Author Topic: Port Forwarding Help  (Read 10423 times)
Offline mkutche
    • GosportWx.com
« on: August 02, 2013, 06:17:20 PM »
Was wondering if anyone can help me with my dd-wrt linksys router port forwarding?? I've tried everything to get 192.168.1.108:800 to pick up on my public IP address 50.129.82.87:800 its for my d-link 930L cam so I can save upload times to my server and actually have a live stream so i can use Image Salsa plz and thanks below is what i have so far and yes UPNP is enabled. because in the settings UPnP Port Forwarding   Port open success.
Port Range Forward
Application   Start   End   Protocol   IP Address   Enable
D-Link 930L 80  800  TCP    192.168.1.108   yes
i dont know what im doing wrong hope someone can help me :)
Mike
Mike K.
WS2080 - Cumulus MX v3.0.0
Gosport, Indiana
Gosportwx.com Gosportwx.com/PWS/ Gosportwx.com/j-template/ twitter.com/GosportINWX facebook.com/GosportWxcom
Offline cospringswx
    • Colorado Springs Weather
Re: Port Forwarding Help
« Reply #1 on: August 02, 2013, 06:34:32 PM »
I had something similar happen to me. The cause was disabling a firewall in the IP cams settings software. Make sure UPNP is enabled in cam settings as well.
Ryan
Colorado Springs, CO
www.cospringsweather.com
Davis Vantage Vue
Weather Display Software
Hikvision HD IP Camera
Offline mkutche
    • GosportWx.com
« Reply #2 on: August 02, 2013, 06:40:08 PM »
UPnP SETTINGS
 UPnP   Enable
 UPnP Port Forwarding   Enable
all are checked
Mike K.
Gosport, Indiana
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
« Reply #3 on: August 02, 2013, 07:38:02 PM »
If you have UpNP on the router enabled, typically it will not require you to manually set up port forwarding, as it should register the device(s) properly in the table.  If not, then the device isn't really true UpNP.  I have a Foscam 8910W that works superb in this respect (however I have two ASUS RTN16 routers that have a third party firmware).
Weather radios:
Reecom R-1650
Sangean CL-100
Uniden Home Patrol I
Offline mkutche
    • GosportWx.com
« Reply #4 on: August 02, 2013, 08:30:46 PM »
ok so i bought PFConfig and Free PFPortChecker and its tellin me my external IP is 50.129.82.87 was able to ping to router and port check result "your port is Open on another device" this was after finding the application D-Link 930L on list with the ports 80,5150, 5160 TCP .. but im still yet to access it viea external IP. or am i not suppose to?
Mike K.
Gosport, Indiana
Offline cospringswx
« Reply #5 on: August 02, 2013, 08:58:11 PM »
Try this Mike. When selecting the protocol type select both to use UDP and TCP.
www.networkcamerareviews.com/articles/portforwarding.html
« Last Edit: August 02, 2013, 09:03:26 PM by hayskswx »
Ryan
Davis Vantage Vue
Offline mkutche
    • GosportWx.com
« Reply #6 on: August 02, 2013, 09:12:47 PM »
my router is a linksys DD-WRT v24-sp2 and i've tried PFConfig and still cant get my public IP address to pick up http://192.168.1.108:800/ =[
Mike K.
Gosport, Indiana
« Reply #7 on: August 03, 2013, 12:33:59 AM »
heh...  Are you trying to connect to it from inside  your network??  Because when I try that addy it says DSC-930l and asks for User ID and PWD?  You have to be OUTSIDE your network to see it.  USe the browser on your smartphone (no wifi) or  vampire onto the neighbour's wifi and you will see.
Offline mkutche
    • GosportWx.com
« Reply #8 on: August 03, 2013, 10:14:11 PM »
ok so i created a basic user and user for username and password it should bypass the login thing can anyone see this?? http://user:user@192.168.1.108:800/video.cgi?resolution=VGA im tryin everything if this dont work i'll just wait til i can afford a better router.. lol
Mike K.
Gosport, Indiana
« Reply #9 on: August 03, 2013, 10:54:41 PM »
Nope - linky no workie.  I don't even see the login screen now like I used to.  Router is not the issue.
