May 26, 2013, 04:52:52 AM *
Members: 6623  •  Posts: 178941  •  Topics: 18156
Author Topic: Placefile for NAWN conditions  (Read 6272 times)
saratogaWX
Administrator
Saratoga, CA, USA Weather - free PHP scripts
« on: September 06, 2008, 02:50:23 PM »
For you GRLevel3 folks, the NorthAmericanWeather.net home for the affiliated regional weather network sites has a free placefile generated every 5 minutes with locations/conditions at member stations:
Just add the following to your GRLevel3 placefile list and set the refresh interval at 5 minutes
http://www.northamericanweather.net/members-placefile.txt
Best regards,
Ken
Davis Vantage Pro Plus - FARS, Boltek-PCI/NexStorm, GRLevel3, WD, WL, VWS, Cumulus, Meteohub
stormwatch
Contributor
« Reply #1 on: October 07, 2008, 12:13:27 PM »
Hi Ken,
Very nice!! I am having trouble though getting GR3 to display the info. I just purchased the software and and have been experimenting with it. I copied the .txt file and added it to "Place Files" but like I mentioned; I'm not getting the info on the map. Have tried reading the GIS instructions on GR3 but having problems understanding adding "Place Files".
Do I need to change the script in GR3 or how exactly does the Program pick up and display the "Place Files"?Still a little overwhelmed with all the features of GR3.
Any tips and suggestions would be greatly appreciated!
Tom M.
Tom M.
Carolina StormWatch Weather
Sunset Beach, NC
Grissettown-Longwood Fire And Rescue
Brunswick Co. CoCoRaHS Coordinator NC-BR-1
CWOP-0803
Advanced Skywarn Trained
saratogaWX
Administrator
« Reply #2 on: October 07, 2008, 01:01:01 PM »
Here's what I did in GR3 to add the placefile
GR3, Window, Show Placefile Manager
Press the 'Open' button (the left-most button in the Placefile Manager dialog)
Put http://www.northamericanweather.net/members-placefile.txt in the Place Filename area and press OK
Then close the Placefile Manager dialog.
GRLevel3 should do the fetch of the placefile (and refresh it every 5 minutes).
Best regards,
Ken
saratogaWX
Administrator
« Reply #3 on: October 07, 2008, 01:46:21 PM »
I saw the problem with the placefile .. I too got the 'red bar' with no error message.
I've reduced the size of the placefile by including only the US stations in it (since GR3 works only with NOAA NEXRAD) and it should be fine now.
Best regards,
Ken
stormwatch
Contributor
« Reply #4 on: October 08, 2008, 08:15:47 AM »
Thanks Ken; working great now.
Oops!! The hover is not working on the website; just on the actual GR3 program. The locations are showing up fne on my website though. Just not getting the current conditions.
Tom
« Last Edit: October 08, 2008, 10:04:29 AM by stormwatch » Logged
Tom M.
Sunset Beach, NC
CWOP-0803
saratogaWX
Administrator
« Reply #5 on: October 08, 2008, 10:46:32 AM »
Yes, the hover feature only works on the GRLevel3 program display (same with any placefile).  The images uploaded with GRLevel3 are just snapshots of the screen display.  GRLevel3 would have to emit <map> and <area> HTML to have the website display enabled with popups (but it doesn't) Sad
Best regards,
Ken
tnwxman
« Reply #6 on: December 27, 2008, 04:43:59 PM »
Hi Ken,
Thanks for the file. I send to the Southeastern network. I notice that the place file in GR3for NAWN is not refreshing every five minutes. What am I doing wrong. Refresh has 5 in the txt file. Please advise.
saratogaWX
Administrator
« Reply #7 on: December 27, 2008, 10:16:22 PM »
In GRLevel3, Windows, Show Placefile Manager...
In the dialog, right-click on the North American Weather Network .. it should show the current status of the feed and when the next update should occur.   Does it show a 5-minute interval between last update date and next update time?
Best regards,
Ken
tnwxman
« Reply #8 on: December 28, 2008, 11:22:45 AM »
Hi Ken,
It shows no errors. It shows the last update time and the next update time which is 5 minutes later. However when I cursor over my station and the other stations in the network it still shows the orginal data from when I downloaded the file yesterday afternoon. At the time I downloaded the file we had 65 degrees this morning after the front past we are 43 but the data showing is still the data from yesterday. This is true for all stations. What am I overlooking?
Best regards,
Bob.
saratogaWX
Administrator
« Reply #9 on: December 28, 2008, 02:03:50 PM »
Hmmm... very strange.  My GRLevel3 keeps the placefile loaded so it's current (within 5 minutes) all the time.
You do have Polling started (the File, Start polling is greyed-out)?   I can't think of another setting in GRLevel3 that would be used for placefile controls .. it seems to be built-in and refresh controlled by the refresh interval in the placefile itself.  ?!?
Best regards,
Ken
tnwxman
« Reply #10 on: December 28, 2008, 05:10:27 PM »
Hi Ken,
Yes start polling is greyed out. I tried with left check mark, then both no success.
Any other suggestions. I anew to GR3 so I can be doing something wrong. By the way is there an owners manual for GR3 I would like to understand the program more and what it does.
Best regards,
Bob
Page created in 0.093 seconds with 19 queries.
