Author Topic: ARDUINO UNO IS HERE!  (Read 17755 times)
Offline fmbfla
« on: January 28, 2014, 09:40:30 PM »
I know you might be able to buy a weather station cheaper (or not) but the fun is knowing that you BUILT IT!
I did just that I took My arduino uno and got a few various sensors and plied the innerweb fer clews on how to post ("GET" to Wunderground).
My results can be found here....http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KFLFORTM67
Idea's inc, 5 VOLT SOLAR POWERED, GPRS for remote locals or just so you don't need your COMPUTER
The code below contains my rant's of what is what and why.
If your reading this then you know what your doing.....
++++++DON'T BURN THE HOUSE DOWN! (again)++++++
lets get this party started and quit using AMERICAN remade Chinese stuff and build our own AMERICAN made Chinese stuff!!
gotta go,
I need a shot of Saki :-)
 Brought to you by the Drunken Programmer!  (rt)
 This MODIFIED sketch connects to a website (http://www.rtupdate.wunderground.com)
 Using an Arduino Wiznet Ethernet shield To upload your weather conditions to wunderground.com,
 We make a standard HTTP GET request with the ID, PASSWORD and weather conditions as GET parameters.
 You must first create an account with wunderground for this to werk!
 Various notes throughout attempt to explain why i did what i did to make it werk.
 This sketch also incorporates an NTP RTC update code to make sure that the time is always correct and
 resets the RTC Soft or Hard to UTC ZULU Wunderground wants "UTC ZULU HOUR".
 Results for this can be monitored @ http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KFLFORTM67
Binary sketch size: 28,058 bytes (of a 32,256 byte maximum)
 Circuit:
 * Arduino UNO adafruit
 * Ethernet shield attached to pins 10, 11, 12, 13
 * DHT to pin A0 adafruit
 * Wind direction to pin A1(360 var resistor)
 * Anemometer to Digtal 2 (INT0) (reed)
 * Rain tip to Digital 3 (INT1) (hall effect)
 * BMP to I2C adafruit
 * RTC to I2C adafruit
 Originaly created 18 Dec 2009
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe, based on work by Adrian McEwen
 Modified  To upload weather conditions to wunderground.com
 1,Jan 2014
 By the drunkin programer
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>       // New from IDE 1.0
#include <Wire.h>
#include "DHT.h"
#include <Adafruit_BMP085.h>
#include "RTClib.h"
//Pins
#define DHTPIN  A0                   // DHT 22  (AM2302)
#define vane A1
#define anemometer  2                // D2 Wind speed
#define rainTip  3                   // pin D3 Rain bucket
#define led  13                      // Notification of SENDING DATA
#define DHTTYPE DHT22                // DHT 22  (AM2302)
//IPAddress SERVER(38,102,137,157);  // numeric IP for wunderground.com
char SERVER[] = "rtupdate.wunderground.com";           // Realtime update server
//char SERVER [] = "weatherstation.wunderground.com";  //standard server
char WEBPAGE [] = "GET /weatherstation/updateweatherstation.php?";
char ID [] = "XXXXXXXXXXX";
char PASSWORD [] = "XXXXXXXXXX";
// Pick one below
// byte timeServer[] = {192, 43, 244, 18}; // time.nist.gov NTP server
  132, 163, 4, 101};    // ntp1.nl.net NTP server
//byte timeServer[] = {132, 163, 4, 102}; // time-b.timefreq.bldrdoc.gov NTP server
// byte timeServer[] = (132, 163, 4, 103);
const int NTP_PACKET_SIZE= 48;        // NTP time stamp is in the first 48 bytes of the message
byte pb[NTP_PACKET_SIZE];             // buffer to hold incoming and outgoing packets
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };//Hard config my mac
//IPAddress ip(192,168,1,109);//Hard config ip
EthernetClient client;
unsigned int localPort = 8888;
const float pi = 3.14159265; // pi, not apple, not pumpkin, not pizza, not even related to Raspberry Pi. http://www.raspberrypi.org/ This is the REAL PI for RPM/Wind speed calculations
// Radius from vertical anemometer axis to a cup center (mm)
const int radio = 60;
// (changing "Wait")changes the windspeed calculation "period" automaticly
const unsigned long Wait = 1250;  // Amount of Time to wait till Re-connecting, Changing this also
const unsigned long period = Wait * 2; // Measurement period (miliseconds)
const unsigned long IDLE_TIMEOUT_MS = 1000;
unsigned int counter = 0;         // pulse count for wind sensor
