Author Topic: Help connecting RG11 and WD?  (Read 4007 times)
Offline duke666
    • Nightingale Weather
« on: June 18, 2012, 01:56:51 PM »
Ok, go easy on me, I've decided to experiment with these little fellas and need pointing in the right direction ;).
I have two on the way and my aim is to use one as early rain detection and one as TB for direct comparison against VP2 TB & CoCoRaHS Manual Rain Gauge.
So this is what I think I know,
1/ WD can use the RG11 as a TB and measure accumulative rain fall.
2/ WD can use the RG11 as "its raining".
I assume 2 WD's would need to be running or can one WD be used to monitor two RG11's?
From what I've read here WD uses a "1 wire counter" to connect the RG11 to a pc. Has someone got a link to one of these and do I need anything else to connect RG11 & 1 wire counter to pc.
Also, I read there are other ways of connecting the RG11. Either by A/D converter or by serial / USB using this method at weather-above.com
Is there a preferred method?
I know there's a few questions in there but I want to start off in the right place.
I'm grateful for any comments and helpful information.
Duke.
« Last Edit: June 18, 2012, 02:12:20 PM by duke666 »
Offline Weather Display
Re: Help connecting RG11 and WD?
« Reply #1 on: June 18, 2012, 02:29:12 PM »
Hi
you can connect it straight up via a USB to serial adaptor
no need for 1 wire counter
WD then uses it as a rain detector (not as a rain gauge), via that way..see under setup, advanced/misc, rain..
if you connect up via a 1 wire counter then it can used as a rain gauge
Brian
info@weather-display.com
Offline duke666
« Reply #2 on: June 18, 2012, 02:44:56 PM »
Hi Brian,
Thanks for your quick reply. Can WD monitor 2 of these simultaneously, one set up as rain gauge and one as detector?
Duke
