Author Topic: Acu-Link Internet Bridge firmware update  (Read 5895 times)
Offline Rhino
« on: November 15, 2012, 12:52:13 AM »
Hey Everybody- anyone who currently has an Acu-Link Internet bridge will be receiving a firmware update!
The Acu-Link Internet bridge firmware version 126 update will occur on Thursday, November 15th. This firmware update will improve bridge performance and stability.
Acu-Link bridges will update automatically - no action is required. During the update, please DO NOT interrupt the power source or your Internet connection to the bridge. The update can take anywhere from 5 minutes to 30 minutes or longer depending on your Internet connection speed.
Acu-Link Bridge Firmware v126 will include the following:
• Improved data accuracy and charting (firmware protocol includes increased significant digits in data algorithms)
• Rainfall calculation fix for accurate rainfall data
• Bridge and display unit algorithm update, so data matches between units
• Bridge core stability upgrade for improved auto-recovery and up-time
• Methodology update for sensor wireless signal reception, for improved indication of true signal reception
Thanks!!
Ryan
Offline wxtech
    • Lexington, Ga. Weather
Re: Acu-Link Internet Bridge firmware update
« Reply #1 on: November 15, 2012, 07:52:41 AM »
Ryan, I was one of the recent Bridge Acu-Link Beta Testers.  I'm impressed with the 5-n-1 accuracy and the backyard weather site.  Last night we accumulated 0.29" rain in the NWS standard rain gauge, 0.28" in the CoCoRaHS rain gauge, 0.29" indicated on the AcuRite 1015 display, 0.27" indicated on the AcuRite 1055 display (different time/date), and 0.29" on the My Backyard Weather page.  The Davis VP2 indicated 0.20" and the rain total had to be adjusted.  I recommend the AcuRite system.
Offline hdtvluvr
« Reply #2 on: November 15, 2012, 08:11:00 AM »
I thought I would wake up with the new firmware but it didn't change. Will it be later today or tonight?
Offline Rhino
« Reply #3 on: November 15, 2012, 09:54:45 AM »
The firmware update will be staged throughout the day, can't say exactly when you will receive it- sorry!
Ryan
Offline Harry Nagel
« Reply #4 on: November 15, 2012, 10:26:42 AM »
When will this device be available for purchase? Any updates?
Offline Rhino
« Reply #5 on: November 15, 2012, 03:09:39 PM »
Yup! Available NOV. 16 at 3:00 P.M.   8-)
http://www.wxforum.net/index.php?topic=17246.0
Offline hdtvluvr
« Reply #6 on: November 16, 2012, 08:13:20 AM »
Rhino
Will the 14 day learning mode for forecast start over when the bridge gets the firmware update? If not, is there a way to reset it?
Offline Rhino
« Reply #7 on: November 16, 2012, 11:24:22 AM »
To start the forecast over again, delete the forecast weather select widget, then create a new one. Note that with the last website update, you can now calibrate the forecast. TO do this- click the "settings" button on the forecast widget, then you can calibrate the forecast.
Offline hdtvluvr
« Reply #8 on: November 16, 2012, 08:21:23 PM »
If you do it on your computer do you also have to do it on the iphone app?
When I reopened it on the computer, it didn't say that it needed X hours before it could display a forecast, the forecast was already available. Is that correct?
Offline hdtvluvr
« Reply #9 on: November 26, 2012, 08:10:29 AM »
I'm still not sure if the forecast reset. Any way t tell?
Offline Rhino
« Reply #10 on: November 26, 2012, 10:22:37 AM »
If it said it needed 4 hours of historical data, then yes- it reset.
Offline hdtvluvr
« Reply #11 on: November 26, 2012, 11:21:21 AM »
It didn't say it needed 4 hours. It just came back up with a forecast. Removed and re-added the widgets twice now with same results. What should I try now?
Offline Bruinzfan
« Reply #12 on: November 26, 2012, 10:21:25 PM »
Rhino,
Slightly off topic...do any of the stand alone rain gauges communicate with the Bridge?
Thank you,
Keith
Newb here!
Acu-Rite
38' Mast
Weather Display
Offline hdtvluvr
« Reply #13 on: November 27, 2012, 07:56:28 AM »
It must be a timing issue. Closed the forecast widgets last night and re-selected this morning. Now they say they need 4 hours of historical data.