unsigned int RPM = 0;             // Revolutions per minute
unsigned int Sample = 0;          // Sample number
unsigned int TIME = 10;           // count down from 10 and reat the rtc
unsigned int connections = 0;     // number of connections
unsigned int winddir = 0.0;       // Wind direction
unsigned int rainin = 0;          // counter for Rain
unsigned int rainSample = 0;      // counter for Rain Samples
float windspeedmph = 0/ 0.445;    // Wind speed (m/s)
float windgustmph = 0;            // Max wind speed
//---DEWPOINT CALC!-------------------------------
double dewPoint(double tempf, double humidity)
  double A0= 373.15/(273.15 + tempf);
  double SUM = -7.90298 * (A0-1);
  SUM += 5.02808 * log10(A0);
  SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
  SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
  SUM += log10(1013.246);
  double VP = pow(10, SUM-3) * humidity;
  double T = log(VP/0.61078);
  return (241.88 * T) / (17.558-T);
EthernetUDP Udp;                  // UDP for the time server
DHT dht(DHTPIN, DHTTYPE);         // DHT 22  (AM2302)
Adafruit_BMP085 bmp;              // BMP Sensor
RTC_DS1307 rtc; // Hardware RTC time
//RTC_Millis rtc; // Software RTC time
void setup(void)
  attachInterrupt(1, addrain, RISING); // attachInterrupt 1 sp that it can count the rain constantly
  // (it does'nt tip that often and we dont need to calcualate).
  Serial.begin(38400);
  Wire.begin();    //Rtc
  rtc.begin();     //uncomment to use hardware rtc
  //uncomment below to reset the time !
  //rtc.adjust(DateTime(__DATE__, __TIME__));// leave uncommented if using software rtc
  bmp.begin();
  dht.begin();
  pinMode(anemometer, INPUT); //Anemometer input(spins like made when the wind blows).
  digitalWrite(anemometer, HIGH); // set this high so when it detects a change it records it via INT(0)
  pinMode(rainTip, INPUT);// rain tip input
  digitalWrite(rainTip, HIGH);     // set this high so when it detects a change it records it via INT(1)
  Serial.println(F("NTP2RTC / Ethernet shield to Wunderground Test!\n"));
  Serial.print(F("\nInitializing..."));
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    //Ethernet.begin(mac, ip);
    // Serial.println(ip);
  Serial.print("Local I.P: ");
  Serial.println(Ethernet.localIP());
  Serial.println("Ready!");
  Serial.println("End of the Setup Function");
void loop(void)
  // Lets see what time the RTC is set at!
  DateTime now = rtc.now();
  Serial.println("+++++++++++++++++++++++++");
  Serial.println("RTC current TIME ");
   if(now.hour() < 10){            // Zero padding if value less than 10 ie."09" instead of "9"
    Serial.print(" ");
    Serial.print((now.hour() > 12) ? now.hour() - 12 : ((now.hour() == 0) ? 12 : now.hour()), DEC); // Conversion to AM/PM
  else{
  Serial.print(':');
  if (now.minute() <= 10){
    Serial.print("0");
  Serial.print(now.minute());
  Serial.print(':');
  if (now.second() <= 10){
    Serial.print("0");
  Serial.println(now.second());
  //Clear the rainin, windgustmph and rainSample every 10 loops.
  //if you let the results runn they will add up on wunderground and report constant additions to wing gust and rain fall
  //But you must report the readings for a rew posts for wunderground to realize it is a real reading and not a false one
  if (rainSample >=10){
    rainin = 0;//Clear the rainCount
    rainSample = 0;// Clear the rain samples
    windgustmph = 0;  //clear Max wind speed
  Sample ++;    // add "loop's
  TIME--;       // Subtract Count doun from 10 to reset the RTC
  rainSample++; // add and when limmit reached clear the results
  windvelocity();
  RPMcalc();
  WindSpeed();
  Heading();
  float tempf = dht.readTemperature();
  float humidity = dht.readHumidity();
  float baromin = bmp.readPressure()* 0.0002953;// Calc for converting Pa to inHg (wunderground)
  float dewptf = (dewPoint(dht.readTemperature(), dht.readHumidity())); //Dew point calc(wunderground)
  // max wind speed holder(wunderground)
  if (windspeedmph > windgustmph) {
    windgustmph = windspeedmph;
  Serial.print("Posting Sample # ");// tells us how many loops
  Serial.println(Sample);
  Serial.print("Posts till clock Reset ");// tells us when the clock will try a reset might fail every now and then but werks!
