Author Topic: Alternative Dashboard version 6.95 Released  (Read 69841 times)
Offline bucks County Weather
    • http://www.backyardweather.org
Re: Alternative Dashboard version 6.90 Released
« Reply #50 on: November 02, 2013, 12:47:24 PM »
Make sure you tick it to update every minute in #7 setup.
Chris
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #51 on: November 02, 2013, 12:48:43 PM »
That's the correct configuration, but you must keep pushing buttons until it 'takes'.  Mine took lots of fiddling around before I finally accidentally hit the magic combination.
Regards, Jerry Wilkins
gwwilk@inebraska.com
Offline i_fiorentino
  • Davis Vantage Vue, Boltek Stormtr., Mobotix M22-IT
    • Meteopistoia.it
« Reply #52 on: November 02, 2013, 01:00:54 PM »
I've gave an eye around this problem.
So, manual upload works, automatic upload doesn't work :(
    • Meteopistoia.it
« Reply #53 on: November 02, 2013, 01:04:40 PM »
Ok, i've set to upload every minute.
Override on or off?
« Last Edit: November 02, 2013, 01:09:24 PM by i_fiorentino »
Offline ed2kayak
  • Ed
    • Cumberland Valley Weather
Ed
    • Meteopistoia.it
« Reply #55 on: November 02, 2013, 02:02:39 PM »
Wow, i succeeded  \:D/ \:D/
The problem (i think) was the "Override" button (red intead of green).
Regards,
Alessandro
Offline jonnyj771
    • Lightning Weather
Re:
« Reply #56 on: November 02, 2013, 02:07:30 PM »
Also Alessandro, make sure the graphic is set at a width of 180
Facebook:
Lightning Weather
   www.facebook.com/lightningweather
                             /groups/lightningweather
Lightning Weather Quad Cities
                             /lightningwxqc
                             /groups/lightningWXQC
Weather Station Hardware: Davis Vantage Pro2 6152
Weather Station Software: WD - 10.37S Build XXX (Beta)
Page Template: MeteoTemplate v1x. (Current Active)
    • Meteopistoia.it
« Reply #57 on: November 03, 2013, 01:45:14 AM »
Hi guys,
raintoday.gif doesn't reset after midnight  :-(
Now, it updates correctly but it remained with yesterday rain amount.
Any idea?
Regards,
Alessandro
    • Meteopistoia.it
« Reply #58 on: November 03, 2013, 04:45:09 AM »
 :oops: :oops:
It seems to be ok now.
I don't know how but it's fixed itself.
Regards,
Alessandro
Offline jgillett
  • unnamed weather station, Boltek, Win7 Pro, ToA
    • TiggrWeather Phoenix
« Reply #59 on: November 03, 2013, 10:18:01 AM »
Make sure your time zone settings are correct. I had the same problem with a different file from WD which turned out to be a TZ I had forgot to reset during a dashboard update.
W7JKG
BUY FROM AMAZON  HERE... Thank You! :-)
    • Meteopistoia.it
« Reply #60 on: November 03, 2013, 12:57:54 PM »
Hi John,
yes it's correct, "Europe/Rome".....i don't know why rain amount reset at 9.00am on my dashboard  :?:
Tomorrow it will be a raining day so i can test it again.
Regards,
Alessandro
Offline BurnsvilleWeather
  • Burnsville, MN USA
  • Retired from Weather!
« Reply #61 on: November 03, 2013, 01:36:08 PM »
UPDATE:
After playing around with many ideas and lots of trial and error, I've figured out a way to allow the lightning date and time to update with the rest of the site and display the date in the desired format.  Had to split the date and time out from the current combined testtag and then split the ajax tags into two separate ajax tags too.  It now works (at least in my testing) well enough to release it.
The new version is 6.91 and is only needed if you have lightning on your site.  If you don't use it, there is no need to jump onto 6.91 right away.  If you do update, only the main php and ajaxWDwx3.js have to be update as the ajax code changed to version 3.06 with this update.
There we a couple other very minor updates in this release to remove the negative sign in places where the red down arrow already shows in front.  I thought that was kinda a double negative thingy!  I've also added the instructions for using the new ajaxWDwx3.js file into the instructions as too many people are not reading the READ-ME-1ST file and they are actually using the stock ajax code instead!
Scott
www.BurnsvilleWeatherLIVE.com (Formally Webster Weather LIVE)
Home of the Alternative Dashboard and Mobile Dashboard Scripts. Weather Display Scripts and Graphics
Davis VP2 with, UV, Solar, Leaf, Web Cam.
