Since when did an 04 TB have drive/steer by wire? I call BS.
The lightning may have welded the ignition switch contacts together, as well as some bearings in the steering column or the innards of the steering box. One mistake newbie arc welders sometimes make is clamping the ground on to a wheel or brake rotor and then welding on the frame, etc. The return current has to flow through the wheel bearings, welding them.
