Author Topic: Today's puzzler  (Read 934 times)
Offline Aardvark
Today's puzzler
« on: November 13, 2013, 09:34:22 AM »
my soil temperature probe at 3 feet suddenly shows a -65 temperature then goes back.  I checked it out on 3 receivers so it is the signal, suggestions?
Davis VP2 Plus; 24h  FARS; Extra Temp Humid sensor (2); Extra Temp Station (2); Soil Moisture/Temp  https://www.weatherlink.com/embeddablePage/show/1c484adbfa914d1aa10a58ad53ccd563/summary;Weatherlink IP;USB; MAC Catalina
; Webcam;
Offline SLOweather
    • http://www.sloweather.com
Re: Today's puzzler
« Reply #1 on: November 13, 2013, 01:11:05 PM »
Look for an intermittent short in your probe wire; open insulation, bare wires, rodent gnawing, shovel cut, etc.
Offline Aardvark
Re: Today's puzzler
« Reply #2 on: November 13, 2013, 01:24:36 PM »
that was my first thought.   the stinker is it is the 3 foot probe and it is spliced .   I don't want to have to dig  out the probe, fix it and re bury it.  I suppose the next best is to look for a new probe wire , run it down the conduit and be happy until next spring when I can redrill the hole.
I doubt it is a shovel or critter, but instead of soldering like I usually do. I used crimp connectors that were heat sealable, then I wrapped the wires and ran it in the pvc pipe.  it could very well be just enough contraction of the wire to break connection.
I am attaching a picture of how the leads go directly down to the right depth
; Webcam;
Offline Aardvark
Re: Today's puzzler update
« Reply #3 on: November 15, 2013, 07:19:42 PM »
I ordered a new temperature probe from Archer and it should be here next week.   I checked the wire and it looks fine, but something is flakey  so rather than pull the whole pvc pipe out of the ground, when the new probe comes, I am going to fish it down the pipe, probably hooked on to a wood dowel to the right depth.  it is going to be a bit tight since the pvc pipe is 1/2 inch diameter and has already two wires in it.   Should that work, things will be better.
to remove the old sensor, it has to be pulled up and I am not in the mood to either auger another hole or pull it up.  More to follow.
; Webcam;
