Author Topic: Blake Chimney Mount or other idea for anemometer  (Read 8286 times)
Offline mnwx
Re: Blake Chimney Mount or other idea for anemometer
« Reply #25 on: July 19, 2015, 03:43:59 PM »
Kudos and thanks! to BigOkie of Tulsa, who showed us how to use Superstrut hardware to mount a weather station to a flagpole.
In my case, the people at Home Depot not only cut the 4' length of galvanized pipe, they also cut four 8" pieces of Superstrut for me.  All I had to do was bolt it together.
Turns out our old flagpole is not only tapered, it isn't plumb -- so I used galvanized washers between the upper two pieces of Superstrut to get the pipe plumb and the weather station level.
This is my first post here, after 12 years with an older Davis weather station.
Thanks, --MN WX
