May 24, 2013, 02:55:39 PM *
Members: 6620  •  Posts: 178789  •  Topics: 18139
Author Topic: Vantage vUE  (Read 1288 times)
shepsvettes
« on: July 08, 2012, 07:58:17 PM »
My 6 month old Vantage Vue died. No signal from the ISS Battery checks 3.12 volts any suggestions? If not Im going to call Davis tomorrow.
dalecoy
« Reply #1 on: July 08, 2012, 08:27:35 PM »
How did you determine this?  i.e., when you pressed the transmitter pushbutton, the LED didn't blink?  Or what?
If you followed all of the troubleshooting steps on Page 12 of the ISS manual, then calling Davis is the next step.
shepsvettes
« Reply #2 on: July 08, 2012, 10:10:26 PM »
No blink from the LED  did the steps from the manual.   WIll call Davis. Kinda dissapointing, It had worked great since it was put up in November
dalecoy
« Reply #3 on: July 08, 2012, 10:40:58 PM »
Well, it should still be under warranty.
shepsvettes
« Reply #4 on: July 09, 2012, 05:27:51 PM »
I left the battery out all night, ISS in dark basement so nothing from the solar panel, Put the battery back in this afternoon and it came back to life. I called Davis and they said it was locked up from being to close to my ham radio antennas.  First problem since November will try it again.
Bushman
« Reply #5 on: July 09, 2012, 07:58:34 PM »
Has it been in proximity to those same ham antennae?
shepsvettes
« Reply #6 on: July 09, 2012, 08:41:28 PM »
Yes, Nothing has changed since it was put up in November
dalecoy
« Reply #7 on: July 09, 2012, 09:03:18 PM »
Presumably, the frequencies used and other variables of ham radio have changed rather continually.  The ISS has both analog and digital functions, and any "lock up" from external RF is likely to seem somewhat random, and in fact may never happen to your Vue again.
W3DRM
« Reply #8 on: July 10, 2012, 11:13:41 AM »
My ISS and anemometer have been within 15 feet or so of my HF, VHF & UHF ham antennas for 6+ years and I've never had a problem with my VP2. Unless you are running full legal power, and the wx equipment is only a few feet away, I don't buy their explanation. There are many VP2's mounted on ham towers running full power without any problems that I have heard of. Perhaps the Vue is built differently and is more susceptible to stray RF though...
Don - W3DRM - Minden, Nevada --- Davis Wireless VP2, VWS 14.00 p101,
StartWatch, VirtualVP, VPLive, WL 5.9.3, Win7 Ultimate-SP1
--- Logitech QuickCam Fusion webcam
dalecoy
« Reply #9 on: July 10, 2012, 11:33:44 AM »
The Vue and VP2 are certainly constructed differently.  But perhaps if you describe your installation and nearby antennas, and shepsvettes describes the same thing, then we could get some idea of comparative proximity.
Of course, shepsvettes is describing one failure in 8 months, and there are lots of other variables also, and maybe it's not RF ... and maybe ...
Bushman
« Reply #10 on: July 10, 2012, 12:14:55 PM »
I think Davis is blowing sunshine on their explanation.
dalecoy
« Reply #11 on: July 10, 2012, 02:18:49 PM »
Perhaps so.  What's your explanation?  The Vue clearly "locked up", and "unlocked" after all power was drained.
I have no personal opinion as to why/how it "locked up", so without some alternative explanation, I can't personally declare anything about Davis' explanation.
So, please propose an explanation for the reported events.
SLOweather
Administrator
« Reply #12 on: July 10, 2012, 02:38:45 PM »
I don't wanna get in between dalecoy and bushman. I just want to mention that, in my experience, almost anything digital can lock up or be made to lock up. My smartphone has a couple of times. A lot of it has to do with the quality of design and assembly, and a lot with random circumstance.
Before I switched to wireless, my wired VP2 ISS locked up a couple of times due to EMP from close lightning. Unplugging and replugging the cable fixed it.
Mark / Ohio
Live from Mars!
« Reply #13 on: July 11, 2012, 08:40:37 PM »
Lightning locked my wireless VP 1 up tight once too.  With all the computerization now even home appliances and TVs need a reboot on occasion.  How often it happens is more of an indicator of a possible problem then the symptom itself.
jerryray
« Reply #14 on: November 07, 2012, 01:20:15 AM »
I have also had the lockup problems. I have two Vantage Views systems here, one on the tower, on on a lower roof.
This morning, the older Vue console stopped receiving, then an hour later the new on locked up. I have not been on the air in 2 days.
I had to install a normally closed mag switch on the tower unit. This way I use a telescoping probe to drop a magnet  in, This act as if the battery was removed
I just purchased another vantage sending unit. I am going to ferrite the leads in side and see if this helps.
As someone else here said the first 6 months were fine.
Page created in 0.084 seconds with 19 queries.