  Serial.println(TIME);
  Serial.println();
  Serial.println("-------------------------------------");
// Debug, or you can sit up all night watching it.
  Serial.print("wind dir= ");
  Serial.print(winddir);
  Serial.println(" deg's");
  Serial.print("windspeed mph= ");
  Serial.println(windspeedmph);
  Serial.print("wind gust mph= ");
  Serial.println(windgustmph);
  Serial.print("temp= ");
  Serial.print(tempf);
  Serial.println(" *F");
  Serial.print("rain in= ");
  Serial.println(rainin / 2.0 / 100.0);
  Serial.print("baro= ");
  Serial.print(baromin);
  Serial.println(" inHg");
  Serial.print("dew point= ");
  Serial.println(dewptf);
  Serial.print("humidity= ");
  Serial.println(humidity);
  Serial.println();
  Serial.print("Waiting ");
  Serial.print(Wait*2/1000.0);
  Serial.println(" seconds.");*/
  if (TIME  <= 1) {// Hey, if the TIME reached 1 then contact the NTP site and try to set the RTC to UTC ZULU
    TIME = 10; // Make the countdown start from 10 again
    Udp.begin(localPort);// Call from this line.......PLEASE
    Serial.println("UpDating CLOCK");
    Serial.print("RTC before: ");
    PrintDateTime(rtc.now());// Show me the time
    Serial.println();
    int packetSize = Udp.parsePacket(); //<<<<<<<<<<<<NEW LINE HERE
    // send an NTP packet to a time server
    sendNTPpacket(timeServer);// Ask the bum for the time... and say please!
    // wait to see if a reply is available
    delay(1000);
    if ( Udp.available() ) {
      // read the packet into the buffer
      Udp.read(pb, packetSize);      // New from IDE 1.0 <<<<<<<<<<<<<MODIFIED LINE
      unsigned long t1, t2, t3, t4;
      t1 = t2 = t3 = t4 = 0;
      for (int i=0; i< 4; i++)
        t1 = t1 << 8 | pb[16+i];
        t2 = t2 << 8 | pb[24+i];
        t3 = t3 << 8 | pb[32+i];
        t4 = t4 << 8 | pb[40+i];
      float f1,f2,f3,f4;
      f1 = ((long)pb[20] * 256 + pb[21]) / 65536.0;
      f2 = ((long)pb[28] * 256 + pb[29]) / 65536.0;
      f3 = ((long)pb[36] * 256 + pb[37]) / 65536.0;
      f4 = ((long)pb[44] * 256 + pb[45]) / 65536.0;
      const unsigned long seventyYears = 2208988800UL;
      t1 -= seventyYears;
      t2 -= seventyYears;
      t3 -= seventyYears;
      t4 -= seventyYears;
      PrintDateTime(DateTime(t4));
      Serial.println(f4,4);
      Serial.println();
//WUNDERGROUND  COMMENTS
      //Adjust your timezone ... in my case I substract 5 hours for West Florida Time
      //**** YOU MUST Add "X" hours (in my case + 5) to the  client.print(now.hour() + 5); ****
      // to get back to UTC ZULU, or Wunderground wont show RAPID FIRE or display incorrect times for you observations
      t4 -= (5 * 3600L);     // Notice the L for long calculations!!
      t4 += 1;               // adjust the delay(1000) at begin of loop!
      if (f4 > 0.4) t4++;    // adjust fractional part, see above
      rtc.adjust(DateTime(t4));
      Serial.print("RTC after : ");
      Serial.println();
      Serial.println("done ...");
      // endless loop
      //while(1);
    else
      Serial.println("No UDP available ...");
      Serial.println("ARRRRRRRRRRRRrrr !!!");// wait 10 more loop's.
  Serial.println();
  if (client.connect(SERVER, 80)) { // Money Shot!
