May 23, 2013, 05:01:50 AM *
Members: 6617  •  Posts: 178633  •  Topics: 18128
Author Topic: Strange Outside Temperature.  (Read 1347 times)
killwilly
« on: September 25, 2008, 07:55:06 AM »
Hello.
Twice this month I have had very strange outside maximum temperature readings. The 7th and the 21st have shown 114.8c. The time recorded has also been very strange, one at 150:67, the other at 50:34.... on a 24 hour clock! I should add that the minimum and current temperatures have been correct.
I don't run my computer and weather station 24/7, but my WMR 200 does have a data logger.
I have only had this problem since I upgraded to version 14:00 p30.
Has anyone else had a similar experience?
Any help would be very much appreciated.
Alan.
Alan >>>>>><br /><br />Hardware:- Davis Vantage Vue<br />Software:-  VWS:14.00 p87. Davis WeatherLink<br />Location:-  Lincolnshire, UK.<br /><br /><br />Wunderground ID,  ILINCOLN15
Anthony
Moderator
« Reply #1 on: September 25, 2008, 08:29:28 AM »
Heres what I think happens. If vws is updating it's files or obtaining info from the station and you shut vws down. It can cause eronous data to be written to vws.
The cure. Leave you computer running.
Anthony
WB8YUE
killwilly
« Reply #2 on: September 25, 2008, 08:42:14 AM »
Hello Anthony.
Thank you for your prompt reply. I would like to keep my computer running, but unfortunately it's a laptop and I don't think it wise to run laptops permanently.
Perhaps you or someone else may be able to advise me when would be the best time to shutdown.
Alan.
tomcj2
« Reply #3 on: September 25, 2008, 08:47:22 AM »
I have kept my HP laptop running for more than 2 years without problems.  (I do remove the battery)
Davis VP2 (6163), WL 5.9.0..  VWS 14.01 p25, Panasonic HM371A camera. WU & W4U KORCANBY3, CoCoRaHS OR-CC-27
killwilly
« Reply #4 on: September 25, 2008, 09:16:53 AM »
Thank you tomcj2. It may be possible to run my laptop 24/7, but not practical for me. I use it for other things at a different location.
Alan.
Weather Display
« Reply #5 on: September 25, 2008, 04:14:32 PM »
did the wrong data occur when the missed history data , at start up of VWS,  was read from the wmr200 ?
(running the program all the time then would get around that problem)
Anthony
Moderator
« Reply #6 on: September 26, 2008, 08:08:58 AM »
If it happened because of what I said in my first post. It would be difficult to tell just what vws was doing at a given point. So you might shut vws down a hundred times and it never happen. And it could happen the next time you shut it down. And GWB also makes a good point.
Anthony
WB8YUE
killwilly
« Reply #7 on: September 26, 2008, 09:02:23 AM »
The odd temperature does only show on my VWS history files, and not on my station console history. I think your advise to run 24/7 is the only answer.
Many thanks to everyone for your help.
Alan
Page created in 0.102 seconds with 20 queries.
