WeatherAnomaly
« on: October 15, 2008, 09:41:59 AM » |
Hey all
Looks like I'm a newbie all over again. My new VP2 just arrived and I have it mounted now. I'm switching from my 4 year old La Cross over to the Davis so I have a few questions. I have the Davis Instruments 6510SER Data logger with WeatherLink. The Data Logger is hooked into a an Envoy (6316). I also have a 6332 VP2 Anemometer Transmitter Kit. So looking at the VP Console I have the ISS running on station ID 1 and the Anemometer Transmitter Kit running on station ID 2. The VP Console sees everything just perfect. Now...getting it to run and dump the data to my server.
I'm not sure what really needs to be done next. I have VWS running but it cannot see the COM 1 port. I also have WeatherLink loaded up. I'll assume they are fighting each other for COM1? Questions:
Do I need to have WeatherLink running with VWS? Do I just run VWS and uninstall WeatherLink? Does VWS become the interface to the Envoy in place of WeatherLink?
I used to know my way around the old forum very well and until I come up to speed here I feel like a stuck pig in a pen.....reeeeeet! reeeeeet!
Thanks in advance all! Charley
Curly
« Reply #1 on: October 15, 2008, 11:23:22 AM » |
Hey Charlie, Congrats on the new station! I'm not sure what really needs to be done next. I have VWS running but it cannot see the COM 1 port. I also have WeatherLink loaded up. I'll assume they are fighting each other for COM1? You're correct. You can either run VWS or WL, but not at the same time. However, you can run both at the same time if you use VirtualVP because it allows both programs to access the data. Do I need to have WeatherLink running with VWS? Do I just run VWS and uninstall WeatherLink? Both programs are independant so neither one requires the other program. Curly
WeatherAnomaly
« Reply #2 on: October 15, 2008, 01:43:43 PM » |
Thanks Curly. Now for a follow question. I have not done so yet but....can I just change the station? VWS / Communication / Communication / and change the WX from La Cross to Davis Pro ? Or does anyone know if I will need to do a re-install of VWS? and yes, I will back up my 4 years of data first...
racenet
« Reply #3 on: October 15, 2008, 02:51:13 PM » |
Yes, you can just change the station. Then, do a restart of VWS.
Bob
WeatherAnomaly
« Reply #4 on: October 15, 2008, 03:19:50 PM » |
Thanks Bob. I did just that and I'm up and online! Hurray! I deleted my calibrations and then noted something. I'm still poking around as the options have changed since the communication is now listed a Davis.
1) Is there a place where I can do a reset on the entire VWS? 2) My anemometer is not connected to the ISS but rather it is connected to the Transmitter kit and the Envoy is reporting no Wind and the Direction is N. I have this set up in the Davis Console as station ID 1 and 2 and the readings are normal...wind speed changing and direction fluctuating. ID 1 being the ISS and ID 2 being the Transmitter Kit. So my question is where to set this up for the Wireless Transmitter kit in VWS?
mmorris
« Reply #5 on: October 15, 2008, 07:14:06 PM » |
There is no place to setup the wireless Transmitter kit in VWS if you Console is setup right then the data comes from the console and VWS doesn't know that you have a separate Transmitter kit for the anemometer.
>>Miles<< By from Portage Lakes, OH. Been using VWS since 1996 Ver# 14.01P43 Wireless Vantage Pro2Plus Serial Data Logger, Anemo Tran Kit Win XP, Firefox, WXSIM, Cumulus, NexStorm, Yawcam, VVP, BadBlue Web server, Quake Catcher Net Follow me on twitterVietnam era Veteran USAF bb loader Quadruple Bypass survivor
WeatherAnomaly
« Reply #6 on: October 15, 2008, 08:32:26 PM » |
OK, then that would tell me that I need to use WeatherLink to set up the Davis Envoy? And then the Envoy, once configured properly, would recieve the two station signals?
mmorris
« Reply #7 on: October 15, 2008, 09:56:39 PM » |
In weatherLink look in the drop down in setup for Set Transceiver and mine say: Station No1 is the ISS Station NO2 is Wind Then click on ok. That is all I had to do. Now I have the VP2plus and that is where my data logger is sending data to VWS your Envoy should be the same if that is where your data logger is. You may want to consider doing the walkthrough under the setup menu to setup you Envoy if that option is there for you to do.
« Last Edit: October 15, 2008, 10:09:25 PM by mmorris »
WeatherAnomaly
« Reply #8 on: October 15, 2008, 10:07:31 PM » |
Bingo! That was it. Thanks so much for the help. Now I can work with the Davis unit and learn all the new features it has.
mmorris
« Reply #9 on: October 15, 2008, 10:12:02 PM » |
Good deal. I was up editing my last post glad I could help out..