    Serial.println("Sending DATA ");
    client.print(WEBPAGE);
    client.print("ID=");
    client.print(ID);
    client.print("&PASSWORD=");
    client.print(PASSWORD);
    client.print("&dateutc=");
    client.print(now.year());
    client.print("-");
    client.print(now.month());
    client.print("-");
    client.print(now.day());
    client.print("+");
    client.print(now.hour()+5);// YOU MUST Add 5 hours to get back to UTC or Wunderground wont show RAPID FIRE
    client.print("%3A");
    client.print(now.minute());
    client.print(now.second());
    client.print("&winddir=");
    client.print(winddir);
    client.print("&windspeedmph=");
    client.print(windspeedmph);
    client.print("&windgustmph=");
    client.print(windgustmph);
    client.print("&tempf=");
    client.print(tempf);
    client.print("&rainin=");
    client.print(rainin / 2.0 / 100.0);
    client.print("&baromin=");
    client.print(baromin);
    client.print("&dewptf=");
    client.print(dewptf);
    client.print("&humidity=");
    client.print(humidity);
    //client.print("&action=updateraw");//Standard update
    client.print("&softwaretype=Arduino%20UNO%20version1&action=updateraw&realtime=1&rtfreq=2.5");//Rapid Fire
    client.println();
    Serial.println("Upload complete");
  else {
    Serial.println(F("Connection failed"));
    return;
  Serial.println("Server Response!");
  unsigned long lastRead = millis();
  while (client.connected() && (millis() - lastRead < IDLE_TIMEOUT_MS)) {
    while (client.available()) {
      char c = client.read();
      Serial.print(c);
  client.stop();// Wipe it off and get ready to do it again
    delay(Wait);// 30sec +/-
  Serial.println();
}// end loop
//MISC--------------------------------------------------
void windvelocity(){
  windspeedmph = 0;
  counter = 0;
  attachInterrupt(0, addcount, RISING);//anemometer
  //attachInterrupt(1, addrain, RISING); // Read the Rain tips Hall Effect
  unsigned long millis();
  long startTime = millis();
  while(millis() < startTime + period) {
  detachInterrupt(0);
  //detachInterrupt(1);
void RPMcalc(){
  RPM=((counter*4)*60)/(period/1000);  // Calculate revolutions per minute (RPM)
void WindSpeed(){
  windspeedmph = ((2 * pi * radio * RPM)/60) / 1000;
void addcount(){
  counter++;
void addrain(){
  rainin++;
void Heading(){
  float windDir =(analogRead(vane)* 5.00 / 1023.0);    // Wind direction
  if ((windDir > 4.94)||(windDir < 0.01))
    (winddir = 0.0);// North
  if ((windDir >= 0.02)&&(windDir < 0.30))
    (winddir = 22.5);//NNE
  if ((windDir >= 0.31)&&(windDir < 0.72))
    (winddir = 45.0);//NE
  if ((windDir >= 0.72)&&(windDir < 0.99))
    (winddir= 67.5);//ENE
  if ((windDir >= 1.00)&&(windDir < 1.25))
    (winddir = 90.0);//E
  if ((windDir >= 1.26)&&(windDir < 1.52))
    (winddir= 112.5);//ESE
  if ((windDir >= 1.53)&&(windDir < 1.91))
    (winddir= 135.0);//SE
  if ((windDir >= 1.92)&&(windDir < 2.40))
    (winddir = 157.5);//SSE
  if ((windDir >= 2.41)&&(windDir < 2.73))
    (winddir = 180.0);//S
  if ((windDir >= 2.74)&&(windDir < 2.96))
    (winddir = 202.5);//SSW
  if ((windDir >= 2.97)&&(windDir < 3.37))
    (winddir = 225.0);//SW
  if ((windDir >= 3.38)&&(windDir < 3.55))
    (winddir = 247.5);//WSW
  if ((windDir >= 3.56)&&(windDir < 3.85))
    (winddir = 270.0);//W
  if ((windDir >= 4.13)&&(windDir < 4.06))
    (winddir = 292.5);//WNW
  if ((windDir >= 4.07)&&(windDir < 4.32))
    (winddir = 315.0);//NW
  if ((windDir >= 4.33)&&(windDir < 4.93))
    (winddir = 337.5);//NNW
// MISC
void PrintDateTime(DateTime t)
  char datestr[24];
  sprintf(datestr, "%04d-%02d-%02d  %02d:%02d:%02d  ", t.year(), t.month(), t.day(), t.hour(), t.minute(), t.second());
  Serial.print(datestr);
// send an NTP request to the time server at the given address
unsigned long sendNTPpacket(byte *address)
