June 20, 2013, 04:50:07 AM *
Members: 6697  •  Posts: 181469  •  Topics: 18424
Please welcome ThePontificator, our newest member.
Author Topic: Wireless Vantage Pro loss of signal in Hurricane Isaac  (Read 382 times)
Dj1225
« on: August 29, 2012, 05:10:28 PM »
Hey everyone I live in Gulfport, MS. and were getting pounded by Isaac and I have a wireless Vantage Pro and I lost signal between the ISS and console...I went outside and saw that the door that houses the battery and the cables where they connect to the station had blown open...Is that the reason why I lost signal and what happens if it gets wet inside? Will the signal come back after it dries out?
wxtech
High Tech Septuagenarian
USAF Weather Equipment Maintenance Tech (retired)
« Reply #1 on: August 29, 2012, 06:26:05 PM »
A moist SIM circuit board will definitely cause failure.  Dry it out then dry it further with a compressed air cylinder.  If it doesn't fix the problems, then open it up and leave it inside a dry room.   Also check the RJ plugs and sockets for moisture.  It doesn't take much moisture to cause failure.   Packing the entire ISS in a jar of rice will help dry it sooner.  Rice is a home made desiccant.
I've had one that took 3 days to get the circuit board dry enough to operate again.
Al Washington, Lexington, Ga., Davis VP2+ WLIP 5.9.2 w/soil temp, VP(original) serial.  Acu-Rite 1015/1010/639/1055 5-n-1/3-n-1, bridge beta test group,
NWS Coop station=LXTG1, Fischer Porter, SRG, MMTS.
CoCoRaHS=GA-OG-1 manual & electronic ET gauges. CWOP=CW2074. XP with serial port, VWS v14.01p0, laptop with Win7 and USB ports.
Page created in 0.104 seconds with 18 queries.
