Author Topic: streaming radio  (Read 25669 times)
Offline cospringswx
    • Colorado Springs Weather
Re: streaming radio
« Reply #50 on: June 05, 2013, 02:01:47 PM »
I email WU support and they got back with me saying to send a screen shot of scannercast. Waiting for a response. Otherwise I have it working here   http://audiostream.wunderground.com/hayskstornado/Hays.mp3.m3u . My question is how can I put this inside of a page?
Ryan
Colorado Springs, CO
www.cospringsweather.com
Davis Vantage Vue
Weather Display Software
Amcrest HD IP Camera
Re: streaming radio
« Reply #51 on: June 06, 2013, 03:12:17 AM »
Edcast doesn't like my Win 7 home WX PC. I've tried it since I had the problem and it crashed it again.
I know it works great on XP, but that probably doesn't help you much.
I wonder if anyone with Win 7 has successfully done this.
I use edcast just fine with Windows 7 and use a transfer rate of 32Kbps, rather than 16Kbps, so the audio will sound better.
Offline Cutty Sark Sailor
Re: streaming radio
« Reply #52 on: June 06, 2013, 06:49:43 AM »
Re Midland 300 streaming: Yes, WIN 7 ok. I use a tower, not a laptop, however, but have run it on laptop experimentally with no particular problems. Here's some experience and assumptions I've picked up over the last 4 years:
Quality: #1 secret is good static-free reception. #1a is the change the mono output to 2 channels.... getcha self appropriate Y-cable adapters (eg: http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=y-splitter+cable ) and split the mono to stereo channels.
This seems to work better than setting edcast to mono.
Now you can leave edcast at MP3/16kbs/22050hz/Stereo.
Edcast Source should be 'line in' not mic/stereo mix or 'speaker. (even though you may have plugged into something labeled 'mic/line'). Make sure you turn off any other Edcast encoders other than the one.
My volume out of M300 is about 30%, edcast Master Volume about 75%, watch peak meter, going to 0dB
Check Laptop power settings make sure stuff isn't set to power down, or standby, or go low power, battery save, whatever.
Edcast probably is not what's crashing pc. It may be memory, cpu heat, some other process... . Try setting it to run as administrator????
You can also try this:
If you're using Win7, stick a flash drive in a usb port, ( I happened to have 2GB handy) and set it for "Rapid Boost"... (unloads the hard drive a bit, etc, speeds some processes up.)
Cheers
Mike
Offline cospringswx
Re: streaming radio
« Reply #53 on: June 11, 2013, 01:06:46 PM »
Make a link without using the WU flash player?
Looking on your site, you can add something on the left sidebar, like you did for "Gas Prices", for example.
Just made this page...
http://hayskansasweather.com/wxradio.php
Ryan
Davis Vantage Vue
Offline cospringswx
Re: streaming radio
« Reply #54 on: June 12, 2013, 11:17:01 AM »
William at WU emailed me back and said they are having technical issues with the radio page and will get back with me when it's fixed.
Ryan
Davis Vantage Vue
Offline MesquiteWx
    • Mesquite Weather
Re: streaming radio
« Reply #55 on: October 29, 2013, 03:14:41 PM »
I know this is an old topic but seems to maybe fall into what I am having. I have streamed to WU before and stopped for a while. The person who was hosting the feed apparently quit so I am putting mine back up now. I am using Win 7 Pro 64-bit and have Edcast and everything set up correctly. It connects to WU, it shows it is active and it shows up in the directory. But no sound is coming from the WU feed when you select it and the radio is on and it shows in Edcast is getting a signal. I have sent WU a message but wonder if this is a problem with Edcast running on Win 7 Pro 64-bit or something else. I have run it fine in the past on XP and Vista.
Anyone else experienced this problem before?
-Thanks!
Offline cospringswx
Re: streaming radio
« Reply #56 on: February 08, 2014, 02:38:41 PM »
I got this back working! :grin: now I got to figure out how to get it on my site.  #-o
http://audioplayer.wunderground.com/Hayskstornado/Hays_mp3.m3u
« Last Edit: February 08, 2014, 02:44:15 PM by hayskswx »
Ryan
Davis Vantage Vue
Offline cospringswx
Re: streaming radio
« Reply #57 on: February 08, 2014, 04:18:08 PM »
This is the best I could do.
http://www.hayskansasweather.com/wxradio.php
Can't seem to get the white box outline around the icon on the menubar to disappear. ](*,)
Ryan
Davis Vantage Vue
Re: streaming radio
« Reply #58 on: February 08, 2014, 04:33:00 PM »
Got fed up with Wunderweenies...  ](*,) feeding my own self, so to speak. Yeah, I've got wunderground feeds for some other locations, but only because I can't find direct feeds for them. Some of 'em might even work.  :roll:
So, here's the player that pops up when the appropriate ('NOAA RADIO') link on my weather page is clicked:
http://ourspecial.net/twinhollies/weathercenter/wxradio/wxradio.htm
The first position (default) on the player feeds right from here at home, and goeth not  :lol:  to Wunderground.
Mike
Offline cospringswx
Re: streaming radio
« Reply #59 on: February 08, 2014, 04:48:33 PM »
Awesome Mike. WAY better than me!