  // set all bytes in the buffer to 0
  memset(pb, 0, NTP_PACKET_SIZE);
  // Initialize values needed to form NTP request
  // (see URL above for details on the packets)
  pb[0] = 0b11100011;   // LI, Version, Mode
  pb[1] = 0;     // Stratum, or type of clock
  pb[2] = 6;     // Polling Interval
  pb[3] = 0xEC;  // Peer Clock Precision
  // 8 bytes of zero for Root Delay & Root Dispersion
  pb[12]  = 49;
  pb[13]  = 0x4E;
  pb[14]  = 49;
  pb[15]  = 52;
  // all NTP fields have been given values, now
  // you can send a packet requesting a timestamp:
#if ARDUINO >= 100
  // IDE 1.0 compatible:
  Udp.beginPacket(address, 123); //NTP requests are to port 123
  Udp.write(pb,NTP_PACKET_SIZE);
  Udp.endPacket();
#else
  Udp.sendPacket( pb,NTP_PACKET_SIZE,  address, 123); //NTP requests are to port 123
#endif
// End of program
Offline Scott216
Re: ARDUINO UNO IS HERE!
« Reply #1 on: July 08, 2014, 04:34:41 PM »
fmbfla - In your sketch you have this comment:
"Clear the rainin, windgustmph and rainSample every 10 loops. If you let the results run they will add up on wunderground and report constant additions to wing gust and rain fall. But you must report the readings for a few posts for wunderground to realize it is a real reading and not a false one."
Could you elaborate on this a bit?
Offline wxtech
  • Moderator
    • Lexington, Ga. Weather
« Reply #2 on: July 09, 2014, 10:29:59 AM »
Thanks for sharing your project especially the sketch.
When we buy a weather station in the box, we never get exactly the features that we're wishing for.  A DIY wx station gets closer to our needs providing we can create the software.
Al
Offline fmbfla
« Reply #3 on: July 16, 2014, 08:52:10 PM »
Thanks Scott216, I think I have fixed this issue after reading up on the WIKI again.  so far so good with the current sketch. (ADDED A UV SENSOR!)
 The anemometer/windvane are from ebay looke for a cheap one and upgrade it or make your own
 code for the Anemometer from: Authors: M.A. de Pablo & C. de Pablo S. on there home-made version af an anomometer
 resets the RTC Soft or Hard to UTC ZULU to comp for time drift, (Wunderground wants "UTC ZULU HOUR" for RTU).
 Binary sketch size: 29,800 bytes (of a 32,256 byte maximum) as of 6/27/2014
 misc links,
 * http://en.wikipedia.org/wiki/Dew_point Dew point Calc
 * http://wiki.wunderground.com/index.php/PWS_-_Upload_Protocol Information on the Upload Protocol for wunderground.
 Circuit:
 * Arduino UNO adafruit http://www.adafruit.com/products/50
 * Ethernet shield attached to pins 10, 11, 12, 13 http://www.adafruit.com/products/201
 * DHT to pin A0 adafruit http://www.adafruit.com/products/393
 * Wind direction to pin A1 this is a DAVIS instrument which incorperates the anemometer (or make a home made one using a 360 var resistor)
 * Anemometer to Digtal 2 (interrupt 0)this is a DAVIS instrument (reed switch)
 * and it looks like this http://www.skygeek.com/davis-instrument-7890-anemometer-mast-mount.html?utm_source=googlebase&utm_medium=shoppingengine&utm_content=davis-instrument-7890-anemometer-mast-mount&utm_campaign=froogle&gclid=CLLugIr107wCFbB9Ogodi14AiA
 * Rain tip to Digital 3 (interrupt 1) (hall effect sensor) http://www.adafruit.com/products/158
 * BMP to I2C adafruit https://www.adafruit.com/products/391
 * RTC to I2C adafruit https://www.adafruit.com/products/264
 by David A. Mellis
 modified 9 Apr 2012
 1,Jan 2014
#include "SPI.h"
#include "Ethernet.h"
#include "EthernetUdp.h"       // New from IDE 1.0
#include "Wire.h"
#include "DHT.h"
#include "Adafruit_BMP085.h"
//#include "TSL2561.h"
#include "Adafruit_SI1145.h"
#include "RTClib.h"
int buttonState;             // the current reading from the input pin
int lastButtonState = HIGH;   // the previous reading from the input pin
// Below is for bebouncing the rainBucket's hall effect switch.
