Virtual Weather Station - corrupted records in dbase.csv
(1/1)
sdh13:
Hi All
I am using Virtual Weather Station associated with a Oregon WRS 200 station and VWSql which retrieves the information contained in dbase.csv and updates a MySQL database on my server. It used to work fine for 2 years but since few weeks, I have more and more corrupted records (starting with a bunch of 000.000 ...) instead of the date format in dbase.csv. VWSql does not like this at all and instead of skipping the record, it stops analysing the other records.
It is necessary to clean manually dbase.csv to restartthe update process.
Is there any patch in VWS that would fix the problem or a parameter to set in VWSql to skip incorrect records instead of blocking the process.
Thanks in advance for some advice.
Brgds
sdh13  8-)
Navigation
Message Index