Ryan
Davis Vantage Vue
Offline Maumelle Weather
    • Maumelle Weather
Re: streaming radio
« Reply #60 on: February 08, 2014, 05:06:54 PM »
Very cool Mike. How are you hosting it and what software are you using?  I am very interested.  I once had a stream with Wunderweenies, but always had issues with them.
GR2AE, GR3, Cumulus
Re: streaming radio
« Reply #61 on: February 08, 2014, 05:47:57 PM »
Midland 300 mono out Y split to L&R, line in, Broadwave ( http://www.nch.com.au/streaming/index.html ) to skinned Wimpy player (http://wimpyplayer.com/) on site. Make sense???  :-P  No clue what the newer Wimpys are like... my licensing is old...
    • Maumelle Weather
Re: streaming radio
« Reply #62 on: February 08, 2014, 10:15:29 PM »
Hi Mike,
Looking real hard at this. What format are you using for the stream? MP3.....?
GR2AE, GR3, Cumulus
Re: streaming radio
« Reply #63 on: February 09, 2014, 07:22:16 AM »
Hi Mike,
Yeah, the Wimpy's calling an mp3 from Broadwave. Broadwave as some functions under "connections" that offer sourcing, etc. I don't use it, but I think it will also determine automatically how to feed a request.. It's been awhile since I set these up, and while it's great to be able to set 'em and forget 'em, it's really bad when someone comes along couple of years later and asks what I've done!!!  My old grey cells take that 'set and forget' literally. Of course dedicated/reserved port forwarding and a DNS service or 'real' static IP (not sticky) are important...
    • Maumelle Weather
Re: streaming radio
« Reply #64 on: February 09, 2014, 08:36:45 AM »
Hi Mike,
Thanks for the info. My Uverse seems to have a static IP as it has been the same since they set it up last July, so hopefully that won't change now (probably will since I mentioned it). Looks like Broadwave can be used for free if you link back to them. I"ll see if I can port forward from my UVerse connection. This should be fun.
GR2AE, GR3, Cumulus
    • Maumelle Weather
Re: streaming radio
« Reply #65 on: February 09, 2014, 10:24:20 AM »
Hi Folks,
Have NOAA Weather Radio setup and running here.
You can also listen here, also.
The first link uses your player within your browser, the second link is a flash player.
Enjoy.
GR2AE, GR3, Cumulus
Offline cospringswx
Re: streaming radio
« Reply #66 on: February 09, 2014, 11:19:26 AM »
Congrats John. =D> You guys making me look bad. :lol:
« Last Edit: February 09, 2014, 11:27:05 AM by hayskswx »
Ryan
Davis Vantage Vue
    • Maumelle Weather
Re: streaming radio
« Reply #67 on: February 09, 2014, 11:48:11 AM »
Hi Ryan,
Overall it was pretty simple to setup. My biggest challenge was finding the right info. for my ATT Gateway Router/Modem so it could connect to Broadwave. I know I have to get a mono "Y" splitter to stereo input so its in stereo, but I'll do that later.
GR2AE, GR3, Cumulus
Offline cospringswx
Re: streaming radio
« Reply #68 on: February 09, 2014, 11:56:42 AM »
Is that why yours plays out of 1 speaker? I don't have a Y splitter and mine plays out of both speakers on this end. What about on your side?
Ryan
Davis Vantage Vue
Re: streaming radio
« Reply #69 on: February 09, 2014, 12:00:54 PM »
The pitiful thing about this, FireFox will not natively play an MP3... (it uses whatever is available on the local machine... if any)
Otherwise you could do the HTML5 audio tag, and the mp3 will play fine without any other contraptions... in IE and others... Firefox wants an ".ogg"
Matter of fact, try using that tag and opening the page with IE... it'll zip right along.
Now, there's bound to be a 'server' that will also offer "ogg"... but I've not found it,. nor explored server conversion or something..
WHOA folks, I'm talking as simple as possible here, not the icecast/shoutcast/extra third party stuff...
Re: streaming radio
« Reply #70 on: February 09, 2014, 12:03:54 PM »
I've been trying to dope out your radio feed thingy, and you've probably got it set to MONO... you'll not need it... we could probably get around the Y, but it's so darned easy, and don't have to remember a bunch of other settings... and where's what and who's who if we add other streams, etc.
Offline cospringswx
Re: streaming radio
« Reply #71 on: February 09, 2014, 12:07:32 PM »
Well don't make it too dopey. :shock: I know how you people from Frankfort, KY are.    :lol:   I shot you an email BTW. :-)
« Last Edit: February 09, 2014, 12:24:22 PM by hayskswx »
Ryan
Davis Vantage Vue
Offline cospringswx
Re: streaming radio
« Reply #72 on: April 19, 2015, 06:49:00 PM »
How do I get the WU player to start with my stream?
Ryan
Davis Vantage Vue
Re: streaming radio
« Reply #73 on: April 19, 2015, 06:57:44 PM »
Dunno... mine always starts with my local feed..
or whatever I add to the playlist... as you know, I dumped WU years ago.... uuucchhhh.
Offline cospringswx
Re: streaming radio
« Reply #74 on: April 19, 2015, 07:03:35 PM »
Thanks Mike but I don't have another way to steam it to my site that's the issue.
Ryan
Davis Vantage Vue
