Author Topic: POST your currently updating webcam image here!  (Read 59638 times)
Offline DaculaWeather
  • It's a Jeep thing... you wouldn't understand.
  • SCCA EM #156
    • North Georgia and US Weather
Re: POST your currently updating webcam image here!
« Reply #75 on: May 10, 2014, 06:56:04 AM »
ok...
  • SCCA EM #156
« Reply #76 on: May 10, 2014, 06:59:57 AM »
Full size
Offline Cutty Sark Sailor
« Reply #77 on: May 10, 2014, 07:56:27 AM »
Here's my latest -
« Last Edit: August 16, 2015, 06:34:51 PM by Cutty Sark Sailor »
Offline Jumpin Joe
    • Joes Weather
« Reply #78 on: May 10, 2014, 08:44:10 AM »
Full size
Steve, are those stills from your 3805?
Joe
  • SCCA EM #156
« Reply #79 on: May 10, 2014, 10:18:33 AM »
The top one is. The bottom one is my older 2605.
Offline Jumpin Joe
    • Joes Weather
« Reply #80 on: May 10, 2014, 10:58:29 AM »
Clarity is awesome. Still waiting for the beta test. The last update I have from them is that they will start the beta program this month.
Offline tnwxman
  • KK4QXH
    • Weather for Lebanon, TN 37087
« Reply #81 on: May 10, 2014, 02:09:22 PM »
Like the clarity also. Is it possible to Hubble Cam fix a Foscam FI8905W. If so, what are the recommendations?
Thanks.
Bob
Bob
KK4QXH
  • SCCA EM #156
« Reply #82 on: May 10, 2014, 03:35:47 PM »
Thanks. Actually, the full size is here:
http://www.daculaweather.com/4_camera2_static.php
Offline Intheswamp
    • Beeweather
« Reply #83 on: May 10, 2014, 07:24:47 PM »
You could try it but I believe the Foscam is already focused for distant subjects.  The idea of the Hubble mod is to take a near-sighted webcam, a camera that normally has a focus range of only a few feet in front of it, and modify it so that it's focus point is much farther away, maybe infinity.
Here is the first post of the Hubble Fix thread that explains it:  http://www.wxforum.net/index.php?topic=19044.0
So, you could try it, but I'm not sure that your results will be worth it.  It could possibly make the image quality worse.  The good thing is that it is not a permanent fix (unless you want it to be). :)  Does your present setup seem out of focus?
Ed
Davis VP2, v3.12
Cumulus v1.9.4  Build 1079
www.beeweather.com
Tried to lift one of vreihen's gold stars but wasn't smart enough to do it....<grin>
« Reply #84 on: May 10, 2014, 07:57:32 PM »
FYI... noted on Amazon today... Loggie C910 Pros $119... I think they're consumer packaging... that's the 5MP version, hopefully, not B910. Last batch I got ahold of (4 was all they had) were brown box cam only 'oem' kit extras.... think I paid $80 ea.  Be a good time, since they're out of production, if you want a great USB cam that a lot of us use with a -2 diopter lens.
« Reply #85 on: May 10, 2014, 08:07:06 PM »
Checked your cam's specs, as Ed says, I don't think it would be worth the effort. Folks haven't had much luck with wireless and some other IP cams... just doesn't improve things to the extent they do with those designed for 'near' webcamming.  Wait around, somebody will post it if they've done it. We do have a Logitech 'Alert' POE on the HubbleCam page, however, but I'm not sure of the specs on that device. Looks good, though!
Offline iisfaq
  • Christchurch Weather Live
« Reply #86 on: June 05, 2014, 04:08:04 AM »
Cashmere Weather Live - Christchurch, New Zealand.
Updated once per minute, 24 hours per day.
Canon G9 - Using chdk to capture 1 photo per minute. Photo is transferred with Eye-FI SD Card to computer. Custom software then processes the image adds the weather data and uploads to a server in Singapore in Azure.
chris
« Last Edit: February 01, 2015, 01:20:17 PM by iisfaq »
Offline tosealer
    • Seal Backyard Weather
« Reply #87 on: June 06, 2014, 09:55:27 AM »
Thought I'd add one of my weather cams.  It's a Vivotek FE8171V 360 degree fisheye.  Mounted on the roof of my house (I'm located in Toronto), it gives a decent 360 image.  I use BlueIris to grab the image, add the overlay, and Imagemagick to generate a panoramic view from the 360 degree image.
My other webcam images (one Hikvision, one Raspberry Pi Cam, and three different Chinese IP cameras) can be found here
« Last Edit: April 03, 2018, 08:20:52 PM by tosealer »
Toronto, ON  Canada
Davis VP2/WeatherDisplay
www.SealWeather.ca
Offline cmcgill
    • Westford Weather
« Reply #88 on: August 01, 2014, 10:15:44 PM »
SP-500UZ using Sebectec software.
« Last Edit: August 02, 2014, 10:45:09 AM by cmcgill »
Offline gluepack
    • Jerbils' Weather Site
« Reply #89 on: August 02, 2014, 05:09:19 PM »
I have been using a cheap IP camera, a REPOTEC RP-WV330, for over 30 months now and submitting solely to Weather Underground, although the image is picked up from there and displayed on five other webcam sites, as well as my own weather oriented site.
The image isn't nearly as good as I have seen from other cameras on this thread.  It is actually designed for internal use (not even supposed to use it for pointing outside) but so far, touch wood, I have had no problems and it has been working continuously throughout that period.
It is not intended as a night camera and, as it is close up to the window, at night all you will see is the reflection of the device's indicators on the window.
    • Watts Bar Weather
« Reply #90 on: August 02, 2014, 08:21:28 PM »
That reminds me of the Carbonite Maneuver:
Offline gluepack
« Reply #91 on: August 03, 2014, 04:53:13 AM »
Lol, your post only "works" when it is night time here ;)
    • Watts Bar Weather
« Reply #92 on: August 03, 2014, 12:10:18 PM »
You're right.  I thought he only posted a picture.  I guess it's a updating image.  I'll fix that tonight.
« Last Edit: August 03, 2014, 12:14:04 PM by SlowModem »
Offline morfeas2002
  • Kostas, Kalamata, Greece
    • Kalamata weather station
« Reply #93 on: August 27, 2014, 05:17:21 AM »
This is my 4 camera current images from Kalamata, Greece. Today is a sunny, hot day.
Offline josecmorales
    • Clima en Guayana
« Reply #94 on: September 04, 2014, 04:37:45 PM »
I bought a Foscam FI9804W, really works good
I use weatherbridge to upload the image.
  • SCCA EM #156
« Reply #95 on: December 01, 2014, 08:56:36 AM »
My new HDNC 6301 Sharx camera. 2048x1536 resolution
Offline Jumpin Joe
    • Joes Weather
« Reply #96 on: December 01, 2014, 09:22:16 AM »
Steve,
Awesome picture from an awesome camera. I really like mine.
I'm still working on getting the right software to stream mine with.
Joe
  • SCCA EM #156
« Reply #97 on: December 29, 2014, 08:37:02 AM »
I wish I had brought the 5501 down with me. The electricians didn't get around to getting them installed before we left for my parents.
Offline KK7X
  • KIDRATHD3
    • Rathdrum Weather
« Reply #98 on: December 29, 2014, 11:45:04 AM »
Using a Foscam 9805 mounted outside under the eave.  BlueIris Software uploading to the website and Weather Underground
Offline KK7X
  • KIDRATHD3
    • Rathdrum Weather
« Reply #99 on: December 29, 2014, 11:46:09 AM »
This is a Logitech Alert that I have had for about 7 years.