// I'm tring this out because from time to time, I get false hits due to something unknown at this time.
// The following variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long lastDebounceTime = 0;  // the last time the output pin was toggled
long debounceDelay = 10;    // the debounce time; increase if the output flickers
char ID [] = "KFLFORTM67";
char PASSWORD [] = "xxxxxxxxxx";
byte timeServer0[] = {
byte timeServer1[] = {
byte timeServer2[] = {
  132, 163, 4, 103};
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };//Hard config for ethernet card mac addy
const unsigned long rainTime = 100;
const unsigned long period = 2500;// Measurement period for the anemometer(miliseconds)
const unsigned long IDLE_TIMEOUT_MS = 1000; // Time to wait for the WunderGround server to respond
const int radio = 60;             // Radius from center of Anemometer to center of one of the Anemometer cups
const int DHTPIN = A0;            // DHT 22  (AM2302)
// Pins
const int vane = A1;              // Wind direction
const int anemometer = 2;         // D2 Wind speed
const int rainTip = 3;            // pin D3 Rain bucket
//const int led = 6 ;             // Visual Notification for whatever
unsigned int RPM = 0;             // Revolutions per minute for wind sensor
unsigned int winddir = 0.0;       // Wind direction for anemometer
unsigned int rainin = 0;          // inches of rain
unsigned int dailyrainin = 0;     // dailyRain
unsigned int rainCount = 0;       // count down from ? for rainin Reset
float windspeedmph = 0/ 0.445;    // Wind speed (m/s) for wind sensor
float windgustmph = 0;            // Max wind speed for wind sensor
const float pi = 3.14159265;      //RPM Calcs
//TSL2561 tsl(TSL2561_ADDR_FLOAT); // Light Sensor
Adafruit_SI1145 uv = Adafruit_SI1145();// UV Sensor
//RTC_DS1307 rtc; // Hardware RTC time
void setup(void)
  Serial.begin(19200);
  //rtc.begin(); // uncomment to use Hardware RTC!
  // Uncomment to below to reset the Hardware RTC!
  // rtc.adjust(DateTime(__DATE__, __TIME__));// leave uncommented if using software
  // Comment out below to use the Hardware RTC
  rtc.begin(DateTime(__DATE__, __TIME__));
  bmp.begin();
  dht.begin();
  uv.begin();
  //tsl.begin();
  //tsl.setGain(TSL2561_GAIN_16X);      // set 16x gain (for dim situations)
  //tsl.setTiming(TSL2561_INTEGRATIONTIME_402MS);  // longest integration time (dim light)
  //pinMode(led, OUTPUT);
  //digitalWrite(led, HIGH);
  pinMode(anemometer, INPUT); //Anemometer input(spins like mad when the wind blows).
  Serial.println(F("Wunderground"));// Tells me whats Loaded on the arduino Chip if I change it out
  Serial.print(F("Compile Date:  "));
  Serial.print(now.month());
  Serial.print('/');
  Serial.print(now.day());
  Serial.print('/');
  Serial.println(now.year());
    Serial.println("Failed to configure Ethernet");
  ntp();//Set the RTC on first boot, it will fail the first time but Complets the second time
// ______________________________End of the Setup Function_______________________________
void loop(void)
  //uint32_t lum = tsl.getFullLuminosity();
  //uint16_t ir, full;
  //ir = lum >> 16;
  //full = lum & 0xFFFF;
  // Clear the Daily rain amount and check the time
  if (now.hour()==24){
    dailyrainin = 0;
    ntp();
  if (rainCount >= 900){
     Im using A 900 count for the 4 second loop time
     wunderground goes by 60 minute intervals
     4 seconds x 900 = 3600 seconds / 60 = 60 minutes
    rainCount = 0;
    rainin = 0;
    windgustmph = 0;
  //Start everything up!
