I have a weather page up for our local small airport weather station, located at
http://twinoaksairpark.com/wx as well as a brief METAR test output from VWS at
http://www.twinoaksairpark.com/7S3.TXTThe HTML tag/variable available to display the wind direction in a regular web page appears to only output a general direction, and there is no option I can find to display actual degrees. However, every other wind direction tag/variable displays its data in actual degrees. I wondered if the station hardware was just reporting a generic direction (NE, S, SSW, etc), but then realized the METAR output contains the *exact* wind direction in degrees.
Below is a sample of the actual output from the various wind direction related variables. The first line is the wind direction, and as you can see it just reads "S" rather than a numeric-degrees value. The weather station is a Davis Pro 2.
Any way to get the actual degrees in real time for the web page? The only variable (which I am not sure about due to lack of detailed info) that I was thinking *might* be it is Wind Direction Running Average - vva001. But I think that's averaged over the previous 60 minutes maybe? If so, it'd not what I need. But if that is close to what I want, does anyone know how its calculated?
Thanks!
S Wind Direction
263 Wind Direction Daily Hi
1:28am Wind Direction Daily Hi Time
59 Wind Direction Daily Lo
2:55am Wind Direction Daily Lo Time
154 Wind Direction Running Average
0 Wind Direction Daily Avg
0 Wind Direction Month Avg
0 Wind Direction Year Avg
28.4 Wind Direction Rate
76.5 Wind Direction Rate Hi
1:28am Wind Direction Rate Hi Time
-99.6 Wind Direction Rate Lo
2:55am Wind Direction Rate Lo Time
360 Wind Direction Monthly Hi
2/1/14 Wind Direction Monthly Hi Date
5 Wind Direction Monthly Lo
2/2/14 Wind Direction Monthly Lo Date
360 Wind Direction Yearly Hi
1/2/14 Wind Direction Yearly Hi Date
0 Wind Direction Yearly Lo
1/14/14 Wind Direction Yearly Lo Date
338 Wind Direction Yesterday Hi
6:21pm Wind Direction Yesterday Hi Time
12:39pm Wind Direction Yesterday Lo Time
148 Wind Direction 24hours ago
23 Wind Direction 24hour difference
° Wind Direction Units