  • Home of Oklahoma State University
« Reply #62 on: November 03, 2013, 02:08:51 PM »
UPDATE:
Is there a way to reduce false readings by only having it respond to flashes in fast succession, like how it happens with actual storms? Otherwise, I get a false response every time I use a wall or lamp switch.  In other words, a single response without a quick follow up would not count.
« Last Edit: November 03, 2013, 02:10:24 PM by Bunty »
Also the 2nd home page using modified AltDashboard 6.81 at http://stillwaterweather.com/wx/2ndhome.php
Offline jonnyj771
    • Lightning Weather
« Reply #63 on: November 03, 2013, 03:00:12 PM »
Hi John,
Regards,
Alessandro
Alessandro,
Check your settings in WD and make sure you are set to reset your records at midnight instead of 9 am.
Sounds like that setting is checked.
Facebook:
Lightning Weather
                             /lightningwxqc
« Reply #64 on: November 03, 2013, 03:51:59 PM »
That isn't a function of the dashboard, its a function of WD and the sensor.  Sorry.
Scott
UPDATE:
Offline RickNY
    • College Hills Weather - Farmingville, NY
Re: Alternative Dashboard version 6.91 Released
« Reply #65 on: November 03, 2013, 05:11:12 PM »
Did something happen with the sunlight pie chart after DST change?  Mine is now showing "Sunlight
Hours Unavailable", and I noticed Scott's was as well.  Using 6.90 and WD 10.37R-b76.
Rick
Offline gwwilk
« Reply #66 on: November 03, 2013, 05:43:51 PM »
Rick
The testtags.php variable, $changeinday, goes out of range and reports nonsense values during changes from DST to ST and vice versa.  I've coded my own $changeinday into my menubar.php and ajax-dashboard6.php so it still displays the change in sunlight from yesterday to today.  I've gone overboard since I could easily add tomorrow and yesterday to the mix and also report sunlight hours for them.  John Gillett is also using my code for the sunlight pie without tomorrow's or yesterday's sunlight hours.  In lieu of adding a bunch of changes to that part of your dashboard, you could just wait it out until tomorrow when your sunlight pie will be back.
Offline RickNY
« Reply #67 on: November 03, 2013, 05:48:28 PM »
Thanks Jerry.. I kind of figured it was a one-day thing during the changeover  (My station has only been up since August, so its the first DST change I've gone through.)
One day isn't going to bother me enough to implement code changes.
Rick
Offline jgillett
« Reply #68 on: November 03, 2013, 05:48:46 PM »
Note that, unlike most of the rest of the crazies, we do not use DST here. Thank goodness...
W7JKG
« Reply #69 on: November 03, 2013, 05:52:31 PM »
Ok, so two times a year you guys are the best!  \:D/
Scott
PS: Ducking and running for cover!
Offline RickNY
« Reply #70 on: November 03, 2013, 05:53:16 PM »
John,
AZ rebels ;)  Can't say I disagree with you though.. I just got done complaining about walking the dog in the dark in the morning when its been dark at 6:30 AM the past week or two, only to realize that now I'll be doing the same thing in the afternoons at 5:30 for several weeks anyway.
Rick
Offline jgillett
« Reply #71 on: November 03, 2013, 05:58:40 PM »
Scott - I'll take those two times, thank you. Better than my current record...   :roll:
Rick - Don't admit this too often, but long ago I lived in NJ for quite some time. Know exactly what you're talking about. Then again, on my last job out here I was on a 4/10 shift (0600-1630). Would leave for work in the dark and get home in the dark during the winter. Not fun...
W7JKG
Offline gwwilk
« Reply #72 on: November 03, 2013, 06:08:50 PM »
Scott
You better duck and run!  You've also got my code but haven't implemented it. :roll:  Still, I understand why not. :lol:  It does increase the server's work at initial page load of the dashboard.  Besides I think you have other fish to fry at the moment, when you feel like frying fish.
« Reply #73 on: November 04, 2013, 07:21:08 AM »
Noticed one issue when viewing my site from work...using IE10....my  SUN/MOON icon, which shows the pie everyplace else, shows the sun. Using Safari, Chrome and Firefox, shows the pie chart.
Chris
« Reply #74 on: November 04, 2013, 08:00:25 AM »
That's because ie can't display the code correctly.  That is how it is coded to react.
Scott