  rainCount++;
  windvelocity();
  RPMcalc();
  WindSpeed();
  Heading();
  Rain();
  //float ldr = (uv.readVisible());
  //if (ldr <=351){
 // else if(ldr >=350){
    // You can change the gain on the fly, to adapt to brighter/dimmer light situations
    //tsl.setGain(TSL2561_GAIN_0X);         // set no gain (for bright situtations)
    //tsl.setTiming(TSL2561_INTEGRATIONTIME_13MS);  // shortest integration time (bright light)
  float UVindex = uv.readUV();
  UVindex /= 100.0;
  //float Wm2 = (tsl.calculateLux(full, ir)* 0.0079);
  //Wm2*=100;
  // Send the Data
    //Serial.println("Sending DATA ");
    client.print(ID);
    client.print("-");
    client.print("-");
    client.print("+");
    client.print(now.hour());
    client.print(now.second()+5);
    client.print("&windgustmph_10m=");
    client.print(windgustmph);//[mph past 10 minutes wind gust mph ]
    client.print("&dailyrainin=");
    client.print(dailyrainin / 2.0 / 100.0);
    client.print("&UV=");
    client.print(UVindex);//Si1145 UV/IR/Visible Light Sensor
    //client.print("&solarradiation="); //TSL2561 luminosity sensor
    //client.print(Wm2);
    client.println();
  else {
    delay(2000);
    return;
  //Serial.println("Server Response!");
    if (client.available()) {
      Serial.print(c);
  client.stop();  // Stop/disconnect the ethernet Client
  PrintSerial();
}// end loop
// NTP RTC Time SYNC
void ntp(){
  Udp.begin(localPort);// Start the UDP on the selected port
  // Serial.println();
  delay(100);
  sendNTPpacket(timeServer1);
  delay(1000);
    float f1,f2,f3,f4;
    t1 -= seventyYears;
    t2 -= seventyYears;
    t3 -= seventyYears;
    t4 -= seventyYears;
    // Serial.println(f4,4);
    Serial.println();
    // Adjust timezone and DST... in my case substract 4 hours for Florida Time
    // or work in UTC?
    //t4 -= (4 * 3600L);     // Notice the L for long calculations!!
    t4 -= (2/3600L);     // Divide by 2 for DST
    Serial.println("UpDating CLOCK ");
    //Serial.print("RTC before: ");
    Serial.println("Updated Time : ");
    Serial.println();
  else
    //Serial.println("ARRRRRRRRRRRRrrr !!!");// wait 10 more loop's.
    delay(1000);//wait a second or more before trying again
    ntp(); //Try to get the time from the NTP SERVER
  char datestr[24];
  Serial.println(datestr);
  pb[12]  = 49;
  pb[13]  = 0x4E;
  pb[14]  = 49;
  pb[15]  = 52;
#if ARDUINO >= 100
  Udp.endPacket();
#else
#endif
//Wind Speed Trigger/timer
  windspeedmph = 0;
  counter = 0;
  detachInterrupt(0);
//RPM calc needed for wind speed calc
void RPMcalc(){
void WindSpeed(){
void addcount(){
  counter++;
//Rain Trigger
void Rain(){
  int reading = digitalRead(rainTip);
  // check to see if you just pressed the button
  // (i.e. the input went from LOW to HIGH),  and you've waited
  // long enough since the last press to ignore any noise:
  // If the switch changed, due to noise or pressing:
  if (reading != lastButtonState) {
    // reset the debouncing timer
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    // whatever the reading is at, it's been there for longer
    // than the debounce delay, so take it as the actual current state:
    // if the button state has changed:
    if (reading != buttonState) {
       attachInterrupt(1,addrain,CHANGE);
  lastButtonState = reading;
// Rain calc
void addrain(){
  (dailyrainin)++;
  (rainin)++;
// Voltage to Compas Degree conversion
void Heading(){
// For debugging
void PrintSerial(){
  UVindex /= 100.0;
  // for Debug, or you can sit up all night watching it.