Offline mkutche
    • GosportWx.com
« Reply #10 on: August 03, 2013, 11:38:41 PM »
*throws a rock* blah i give up LOL thanks for helpin anyway maybe one day I'll get it figured out lol
Mike K.
Gosport, Indiana
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
« Reply #11 on: August 03, 2013, 11:51:16 PM »
That link is a class C address (for internal networks) and as such, no one not inside your network will ever see it.  You need to give people the public WAN ip, not the interal LAN ip as you've done.
You can find out what you WAN ip is at http://whatismyip.com
« Last Edit: August 03, 2013, 11:53:47 PM by BigOkie »
Weather radios:
Reecom R-1650
Sangean CL-100
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
« Reply #12 on: August 03, 2013, 11:55:57 PM »
If you use this address:
http://50.129.82.87:800/video.cgi?resolution=VGA
Then I see video but it doesn't look like anything is there.
A tip - if you are using your internal network to access the camera, you will need to use the internal IP.  If you want external sites to retrieve it, you will need to use the external site.
In other words, if you are on the same network the camera is on, you CANNOT use the public wan address like I show above to access it, because most routers do not know how to handle the DNS loopback.  It's easier to just use the internal IP for usage at home.
« Last Edit: August 03, 2013, 11:58:58 PM by BigOkie »
Weather radios:
Reecom R-1650
Sangean CL-100
Offline mkutche
    • GosportWx.com
« Reply #13 on: August 04, 2013, 12:24:03 AM »
so u see the video? the cam im usin doesn't have night vision.
Mike K.
Gosport, Indiana
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
« Reply #14 on: August 04, 2013, 12:32:34 AM »
I'm seeing something.  It's black with a few horizontal flashes from time to time.  But I can tell there is motion to the page.
Weather radios:
Reecom R-1650
Sangean CL-100
« Reply #15 on: August 04, 2013, 12:33:15 AM »
50.129.82.87:800 with your UID/pwd credentials allows me to see your Dlink webcam pages.  And yes, it is night.  So you HAVE PFed.
Offline mkutche
    • GosportWx.com
« Reply #16 on: August 04, 2013, 11:20:16 AM »
ok so my next question is how can i get it to view live on webcam7 sorry for all the questions just new at all this lol.
Mike K.
Gosport, Indiana
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
« Reply #17 on: August 04, 2013, 02:02:21 PM »
I'm not sure how webcam7 works, but from inside your network, if it's an ipcam, you'd have to use http://192.168.1.108:800 as the base address.  If you tell webcam7 what kind of camera it is, it may know what to do after that.
Weather radios:
Reecom R-1650
Sangean CL-100
Offline mkutche
    • GosportWx.com
« Reply #18 on: August 04, 2013, 04:21:11 PM »
ok whoever has webcam7 what do i put for the IP/Host name and webserver port ?? i've put my public IP and port 800 and no one can see it =\
Mike K.
Gosport, Indiana
Offline cospringswx
« Reply #19 on: August 04, 2013, 04:47:31 PM »
The IP address of the camera and the port it's connected to
Ryan
Davis Vantage Vue
« Reply #21 on: August 04, 2013, 05:35:26 PM »
Are you sure the port number is not 8080
Unless W7 is specific, it is whatever he PFed to.
Offline cospringswx
« Reply #22 on: August 04, 2013, 05:46:09 PM »
Use 192.168.1.108 for Host IP and whatever port you forwarded to. When setting it up I recommend using Network Camera 640x480.
Off topic but I got an Axis 211 shipping! :grin:
« Last Edit: August 04, 2013, 05:49:45 PM by hayskswx »
Ryan
Davis Vantage Vue
Offline mkutche
    • GosportWx.com
« Reply #23 on: August 04, 2013, 06:03:30 PM »
ok this is coming from 192.168.1.108:800 since thats where the cam is broadcasting on..http://www.gosportwx.com/testcam.phplet me kno if it works
Mike K.
Gosport, Indiana
Offline cospringswx
« Reply #24 on: August 04, 2013, 06:06:25 PM »
no. When I go to this 50.129.82.87:800 I get a username and log in. That tells me that your camera is forwarded to port 800 but the outside world can't view it since its password protected or in the camera settings is not set up to direct to the home page?
« Last Edit: August 04, 2013, 06:31:45 PM by hayskswx »
Ryan
Davis Vantage Vue
