began loading new processing. On the far right of the signal image is a red line... when this feature is available, that line will move to somewhere in the waveform for each signal... that means the server used it, and selected that point on the waveform. Also, on the 'channel' display text information, a 101 would show by the 'used' channel. If the signal was not used, that would show '100' and the red line would remain at the right margin. I hope he'll turn it on again, we can then get an idea of what a 'good' signal looks like...
Have been looking at various sites to see how everyone's waveforms compare to mine. While doing this, I just noticed that the red-line is still fixed at the right-side of the signals display but now, I am seeing a vertical white line that seems to move around on the display. Does anyone know what this white line is indicating? Is it new or have I just missed it in the past?
Offline bidouilleur
« Reply #12 on: August 10, 2014, 08:56:26 AM »
what do you loose by asking their help ?
the no you have, the yes you risk  ;)
Blitz station 1104 region 1, system RED
Offline bidouilleur
« Reply #13 on: August 10, 2014, 01:12:57 PM »
hence why I'm also here, what else to say to those who help :  =D>
« Reply #14 on: August 14, 2014, 09:02:28 AM »
Added 1141, Norman Oklahoma, on the campus of the National Weather Center!  Welcome aboard!  http://frankfortweather.us/BoStaSig/
This is pretty cool  8-)
Offline Jumpin Joe
    • Joe’s Weather
« Reply #15 on: August 14, 2014, 09:39:04 AM »
Greg,
I think it's REALLY Cool!!!   =D> =D>
Joe
WeatherLink Live
Offline Jumpin Joe
    • Joe’s Weather
« Reply #16 on: September 01, 2014, 11:00:31 AM »
Mike,
Thanks for all of your Labor in keeping up with everything!!! =D> =D>
Welcome to 1154 in Rochester, San Jose and the campus of NWS in Norman, OK !
Joe
WeatherLink Live
Offline schaffer970
« Reply #17 on: September 02, 2014, 03:24:18 PM »
Looks like Tobi made his changes???  I'm not seeing anything in the Tool.  #-o
Offline W3DRM
    • Emmett Weather
« Reply #18 on: September 03, 2014, 11:43:05 AM »
It looks like all of the Region 3 signals are flat-lined... Those from Europe appear to be okay. I guess this is an indication that Egon is still working on the servers.
Offline JonathanW
  • Engineer
« Reply #19 on: September 04, 2014, 07:56:44 AM »
Nice!
    • Maumelle Weather
« Reply #20 on: September 04, 2014, 08:19:01 AM »
I like that a lot, Mike. Being able to see each channel is a major plus.
GR2AE, GR3, Cumulus
« Reply #21 on: September 04, 2014, 08:26:32 AM »
Curiously, my 6.8USB "Green" waveforms are still working (as is FFT).
Still wish that they would put E-Field into the FFT....
« Reply #22 on: September 04, 2014, 10:51:37 AM »
 #-o
Why did I miss that?!?
I guess that I was thinking about the all-in-one FFT, but that would probably be a big mess. Looks good Mike, I guess that I am a "little slow" this morning....
Offline Silversword
  • --Stan Y.
    • Up Country Maui Weather
« Reply #23 on: September 06, 2014, 06:16:04 PM »
Hi Mike,
Is there something that I am missing to do as I see that I have been seeing flat lined graphics at http://frankfortweather.us/BoStaSig/maui993/index.html?
Your hi res looks very good.
May I suggest that your http://frankfortweather.us/BoStaSig/, either be in numerical order by Stations or in alphabetical order by Country/State... might be easier to locate instead by City.  Just my thinking...
Thanks for getting this project to where we can see what others are seeing to make some comparison.
Regards,
--Stan Y.
   Maui, Hawaii
 --- Blitzortung ID: 993
 --- FlightRadar24 ID: F-PHOG1
WDL 6.05
MS Windows 7 Pro
Davis Vantage Pro 2+ Wireless
Webcam: Axis 211
Offline bidouilleur
« Reply #24 on: September 07, 2014, 11:00:47 AM »
Cutty
question being region 1 (France) where the graphs are dead for several days. You seem to still have access to them, you generate them privately or Egon gave you a testing access to new graphs?
I guess the generation of these graphs is quite ressource hungry and since many stations have been added in very short time, I guess the poor servers have the fans spinning full speed.
Any details of what's coming or a possibility to start some graph generating on private servers ?
wondering if a boinc style collaboration might be interesting to share some work over all the red stations we have, mostly using like 30% cpu, there is capacity to use I think ...