  Serial.println();
  Serial.print("wind dir:");
  Serial.print("\t");
  Serial.print("wind:");
  Serial.print("\t\t");
  Serial.print("wind gust mph:");
  Serial.print("\t");
  Serial.print("temp:");
  Serial.print("baro:");
  Serial.print("dew point:");
  Serial.print("\t");
  Serial.print("humi:");
  Serial.print("rain:");
  Serial.print("daily:");
  Serial.println(dailyrainin / 2.0 / 100.0);
  Serial.print("U.V.");
  Serial.println(UVindex);
  Serial.print("LOCAL Time");
  Serial.print("\t");
  Serial.print(now.hour());
  Serial.print(':');
  Serial.print(':');
  Serial.println(now.second()+5);
// End of program
« Last Edit: July 16, 2014, 08:59:27 PM by fmbfla »
Offline fmbfla
« Reply #4 on: July 16, 2014, 08:56:52 PM »
P.S. I got rid of the RTC Hardware and USE THE SOFTWARE RTC ONLY! For which each time the uno boots or every 24h it checks the NTP and resets the time automaticly :-)
Offline Scott216
« Reply #5 on: July 17, 2014, 08:42:51 AM »
Where you reset every night: if (now.hour()==24)
This will keep resetting for the entire hour, you'll lose any rain data during this time.  It would be better if you did something like this:
if (now.hour()==24  && now.minute()==0 && now.seconds() < 10 )
Also, for rainin it looks like you are accumulating rain for an hour, then resetting.  I thought wunderground wanted a rolling 60 minute total.  So you would always show the rain for the previous 60 minutes.  This would be more difficult to code.  Do you know which way is right?
Offline fmbfla
« Reply #6 on: July 17, 2014, 03:29:53 PM »
SCOTT
I'm still trying to figure out the best way to run it but I think it clears everything on the 24 hour, ..................and now I see your point for a full hour it will always reset until it reaches 01:00 hours..
I'll add to it
  "  // Clear the Daily rain amount and check the time
  if ((now.hour()==24)  && (now.minute()==0) && (now.second() < 10 )){
    dailyrainin = 0;
    rainCount = 0;
    rainin = 0;
    windgustmph = 0;
    ntp();"
Thank you:-)
Drew
Offline Scott216
« Reply #7 on: July 19, 2014, 08:43:56 PM »
fmbfla,
Found a bug in your code:
When the hour is 21, this will result in 21 + 5 = 26, which isn't a valid hour.  Here's how I am doing it:
now = now + 36000UL * 5UL; // adds 5 hours to local time
Also, I'm uploading some test data to wunderground and I can't get the "Precip Accum" to work.  On my PWS it's displaying -9999.00 in.  I though the dailyrainin field would populate this, but it doesn't seem to be working.  Here's a sample URL
rtupdate.wunderground.com/weatherstation/updateweatherstation.php?ID=KVTDOVER3&PASSWORD=removedpwd&dateutc=2014-07-20+00%3A22%3A31&winddir=180&windspeedmph=3&windgustmph=6&tempf=64&rainin=0.01&dailyrainin=0.01&baromin=32&humidity=76&softwaretype=Arduino%20Moteino%20v1.00&action=updateraw&realtime=1&rtfreq=2.5
My rainin value works okay.
I don't see anything like dailyrainin in your code.  Are you uploading the daily rain value somehow, or are you skipping it?
Offline fmbfla
« Reply #8 on: July 20, 2014, 10:58:45 PM »
Thank you :-), I will correct that one .
Are you attempting one of these too?
whats your set up ?
Drew
Offline Scott216
« Reply #9 on: July 21, 2014, 01:40:15 AM »
whats your set up ?
Drew
I have a wireless Davis Vantage Pro weather station and I'm decoding the wireless data (with a Moteino) and sending it to Weather Underground PWS.  I've got my files on GitHub: https://github.com/Scott216/Weather_Station_Data.  I'm still debugging it, but I think I'm close to having it working.
Offline Scott216
« Reply #10 on: July 29, 2014, 09:50:17 PM »
I finished debugging.  Seems to work well.  Go to github repo is you want to see my files.
Offline Scott216
« Reply #11 on: August 22, 2014, 09:12:31 AM »
Fixed a bug in the rain counter.  I assumed Davis ISS rain counter rolled over at 255, but it rolls over at 127.
In weather underground, I was getting rain accumulation jumps of 1.29 inches (129 pulses).  It's all fixed now and uploaded to GitHub.
