Author Topic: AcuRite sensors and Weather Underground  (Read 2371 times)
Offline ryguyMN
« on: September 30, 2013, 08:56:18 PM »
Within the last month, I picked up a tower sensor (592TXR) and rain gauge (00899) with the AcuLink bridge.  The two sensors send data to the bridge, viewed on Acu-Link.com, just fine.  I have a Weather Underground account, and see that the Tower sensor weather data is transmitted via the bridge to WU, but rainfall is not.  Am I correct that only one sensor can be transmitted to Weather Underground?
Ryan
Offline nincehelser
Re: AcuRite sensors and Weather Underground
« Reply #1 on: September 30, 2013, 09:57:39 PM »
Yes.  Currently that is a limitation due to the way Acu-Link.com and Wunderground communicate....only one sensor per bridge is allowed.
There's an upcoming release of AcuLink (Version 1.8), but I'm not sure if it addresses this problem.
http://www.acurite.com/acu-link-release-notes
There are a few different routes you could go with this, but it's probably easier and simpler just to buy a 5-in-1 sensor suite.
Another route is using an old PC to sniff the data and forward it to wunderground directly.  Assuming you know a little Linux and scrounge the equipment, you could do this on a shoestring if not for free.  I've got code that could help you there.
Someone with a little windows programming skill could probably whip something out with too much trouble, too.
Offline ryguyMN
« Reply #2 on: October 06, 2013, 07:13:08 PM »
Thanks for the reply. I'll probably just stick to the current setup since I live in a colder climate (Minnesota), and don't plan on keeping the rain gauge outdoors during the winter months. Hopefully, AcuRite can make some enhancements to Weather Underground uploading.
Ryan
Offline nincehelser
« Reply #3 on: October 06, 2013, 09:18:57 PM »
The rain gauge can stay outside in the winter if you want.  As no water is held in the unit, there's no threat of it freezing and breaking like a glass or plastic tube gauge.
