Author Topic: How to get data format for PWSWeather  (Read 4876 times)
Offline wristshot
« on: January 03, 2014, 05:41:49 PM »
Hello, everyone.
I am using weather software (WeatherSnoop for Mac) that does not offer the option of sending data to PWSWeather. I presume, however, that it is possible to write a script that parses the XML or JSON files produced by WeatherSnoop and assembles it into a format that PWSWeather understands. Although I am a total coding klutz, I did manage to do this for Twitter -- check out @WabanWX for regular auto-tweets from my station -- so I imagine that in the remaining years of my life I might get this to work for PWSWeather as well.
But I haven't been able to figure out the right data format. I do understand from googling that it's an HTTP GET request, but can someone provide the full architecture of the request or point me to a source for this info?
I should say I already have an account on PWSWeather and regularly submitted data when I was running different software.
Thanks!
m
    • Watts Bar Weather
Re: How to get data format for PWSWeather
« Reply #1 on: January 03, 2014, 06:58:28 PM »
Have you considered contacting PWS Weather to see what they recommend?  Weatherforyou is a member of this forum and moderates a thread on Weatherforyou/PWS Weather.  Perhaps he could be of help to you.  Good luck!  :)
« Last Edit: January 03, 2014, 07:06:26 PM by SlowModem »
Offline weatherforyou
  • Moderator
  • My weather is on WeatherForYou.com. Is yours?
    • http://www.weatherforyou.com
« Reply #2 on: January 04, 2014, 11:32:36 AM »
If you submit a support request at http://www.pwsweather.com/support.php I'll send over a sample of the string that is sent.
Joe Torsitano
Offline wristshot
« Reply #3 on: January 04, 2014, 11:43:06 AM »
Terrific. Will do. Thanks!
m
Offline wristshot
« Reply #4 on: January 11, 2014, 01:38:25 PM »
Thanks for the help. I did get this to work. The results can be seen at http://www.pwsweather.com/obs/WABANWX.html .
I posted the code to the WeatherSnoop forum here: http://www.weathersnoop.com/forums/viewtopic.php?f=11&t=546&sid=2917a2e11f74914a304a43a40cd7ccfe
If anyone has any questions about the code and how to use it, I am happy to help -- if I can.
« Last Edit: January 11, 2014, 01:48:23 PM by wristshot »
