We've build a few sheds over the years, all 8 x 10 feet. The first one was a simple tool house from 84 Lumber plans. The next was a cabin made of 3x laminated logs, with a stamped concrete floor and masonry fireplace (my avatar photo), and the third a machine shed with a porch roof homage to John Deere's shop in Grand Detour IL.
Now I'm looking at the stuff I've accumulated over the years, including 7 tempered glass panels 46" x 76", and the aluminum frame from a 12' satellite dish.
I'm thinking about a post and beam octagonal glass gazebo/greenhouse, and using the dish frame for the roof. Posts and beams would be 6x6es.
Frost is not an issue here, (central California Coast) and I might put raised beds in it for garden veggies, so I'd probably put it on post footings rather than a slab, and maybe floor it with open pavers ballasted with float rock for drainage.
I can install a vent of some sort in the roof, or raise the roof above the wall tops and install vents. And the door could be a Dutch style 2 piece door.
Last weekend I temporarily assembled the dish on the driveway. I think It will make a pretty interesting roof frame.
And I brought a 10' PT 6x6 home from the lumberyard for practice laying out the cuts.
After a LOT of thought and sketches, I think I have my 3 way base and top beams and post joint figured out.
The beams will be cut to 135 or 45 degrees (depending on how you look at it) and rabbeted accordingly for half-lap joints. Then I'll temporarily joint them with bolts or clamps and cut a square mortise all the way through the center of the joint.
On the post, I'll cut a matching tenon on the ends, and then rip the face of the post to match the 135 degree outside angle of the joint.
Gravity and the mortise and tenon joints will hold the frame together, and the entire joint should require very little in additional hardware.
And, (keeping this weather related) I can do something else I've always wanted to to. The pipe sticking up out of the center of the top of the dish used to be inside the dish to hold the LNA assembly at the focal point of the parabola. I can fab up a weather vane of some sort for the top of the pipe, and then extend its shaft down into the gazebo, and put an indicator on it at the top of the ceiling so we can watch the wind direction from inside.
BTW, the Internet has wonderful sites to help with dimensions of things like this. I found some octagon calculators that I used to easily refine some of the dimensions.
