May 22, 2013, 07:58:30 PM
Welcome,
Guest
. Please
login
or
register
1 Hour
3 Hours
1 Day
1 Week
1 Month
Forever
Members: 6617 • Posts: 178594 • Topics: 18125
Please welcome
TheMOX
, our newest member.
Home
Help
Search
Login
Register
Weather Station Hardware
Rainwise Weather Stations
> Topic:
Temperature Readings
Pages: [
1
Go Down
« previous
next »
Author
Topic: Temperature Readings (Read 1421 times)
blizzardof78
Offline
Rainwise MK-III and Heathkit 4001-ID.
on:
June 16, 2012, 10:11:01 AM »
Here is a brief question...
With the heat of summer just around the corner, literally, I noticed that many times since I have had my RainWise MK-III that the temperature readings may be a bit 'low' compared to other readings. I have the unit roof mounted. I actually thought when I put it up there I was going to be seeing temperature readings too high because of the heat off of the roof. Nope, just the opposite!
So, have any of you ever noticed, no matter where your stations are placed, that your temperature readings during the day seem too low? I have yet to reach 90 degrees here. Not complaining mind you!
Thanks for your observations.
Don in Ohio
VaJim
Virginia Beach Backyard Weather
Offline
Re: Temperature Readings
Reply #1 on:
June 17, 2012, 08:37:08 AM »
Hi Don
How 'low' are you seeing? Over the years I noticed the same. Usually it's a case of 1 - 1.5 degrees. Keeping in mind that with the Rainwise displays you see whole numbers whereas some others do show tenths. i.e. 59.3, etc.
Unless you're seeing huge differences (3-5 degrees) I wouldn't worry about it and if that is the case a call to Rainwise will get you fixed.
I've also learned to use caution when comparing stations, even those in the same yard. It'll drive you crazy. What's to say that the others 'around the corner' are correct?
http://vabeachweather.gofreeserve.com/
http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KVAVIRGI10
DanS
Chiang Mai weather
Offline
Reply #2 on:
June 17, 2012, 08:57:40 AM »
If there is a tree or other structure proving shade during the afternoon, this could be an influence.
Dan
ThaiWx website
WS-2310/2810 WUHU WinXP 24/7
blizzardof78
Offline
Reply #3 on:
June 17, 2012, 04:47:54 PM »
Good Afternoon;
Thanks you for the comments thus far.
I think several contributing factors go into whether or not my readings are way off, a station error, or just location for a couple.
I'll attempt to attach a couple of photos of the station taken today. As I write this it is 77 degrees. The closest "METAR" station is Zanesville, or about 25 air miles west of me. It is 81 there with mainly clear skies. Mostly cloudy here. The Cambridge Municipal Airport has a reporting station which updates every few minutes and they are currently at 80 but their elevation is 799' ASL and I'm at 1090' ASL.
Anyhow I guess it is what it is, right?
VaJim
Offline
Reply #4 on:
June 17, 2012, 05:18:18 PM »
Don: IMHO...25 miles is too far to compare. Maybe take a look at Wunderground and see what your neighbors are reporting. However, like I said, once you enter into station comparison, it can be like a rabbit chase.
IMHO (again)...the Rainwise does a much better job in protecting their temp/RH sensor. Thus giving you a more accurate reading.
Too bad you don't have someone close to you that also has a Rainwise.
blizzardof78
Offline
Reply #5 on:
June 17, 2012, 11:02:13 PM »
Hi Jim... Agreed on all points. None of the information on Wunderground is close enough to make a comparison. However Weather Bug does have a couple stations within 5 miles from here. I'll check those.
On a personal note are you still planning to make it up this way in July?
Don
VaJim
Offline
Reply #6 on:
June 18, 2012, 05:28:19 PM »
Quote from: blizzardof78 on June 17, 2012, 11:02:13 PM
Don
Hi Don
Our schedule has us coming through Canton about the 3rd week of July on the way to Cleveland.
Pages: [
1
Go Up
> Topic:
« previous
next »
Please select a destination:
Administration
=> Forum Announcements
=> Featured weather website
=> Bugs/Suggestions
General Weather/Earth Sciences Topics
=> Weather Conditions Discussion
=> Lightning
=> Severe Weather
=> Tropical Weather
=> Other Weather Topics
=> Weather in TV & Movies
=> Weather Photography
=> Weather Folklore
=> Earth Sciences
=> Weather Station Pictures
=> What Weather Station Should I Buy?
=> Davis Instruments Weather Stations
=> LaCrosse Technologies/Hyundai
=> Oregon Scientific Hardware
=> AcuRite Weather Stations
=> Ambient Weather Station
=> The WxTech Dream Machine
=> Hydreon RG-11 Optical Rain Gauge/Sensor
=> Rainwise Weather Stations
=> Remote Weather Monitoring
=> WeatherElement Weather Station
=> Boltek/NexStorm Lightning Detectors
=> Other Weather Station Hardware
=> Weather Radios
=> Weather Web Cams
Weather Software
=> VP Tools (Virtual VP, VP Live, and VP Tools)
=> Virtual Weather Station by Ambient
===> VWS Beta Testing
===> VWS WeatherFlash
===> ImageSalsa/MovieSalsa
=> WeatherLink by Davis Instruments
=> GRLevel X Software
=> Heavy Weather by LaCrosse Technologies
=> Cumulus
=> Weather Display
=> WUHU software
=> Macintosh Weather Software
=> Other Weather Software
=> Station Software Development
Web Weather
=> Personal Weather Station Links
=> Weather Web Cam Links
=> Weather Web Site Help
=> Weather Website PHP/AJAX scripting
===> Custom Website Templates
=> Weather Web Resources
=> Useful Links
Weather Related Organizations
=> AWEKAS
=> CWOP Forum
=> CoCoRaHS
=> GLOBE Program
=> SKYWARN
=> WeatherBug
=> WeatherForYou/PWSWeather
=> WeatherUnderground
Miscellaneous Debris
=> Tech Corner
=> For Sale/Wanted
===> Tell us a story...
Loading...
