Author Topic: RG11 connected  (Read 8520 times)
RG11 connected
« on: May 03, 2014, 05:22:03 PM »
I interfaced my RG11 with my Davis Temp/Hum (6382) yesterday. I changed it to "rain gauge emulation" mode (was "it's raining") and patched it into the Rain channel on the Temp/Hum.
It works well with the green LED indicating "tips". So far it is running about 2x the Davis gauge. Here is the Envoy8x output.
       Current Conditions for RC Envoy8x
                  Date: Sat, 05-03-2014
          Last Reading: 05:17:39 PM
  Inside Data
    Inside Temperature:   63.5 °F
                   Bar:  29.65 in
       Inside Humidity:     54
  TX 2: RC Envoy8x/Wind_2
            Wind Speed:    0.0 mph
              Wind Dir:   ---- °
     Wind Speed 10 min:    0.0 mph
      Wind Gust 10 min:    0.0 mph
      Wind Dir of Gust:   ---- °
            Wind Chill:   ---- °F
  TX 3: RC Envoy8x/Vantage Pro2 ISS_3
   Outside Temperature:   41.8 °F
      Outside Humidity:     96 %
            Wind Speed:    0.0 mph
              Wind Dir:   ---- °
             Dew Point:   41.0 °F
            Heat Index:   42.0 °F
            Wind Chill:   42.0 °F
            Daily Rain:   0.63 in <<<<RG11 Gauge
   Last 15 min of Rain:   0.01 in
    Last 24 hr of Rain:   0.72 in
             Rain Rate:   0.05 in/hr
  TX 4: RC Envoy8x/Wind_4
            Wind Speed:    0.0 mph
              Wind Dir:   ---- °
            Wind Chill:   ---- °F
  TX 5: RC Envoy8x/Vantage Pro2 Plus ISS_5
   Outside Temperature:   41.7 °F
      Outside Humidity:     98 %
            Wind Speed:    0.0 mph
              Wind Dir:   ---- °
             Dew Point:   41.0 °F
            Heat Index:   42.0 °F
                 THSWI:   41.0 °F
            Wind Chill:   42.0 °F
            Daily Rain:   0.29 in <<<<Davis Gauge
    Last 24 hr of Rain:   0.37 in
             Rain Rate:   0.01 in/hr
                    UV:   ---- index
             Solar Rad:     47 W/m^2
                    ET:  0.000 in/hr
Ignore the 24 hour numbers, since I was testing it yesterday afternoon with a spritzer.
Greg
Offline DaleReid
    • Weather at Eau Claire, WI
Re: RG11 connected
« Reply #1 on: May 03, 2014, 06:37:50 PM »
Greg,
You realize in the State of Wisconsin, you'd need a license to modify the weather.  I'd hide your spritzer if you have a similar law in your state....
ECWx.info
ECWx.info/t/index.php
Re: RG11 connected
« Reply #2 on: May 14, 2014, 04:38:33 PM »
I treated the clear housing with RainX. Now, things are opposite with the RG11 counting about half of the Davis counts.
Hmmm....
Maybe I should apply for that weather modification license...
Greg
Offline iisfaq
  • Christchurch Weather Live
Re: RG11 connected
« Reply #3 on: June 25, 2014, 01:59:07 PM »
Hi
I would be interested in how you did this?
I have an RG11 - but not been using it.
Are you willing to share the details on the interface you connected up?
Chris
Re: RG11 connected
« Reply #4 on: June 25, 2014, 06:44:00 PM »
I used the rain input on a Davis Temp/Humidity station. The pinouts for the Davis rain collector are:
Input/Output Connections
Black . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Unused
Red . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Switch terminal
Green & Yellow. . . . . . . . . . . . . . . . . . . . . . . . . . . . . Switch terminal
But this is somewhat ambiguous. I wired the NO terminals of the RG-11 to match these "RJ-11" connector terminals on a Davis SIM rain channel. Maybe using an actual Davis cable and cutting off one end might be the best bet. I had to use a slightly larger wire than the RJ-11 connector 24 gauge wire since the screw terminals on the RG-11 would not tighten on such a small wire. I soldered short wire stub to the 24 gauge and put heat shrink tubing on it.
I had some trouble at first with the RG-11 not registering counts. I found that I would get a count when I plugged in the connector. I eliminated one of the wires until I got the closure to the rain input to work correctly. Sorry, I didn't document what I did very well. The RG-11 rubber o-ring is difficult to get to seat properly, otherwise I would go and look at it for you. It was somewhat of an ordeal to get it back together properly.
The output that was in my posting is from a Davis Envoy8x, which allows multiple "ISS" units. I have the "real" ISS configured on Station #5 and the Temp/Hum station on #3. The accuracy seems to be variable compared to my CoCoRaHS and Davis gauges. Sometimes they are reasonably close other times, way off. The "RainX" treatment seemed to make an improvement.
    • Weatherelement Moline IL
Re: RG11 connected
« Reply #5 on: June 26, 2014, 01:13:43 AM »
2 things....
1) From the Hydreon web site...
Not as accurate as a properly maintained Tipping Bucket, but a better choice for many applications.
We do not guarantee or specify an accuracy for the RG-11, ...
2) When I got my 3rd RG-11 (?) I recall that the RainX mod required special firmware. Do you have that? Or is there a new firmware I'm not familiar with? (http://www.rainsensors.com/support.php)
Re: RG11 connected
« Reply #6 on: June 26, 2014, 09:00:04 AM »
2 things....
Mine shipped 12/7/2011 so it should have the "RainX" firmware. I am not dealing with that O-ring again so I will not be checking the sticker on the connector. :evil:
Greg H
Offline Moose Whisperer
    • Alaska Weather Watch
Re: RG11 connected
« Reply #7 on: July 19, 2014, 03:34:38 AM »
I just got one to try out from Amazon today as well. My first question - I guess I'm a bit confused; doesn't this thing come with a power supply?
Re: RG11 connected
« Reply #8 on: July 19, 2014, 08:43:17 AM »
No, it doesn't come with a power supply. However, it is very flexible as far as power is concerned. It will run on a wide range of voltages either AC or DC.
Input Voltage 9 – 30VDC or
9 – 26 VAC
50V surge
Reverse polarity protected to 50V
I am using a "outdoor" yard light transformer to run mine. (I had to put a piece of black tape over the photo sensor to force it on all the time).
From what I have seen, it is "reasonably" accurate if there is a steady, gentle rain. If there is a downpour it will be lower than the Davis.
Have fun with the O-ring, you need about four hands to install it... :shock:
« Last Edit: July 19, 2014, 04:24:13 PM by miraculon »
Re: RG11 connected
« Reply #9 on: July 19, 2014, 01:40:51 PM »
Great, thanks!
I've got a spare 24VAC outdoor lighting transformer I can now put to good use as well.
And I've been reading about the O-ring complaints as well. I'm a bit confused here too. Mine came pre-assembled with the O-ring in place and a dessicant pack inside.
Re: RG11 connected
« Reply #10 on: July 19, 2014, 01:58:30 PM »
Yes, but have you disassembled the unit for wiring and switch setting yet, and then tried to reassemble it? I have 3 RG11s. and it's not quite the struggle it was, but it can still be a challenge...
Great, thanks!
Re: RG11 connected
« Reply #11 on: July 19, 2014, 03:16:38 PM »
Great, thanks!
Yea, I'll tackle that part here in a day or two when I replace my ISS board.
