Author Topic: Heavy Weather Pro 2800 Unhandled Exception error  (Read 7470 times)
Offline axplayer
« on: June 29, 2013, 09:52:21 AM »
Getting an error "Unhandled Exception error: bad allocation"
This just started happening. Nothing has changed on the PC I use.
I've uninstalled and reinstalled. Was working OK A week ago.
Any ideas?
Offline Weather Display
Re: Heavy Weather Pro 2800 Unhandled Exception error
« Reply #1 on: June 29, 2013, 04:43:39 PM »
sounds like a NULL pointer error or similar
what windows version?
you might have to delete the files/settings associated with the heavy weather pro software  and start over (i.e something might have goten corrupted)
Brian
info@weather-display.com
Offline axplayer
« Reply #2 on: June 30, 2013, 05:25:03 PM »
I'm on Windows 7. I have the software installed on a machine that I don't use regularly. Its my media server and just sits there in another room. I've uninstalled and cleaned out the registry. reinstalled and still the same error.
Task manager say it's running. Was working fine for a long time. No suddenly this. Maybe it's time to rebuild the machine. What a headache.
Offline axplayer
« Reply #3 on: June 30, 2013, 05:42:40 PM »
Is there any other free software that would work with the 2813?
« Reply #4 on: June 30, 2013, 06:59:02 PM »
is this the La Crosse 2800 type station or a WH1081 clone?
Brian
Offline axplayer
« Reply #5 on: July 01, 2013, 01:48:17 PM »
Yes LaCross 2813. Got it at Costco 2 years ago.
I can get the Weather pro software to work if I go through the registry and delete all entries that are HeaveyWeater related and uninstall the program. But when I reboot or shut the program down I get the Exception error. So I was wondering if any other software worked with this station
« Reply #7 on: July 01, 2013, 02:30:59 PM »
WUHU will need to read in the history.dat file updated by the heavy weather software
Brian
Offline DanS
  • Chiang Mai weather
    • ThaiWx
« Reply #8 on: July 01, 2013, 07:23:46 PM »
You could try another version of HW Pro by  grabbing it off the LaCrosse website. I'm running V3.1 because of some issue with V5 I had (can't recall what exactly it was right now).
Another thing would be swapping memory Simms around their slots or at least just reseating them. Never know.
« Last Edit: July 02, 2013, 02:44:45 AM by DanS »
Offline axplayer
« Reply #9 on: July 02, 2013, 07:12:53 AM »
Thanks all
Offline axplayer
« Reply #10 on: August 29, 2013, 12:00:34 PM »
Found the problem. The History.dat file was 482 meg. Guess it's too big.
After starting a new History.dat the program starts just fine every time.
