Author Topic: Stratus Rain Gauge Design  (Read 8387 times)
Offline LABob
« on: April 03, 2013, 05:14:46 PM »
I have the Stratus RG202 and I had always wondered why they didn't tweak the design a little bit so that the overflow would line up with the markings on the inner cylinder in a meaningful way. For example, if a station had received 2.1 inches of rain, wouldn't it be useful for the gauge to be designed so that the water in the overflow chamber lined up with the 0.11 mark on the inner cylinder? That would make reading total rainfall over 1-inch as easy as reading the level in the overflow chamber against the inner cylinder, multiply it by ten, and add 1 inch for the water in the inner cylinder.
Offline LFWX
  • Liberty Township, Butler County, Ohio
    • Liberty Fairfield Weather Center
Re: Stratus Rain Gauge Design
« Reply #1 on: April 04, 2013, 11:01:10 PM »
The only way to make an accurate measurement (to the nearest 0.01") is to use the small inner tube, any markings on the large tube would just result in much less accurate measurements.
OS: Windows Vista Home Premium
www.LFWeatherCenter.com
CWOP: DW1039
CoCoRaHS: OH-BT-1
Weather For You: DW1039
Midwestern Weather Network
Offline LABob
« Reply #2 on: April 05, 2013, 11:27:20 AM »
The idea wasn't to improve accuracy, but to make it possible to read the gauge without dismantling it (like during a storm). Redesigning the gauge as I described wouldn't affect accuracy, only make it easier to use.
Offline smorris
    • Long Road Station
« Reply #3 on: April 05, 2013, 12:13:48 PM »
Sure it would reduce accuracy. The inner cylinder is approximately a 10:1 ratio. One inch of rain fills 10 inches of cylinder. The outer cylinder is approximately 1:1 ratio, so one inch of rain (over the first one inch) fills the outer cylinder one inch. So the accuracy of the overflow would be 1/10 the accuracy of the inner cylinder.
One-hundredth of an inch of new rain in the outer cylinder would only increase the depth the thickness of 3 sheets of paper, which couldn't be distinguished.
Steve
Steve - Avon, Ohio
CWOP WU AWEKAS CoCoRaHS Skywarn MWWN UK Met PWS WeatherBug Twitter Facebook
Offline LABob
« Reply #4 on: April 05, 2013, 02:01:40 PM »
Why are you proposing to treat the two designs differently? You can still decant the overflow into the inner cylinder to get 1/100ths of an inch. The only change is that you would be able to read rainfall over 1 inch to the nearest 1/10th without disassembling the gauge, which is an improvement over the current design.
With an inner diameter of 4 inches, every inch of rainfall will fill a 1.155-inch ID tube with 12 inches of water. This is approximately the current design, and it works well enough. However, the entire outer cylinder is the same diameter as the funnel. Since the inner cylinder displaces some water, the depth of the water in the overflow doesn't relate in a meaningful way to the actual rainfall. If the inner diameter of the outer cylinder was changed to 4.239 inches, and the funnel kept at 4 inches, the water level in the overflow would rise one inch for every inch of rain that fell into the funnel (assuming the inner tube's walls are 1/8-inch thick).Everything would still work the same. The first inch would be readable in 1/100ths and the overflow would fill the outer cylinder. You would still decant the overflow into the inner cylinder to get 1/100ths of an inch. The only change is that while the gauge is still assembled you can glance at it and see that 2.4 inches of rain has fallen (for example). With the current design you cannot tell how much rain is in the overflow by glancing at the gauge, so I would say the accuracy has been improved in that respect without disturbing the ability to decant the overflow for higher accuracy.
EDIT: When you try to do math without double-checking your work first, you get mistakes. I corrected the calculations of diameters.
« Last Edit: April 05, 2013, 05:07:03 PM by LABob »
    • http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KFLBELLE2
« Reply #5 on: April 05, 2013, 08:02:33 PM »
I get what you're saying about checking the total at a glance but I think for the majority of people the current set up is just fine. I have thought about adding 0.10 lines on the outside cylinder with a thicker line when  it gets to 2.00  but I always defer to my tipping gauge to see the appx total.
Offline tomcj2
    • CanbyWeather
« Reply #6 on: September 28, 2013, 09:14:40 PM »
Is it possible that my VP2 is more accurate than my Stratus?
During sessions of light rainfall, no matter the amount, the VP2 is exactly the same as the Stratus, but when it is raining "Cats and Dogs" the Status is always lower, sometimes as much as 12%.
I initially thought that rain may be bouncing out of the Stratus, but I could not see it happening the other night during a downpour.
Any suggestions?
Davis VP2 (6163), WL 5.9.0..  VWS 14.01 p25, Panasonic HM371A camera. WU & W4U KORCANBY3, CoCoRaHS OR-CC-27
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
« Reply #7 on: September 28, 2013, 10:26:48 PM »
Probably not a good idea to get started with this guy.
Let's remember this thread:
http://www.wxforum.net/index.php?topic=18758
Weather radios:
Reecom R-1650
Sangean CL-100
Uniden Home Patrol I
Offline LFWX
« Reply #8 on: September 29, 2013, 12:41:17 AM »
Any suggestions?
You can remove the funnel and inner cylinder to collect rainfall, then pour the collected amount into inner cylinder for measurement. It will elliminate any bouncing off the funnel and it IS acceptable by CoCoRaHS (I asked them). You may need to swing the outer tube, centrifuge style, if you have drops sticking to the sides of the tube... or use the measure by mass method (just be sure to remove any moisture on the outside of the tube). http://www.cocorahs.org/Media/Training/Training_SnowByWeight.html
I noticed the same thing before I made the change.
CWOP: DW1039
CoCoRaHS: OH-BT-1
Offline tomcj2
    • CanbyWeather
« Reply #9 on: September 29, 2013, 08:33:16 AM »
Thank you for the prompt reply.  We are expecting heavy rain today so I will put your suggestion to the test.
Offline syvalley
« Reply #10 on: March 22, 2018, 01:54:12 PM »
I completely agree with and understand what LABob is proposing.  It was this exact thought that brought me (through Google) to this thread.  I also looked at a couple of other LABob posts in this forum and definitely of the opinion that you guys are lucky to have him as part of your group.
P.S. I know that I'm posting this to a dead thread, but I wanted to contribute nonetheless.
