Author Topic: Confusing Situation/Erroneous Data  (Read 1693 times)
Offline midcon07
« on: August 04, 2008, 11:34:15 AM »
System is a VP2 w/ two consoles and WeatherLink v5.7.1. Yesterday, during a thunderstrom, console 1 went offline. Console 2 remained online. By the time I got console 1 back online it began recording the storm totals as of the time it came back online. Therefore console one recorded .33" and console 2 recorded .68" which is the correct amount.
Also effected when console 1 came back online was the barometric pressure reading which read atmospheric pressure instead of corrected sea level pressure.
My data from console 1 is what drives WeatherLink, the Weather Underground and CWOP. Is it possible without further corrupting data to switch out the consoles so that console 2 would drive the applications? If so would this rewrite/correct the information for any or all the applications? Since this sounds like a "too good to be true" solution how else could the data be modified in order for console 1 and WeatherLink to report the correct data? Also, is it possible to correct Weather Underground and CWOP data?
Thanks for your help.
Jerry
Jerry
Altoona, IA
Davis Vantage Pro2
VWS v15.00 p15
EW7358
CoCoRaHS: IA-PK-83
KIAALTOO4
